Question about Motorola Mobility Defy Cell Phone
I need to purchase a back cover for defy MB 525 it is black with wateroroof seal and locking catch type MWQ7-334411A11
Hard reset for Motorola Defy 525
Hi
To do an internal hard reset on your Defy please go to:
Settings / Scroll down and tap Privacy / Tap Factory Data Reset /
Tap Reset Phone.
If you want to perform an external reset on your phone please follow the steps detailed on this link:
DEFY Master Reset Factory Data Reset
Regards,
Gaby
Motorola Support
Jun 26, 2014 | Motorola Mobility Defy Mb525
How to install android OS in motorola defy ?
CONTACT US , depending on your location we may be able to find a facility to help reinstall the software. WE don't have any online self repair solutions.
Mark
Motorola Support
Apr 28, 2014 | Motorola Mobility Defy Cell Phone
Motorola Problems
Hi, I'm not sure what you mean exactly by "wont unlock" but if you see the "SIM network unlock PIN" message, it's possible to unlock the network on Fastgsm.com. So check it out, it can help if you have this sort of problem.
May 26, 2013 | Motorola Mobility Defy Mb525
Need more friction on movements. The slightest touch moves off target
Remove the 3 screws holding the black cover on the mounting arm. Gently tighten the lock nut until you achieve the required resistance but not too much that motor won't function. I found less that 1/8th of a turn was enough.
Feb 17, 2012 | Bushnell NorthStar 78-8831 (525 x 76mm)...
I need an unlock code for my defy
Hi, are you know how to unlock a mobile device? I think you didn't know, since you must give specific data before get Motorola Defy Unlock Code, like your IMEI phones, your mobile service provider. The easy way to get Motorola Unlock Code is buying from online unlock code seller, it will not time to much.
Apr 13, 2011 | Motorola Mobility Defy Cell Phone
1994 BMW 525 Battery
Look on the passenger side at the firewall and fender junction.   In the attached picture, see at the lower left side.  You need to remove the black plastic battery cover about 9"x7" located there, then you'll be able to see how the battery restraint works if you need to remove.
The title says 1994 525, and this is where tha battery is for '94, probably in the same place '91, if not look for a 10"x7" plastic cover elsewhere in the engine compartment.
Oct 30, 2008 | 2001 BMW 325
Motorola Mobility Defy Cell Phone Logo
52 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
