Question about Canon ImageRUNNER 330s Copier
Our cannon ir has the error code E002... what does that mean? The model is 330s. And how can we fix it? Thanking you in advance.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Canon Expert
  • 259 Answers
That is mean problem with thermistor.
you must replace a new.
position is inside near exit paper place.
Posted on May 20, 2011
Sir you tell me how can I reset canon ir 2002n error code e002-0000
Hello . to clear that error you need to replace the fixing heater unit
Apr 25, 2016 | Canon Office Equipment & Supplies
IR 2002n. What does error e002-0000 mean?
The E00 codes are fixing unit temperature error codes. They relate to the temperature system that melts the toner into the copy paper when printing. When the fixing temperature does not reach a specific level it is usually a fault in the thermistor and you will see this error code.
How can i resolve the error code of E002-0000 on IR 2202? when i switch on it mark that error and refuse to operate please help us
I believe that model number is wrong......You must be referring to a Canon IR 2200 or maybe a Canon IR 2220. The Fuser has a problem when warming up. Replace the fuser or the Fixing film assembly and then the error must be reset in service mode.
Dec 03, 2014 | Canon Office Equipment & Supplies
Canon ir 6570 error code 14
Hi. This error code means that the fixing unit motor is unable to turn, it could be just a paper jam, or the bearings have seized, either way you will have to strip down the fixing unit, it is very common on this model for the lower roller bearings to seize. Good luck
Sep 06, 2014 | Cannon Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Error code E002 cannon 6612 photocopier
this is a canon generic error code that points that the fixing/fusing heaters or sensor has a problem try to swtch off & on the unit, check the ac power supply maybe its not stable, if the problem persist.you have to call your service provider regarding this.
Jul 04, 2009 | Canon Office Equipment & Supplies
CANON XEROX MODEL 6050
E002 - Fusing unit not heating up.
Replace fuser and reset code, best bet is to contact dealer.
Nov 14, 2007 | Canon NP 6050 Copier
Cannon Image Runner 330s
There is nothing wrong with the solenoid. The fuse cleaning web is similar to a roll of paper towels. For each copy made the copier fires the solenoid, advancing the web roll slightly. You can override the error but that will damage the upper fuser roller since it won't be cleaned and lubed properly. You need to replace (or have replaced) the cleaning web and reset the web counter in service mode. I am not sure on that model but when you purchase the web, $15-20, they can tell you how to reset it. Good Luck.
May 07, 2007 | Canon ImageRUNNER 330s Copier
78 people viewed this question
old marine
old marine
