Hello, I have a NEW monitor a170e1tt monitor and I don't know why it don't turn on, don't show any signal of live. what are the most comon problem of that model?
  • Computers & ... Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket hope this helps
Posted on May 18, 2011
  • 92 Answers
Check if the monitor is compatible with your type of pc and check what mhz your computer can handle or you can try check the motherboard monitr socket and check of some of the pins are gone.
1991 dodge spirit turn signals don't flash. Do I need a new fuse? Where is box?
The bulb that shows other drivers the turn might need to be replaced.
Nov 27, 2012 | 1991 Dodge Spirit
Magnavox tv turns off by itself
hello, i don't where you live but there are no analogue signals being broadcasted any more. if your in england you will need a freeview box, some tv will switch off if they are not receiving a signal
regardsshaun
May 11, 2012 | Toymax Magnavox 37MF337B 37 in. LCD TV
I have a 2004 Suziki GSXR 1000 and I am having trouble getting the taillight with intergrated turn signals to work. It will turn on but when I hit the brake it will turn off and the turn signals don't...
Make sure the wireing is all connected properly, i do know that some of these units only use 1 earth wire for the whole light, where as you would have 5 wires for the earths originaly, 2 x indicators, 1 x stop and tail light, 1x number plate light, it may be that you have wired an earth into a live circuit on the new lamp, the coloure code does not always mach that of your bike, so you will have 2lives for the rear indicators, identify these by putting the wires directly to your battery one at a time, connect the indicators using the indicator live wires only to the new unit, the stop light using the live wire only, and the rear light using the original earth and rear light live
Sep 06, 2011 | 2003 Suzuki GSX-R 600
My gateway computer power light blinks and moniter says no signal.turn it off held then power button on for 30 seconds.then turned it back on.same as before.
I don't think this has anything to do with the monitor since it is showing "no signal". this is an indication that the monitor is working.
Problem is from the connection between the computer and the monitor or from the computer itself.
Check the VGA cable and make sure it is firmly fixed into the computer and monitor.
Open the computer case, disconnect the keyboard, mouse, and every other thing apart from the VGA cord, then try again.
If there is still no signal, turn computer off again, remove it's power cord, then remove the system Ram, clean it and fix it back in. Then make sure the VGA card is well fixed into the mother board. After that, connect only he VGA cord and try again.
If non of the above seems to work, connect the computer to another monitor, and connect the monitor to another computer in other to confirm which is having a fault so that we can focus on it.
Keep me posted.
Good luck.
Jul 11, 2011 | Smart Modular SV3170A
No turn signals they come on but don't flash
It's probably the turn signal flasher. It is usually located under the dash along with the hazard light flasher. If you don't know what it looks like, then go to a parts store and look at a new one. Once you have located one, then remove it. Try the hazard flashers. If they work, then replace that flasher with a new one. If they don't, then reinstall that flasher and look for another one like it. When you find one, replace it with the new flasher and try the turn signals. (remember : the key must be on for the turn signals to operate). I hope this information helps you and thank you for using Fixya.com.
Jun 28, 2011 | Chevrolet TrailBlazer Cars & Trucks
The New TV.don't come on, keep showing no signal, don't know what is wrong, can you help us, to get it going. thank you
The TV is turned on. The TV showing "no signal" is an indication that is turned on. Its just that the TV is not recieving any signal whatsoever from an antenna, DVD player or dish.
I suggest you connect thee TV to a DVD player. Click source on the TV remote to AV 1. Use a RCA (yellow white and red wire) for the connection.
Yellow stands for video and white and red stands for audio. Connect yellow to "vidoe out' from the DVD player to 'video in' at the back of the TV. Do the same for the audio white and red.
Now there should be a display on the TV. If there is not display, check your connection.
Let me know if need more help.
Your sincerely.
Elect_Comp.
May 13, 2011 | Televison & Video
How do you turn the volume on?
Hello, look at this link to the user guide: http://www.viewsoniceurope.com/uk/assets/003/9907.pdf There is an audio set-up under the main menu
Don't forget you need to feed the audio signal into the monitor from your soundcard as well as the video signal from your graphics card. This is achieved using separate leads. (Apologies if this is too obvious!) Regards, nicam49
Apr 23, 2011 | ViewSonic VA2213WM Monitor
What will show on the screen if you connect lcd acer x193w only electricity? (Without the PC you plug inserted in lcd acer x193w.) I show my "Acer" and turns off, then starts again and goes off...
Normally when you don't plug a monitor into your computer but just into the wall socket then you should get a No Signal message displayed. If the monitor is behaving erratically then it's not a good sign. Try plugging the monitor into your PC as well and see if it still keeps switching on and off.
Apr 17, 2011 | Acer X193W LCD Monitor
My stand will not go back so I can attach the base...please assist
Hello and welcome to fixya.
I believe you are trying to assemble the monitor and you don't have the manual in hand so here are two links that might help you out:
1. The hp w1907 user manual - see page 13 for assemble instructions or page 22 (if you are looking to only adjust the monitor height).
2. An eHow.com brief explanation.
If you are looking for disassembling the monitor itself to repair it, please let me know so I can re-post another solution although there are a couple of youtube videos already online to show complete repair instructions for the specific monitor.
Let me know if this helped you at all for this.
**Don't forget to rate this solution**
Thanks.
Regards from FixYa.com
Apr 16, 2011 | HP w1907 LCD Monitor
When it's turned on, the light on my monitor doesnt show any signal of power supply
I'm assuming that you mean the green indicator light is not on. This could be caused by a host of problems. Assuming that you know the AC receptacle is live by testing with a standard light the next step would be to unplug the unit and remove the back. Check the fuse for continuity. If the fuse is good you have a problem with the power supply or a short which is keeping the power supply from powering up. The most likely culprit is the Horizontal Output Transistor. Unless you are an electronic tech and know how to check this you probably need to take the unit to a shop for further diagnostics and repair.
Jun 22, 2006 | Samsung SyncMaster 753S 17" CRT Monitor
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
