Question about Toys
I have quantum leap globe but it's not working properly. The lower part of the equator line is working fine. On the other hand, the upper part of it keep saying wrong thing. :( For example, if I point USA with pen, it said greenland or the Arctic .The inside of the globe it seem fine, all the wires are connected. I tried reset it with make no betteries, but still same. Please help me and give some information I can fix by myself due to I am living abroad. I really appreciate for your concern about this. I look foward to your rapid response.
3 Suggested Answers
  • 2976 Answers
SOURCE: Leap frog globe pen no longer works
Either the wire is broken inside the insulation, or the batteries are dead.
Posted on Sep 17, 2009
jeffpresnail
  • 42 Answers
SOURCE: I would like to download
http://www.leapfrog.com/etc/medialib/leapfrog/parent_guides/pg_grade.Par.1139.File.dat/pg_explorerglobe.pdf
There you go...I think that's the one.
Posted on Feb 16, 2011
MICHELE CSX HAND ALIGNMENT
You don't say if your "CSX" is a battery powered watch or a mechanical or windup type watch. The solution for a mechanical watch is take it to a watchmaker. If it is a battery powered watch you may be able to do it yourself. Not all work the same way so without knowing what a "CSX" is I will give you one way to try. Pull the crown out two clicksHold the lower button in until a hand moves.You have now selected that hand to adjustUsing the upper button now, press and adjust the hand until it lines up with 12Now hold the lower button againAnother hand should moveUse the upper button to adjust this hand to the 12 positioncontinue this until all the hands line up with 12Press the crown in and press the upper button,the chronograph hands should startPress the upper button again and they should startPress the lower button and they should all go to the 12 o'clock position
Oct 21, 2011 | Michele CSX Diamond watch
On the TI83 calculator the equation solver dont workequation solver dont work
Most probable that you are not using the correct syntax.
Press MATH, then scroll down to reach the SOLVER line. Press ENTER. Create the equation, using the ALPHA keyboard to type in letter symbols.
Press ENTER. The screen that opens displays the equation and a list of the variable present in your equation. Each letter (variable) must have a value, except the unknown. If there is a 0 after the = sign on the same line as the unknown, you must clear it so as to leave a blank.
Specify the lower bound and the upper bound to speed up the search.
Once finished press [ALPHA][ENTER] to execute the (SOLVER)
Oct 20, 2011 | Texas Instruments TI-83 Plus Calculator
I would like to download an owners manual for the Quantum Leap Globe. Can you please tell me where I can find the manual.
Feb 16, 2011 | Toys
Does Quantum Leap Pianos work on Windows 7? The box says XP and Vista. I'm clueless about these things.
If' it's not specifically mentioned then it's not officially supported. But since 7 is just an improved Vista it might very well work - you have nothing to lose in trying. In the worst case you can always install and run it in compatibility mode.
Nov 19, 2010 | Eastwest Quantum Leap - Colossus...
Sep 17, 2009 | LeapFrog Toys
Quantum Leap Globe -Needs to order new probe(pen)
Philippines Ban Kee Trading, Inc.
Eric Bautista
tel: (632) 371-9978 ext. 114
email: ericb@pacific.net.ph
This appears to be the international distributer for those toys in your country. perhaps they will be able to assist you in finding a pen.
Did she lose the pen or it stopped working ?
Robert
Jan 07, 2009 | LeapFrog Leapster Electronic Book:...
Pen won't work on Quantum Leap Exporer Globe
ok, last night I was doing some research on my daughters leapster, its not a quantum leap, but maybe can be fixed the same way. I found out that you can "recalibrate" the machine. I used the instructions for the leapster, but here is what they said about the Quantum:
Turn the power on. Wait until you see the "Home" screen.
Find the small hole in the back of your Pixter unit above the battery compartment door. That’s the calibration hole.
Insert, push and hold the stylus in the calibration hole. Turn Pixter over so that you can see the screen. When you see two plus signs, remove the stylus from the calibration hole.
First touch the plus sign in the upper left corner with the tip of the stylus.
Then touch the plus sign in the lower right corner with the tip of the stylus.
GOOD LUCK, HOPE THIS WORKS FOR YOU, I ALMOST THREW MINE OUT TOO AND NOW IT WORKS.
Nov 19, 2008 | LeapFrog Leapster Electronic Book:...
Toys Logo
37 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
