Question about Garmin StreetPilot c550 GPS Receiver
I am thinking of purchasing a garmin gps but it says its pin is locked how do i fix this if I purchase it?
  • 343 Answers
The pin is a security code made by the previous owner and is registered at Garmin. The unit would have to be sent back to Garmin to be reset and re-registered. Be careful the GPS was or could been stolen. Thanks for using FixYa
Posted on May 18, 2011
Unlock garmin 1390t gps forgot 4 diget pin
    • 1 Enter your four-digit personal identification number that you used to lock your Garmin GPS. When your Garmin GPS is locked, you need to enter the four-digit PIN every time you turn the device on.
    • 2 Drive to the security location that you set when you locked your Garmin GPS. Turn your Garmin GPS on and pull the GPS antenna up so that your GPS is able to acquire the satellite. Once your GPS recognizes that you are at your security location, it will unlock itself.
    • 3 Contact Garmin if you forgot your PIN and security location. You will need to send your GPS to Garmin to have it unlocked. You will also need to send a valid product registration or proof of purchase for Garmin to unlock your GPS. Call Garmin at (800) 800-1020 and get the shipping address and specific instructions from an authorized Garmin representative.
Jun 09, 2011 | GPS
Garmin Nuvi 680 is locked, purchased at eBay
Hi, according to the Garmin user manual on its device, if you forget your pin and security information that will enable you unlock your Garmin device, you must send your Nuvi to Garmin to get it unlocked. You must also send a valid product registration or proof of purchase.
Feb 06, 2011 | Garmin GPS
I need a code to unlock my garmin 760 gps that i bought
Cathy, what follows below is cut and pasted from a Garmin tip I wrote for your problem:-
"You have Garmin Lock activated on your nuvi: there are only two ways you can unlock it.
1. Enter the PIN code (but you clearly don't have it).
2. Take the unit to the Security Location you chose when activating Garmin Lock: it will then unlock without the PIN code and you can then either reset the PIN or disable Garmin Lock. The Security Location should not be the owner's home address, but many owners ignore this recommendation. Many owners choose their workplace or a close friend or relatives address for this purpose.
If neither option works then your unit is useless unless you send it to Garmin with proof of purchase. Garmin charge for the service and if your maps are not up to date then it's really a waste of money as the investment would be better spent on a new unit with current mapping.
I hope that you manage to either fix your problem using my advice or at least can decide whether to abandon the unit and buy another."
So to summarise, unless your seller knows the PIN or unless the seller can take the unit to where Garmin Lock was set up in order to deactivate it for you, you have purchased a useless brick, sorry.
Sep 20, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
I am locked out of my GPS unit, I just purchased and
Brand new the unit does NOT have a PIN. Therefore, there is no where to "locate" it. You need to ask whomever you purchased the unit from what the PIN is. Failing that, ask them the location at which the PIN was set. This is the security location, and going there will unlock the unit. The only other option you have is to send the unit back to Garmin. Be aware, however, if you cannot prove to them that you purchased the unit, they WILL NOT return it to you.
May 12, 2010 | Garmin Nuvi 660 GPS Receiver
Touchscreen locked @ enter pin. Unit won't shut off unless power
The security pin ID was designed to discourage theft of Garmin GPS products. You can change the security PIN by taking your GPS to the location where you set the PIN and or send it back to Garmin with proof of purchase. I would see if you can update your unit through Garmin web site to see if it helps with the power issue, if not, it probably is the hardware switch and will require you to send it back to Garmin. If you purchased your unit from Costco, simply return it for a new one. Membership privileges. If you purchased it from your local retailer such as Auto Nav 2000 Plus, Inc. I'm sure they can assist you with getting your issue resolve with Garmin. If you purchased it eBay or an auction site, you maybe out of luck. Good Luck
Apr 03, 2010 | Garmin nuvi 255W GPS Receiver
Brand new, the unit does NOT have a PIN. You need to contact the seller and ask them the PIN. Your only other options to unlock the unit are to take it to the location at which the PIN was entered or send the unit back to Garmin. Garmin will require proof of purchase before they will unlock and return the unit to you.
Mar 20, 2010 | Garmin Nuvi 660 GPS Receiver
I purchased a Garmin Nuvi 260 on ebay and it is locked. How do I unlock it. It does nothing but ask for the pin?
I would do one of two things: ask the seller for the PIN or return it and get your money back. You cannot get past the PIN number without entering the correct PIN, taking the unit back to the location at which the PIN was entered or returning the unit to Garmin. However, Garmin requires proof of purchase in order to send the unit back to you.
Feb 14, 2010 | Garmin nuvi 260W GPS Receiver
I purchased a used locked Garmin c530 gps and I don't have the pin # to unlock it.Is there a way to unlock it.Thankyou
you will have to ask the previous owner for the lock code. if he doesn't know it, get you money back from him. the only way to unlock a garmin is to know which location the code was first programmed in or by sending it back to garmin with proof of purchase. this is an anti-theft feature.
Nov 10, 2009 | Garmin StreetPilot c530 GPS Receiver
Purchased device from a pawn shop who states a customer locked it in the store. brought it and researched on line and it appears only sending it to garmin will work. Hard to believe no one has figured it...
If a customer had locked the unit in a pawn shop, it would unlock in the same pawn shop as this would be the security location. And why would you buy a GPS you could not use? You have three options for unlocking a PIN locked Garmin GPS:
1 - Enter the correct PIN
2 - Take the unit to the location at which the PIN was entered
3 - Send the unit back to Garmin
No one has "figured it out yet" and there is no "fix" because this is a security design and not a flaw in the unit. It is to prevent someone from using a stolen GPS. If there were a workaround, the feature would be useless.
Oct 31, 2009 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 660
You will have to send it back to Garmin showing proof of purchase. Garmin will clear the PIN.
Jan 28, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
35 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
