Question about Toshiba Satellite A305-S6857 Laptop
My toshiba satellite a305-s6857 powers up but in less than a minute or two, it restarts, and there's no message that a certain hardwared has failure. I also checked the memory and no problem either. I tried to replace the HDD and installed similar OS (Win Vista Home and Win 7) but the same problem was encountered. Tried to replace memory, removed battery, replaced adaptor, and even disabled the multi/ processor but same problem was encoutered. What should be the problem with my laptop?
    Sergeant:
  • 281 Answers
When you turn your laptop on start taping f8 at the same time.The screen will come to a screen that gives you some different options.Use the the up arrow button And highlight safe mode.Hit the enter key.The next screen will give you the option to go into safe mode by choosing yes.Choosing no will start doing a system restore.
You need to go to start>control panel >system> advanced>start up and recovery>and clear automatically restart.I hope this helps you.Thank You & good luck.
Posted on May 18, 2011
My A305-S6857 freeze every time when I tried to login. I cannot access to my desktop.
Try doing a startup repair by pressing F8 repeatedly on startup. On the options menu, choose 'repair my computer'. If this isn't successful you can try running your antivirus software in safe mode to check for any infections. Press F8 as before and choose safe mode. If this works, you can also check your event viewer to see if there are any system errors recorded: control panel>system and security>administrative tools>event viewer. Expand the critical and error menus under 'summary of administrative events' You can double click on an event for further detail and the event ID which may help you troubleshoot the problem further.
Apr 03, 2012 | Toshiba Satellite A305-S6857 Laptop
I have the Toshiba Satellite A305-S6857, and lately whenever i play music, or watch movies, or videos online the sound and video will skip or become delayed a couple seconds as if the computer is...
you do have something else running in the background and its using the internet, probably spyware or malware. run your anti-spyware program and check, if you don't have one, you need to try "malwarebytes" or "spybot" they are free programs
Mar 19, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
It works good on battery but when AC adaptor is plug in the laptop cuts out and restart by itself.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
Toshiba Satellite A305 AC Adapter
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Mar 11, 2011 | Toshiba Satellite A305-S6857, A305-S6858,...
My a305-s6857 webcam wont work. i think its a driver issue. where can i download the driver?
You can download any orall the Windows XP or Vista device drivers for your model laptop from theToshiba WEB site from their download page. Make sure you enter the model ofyour laptop so you can get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsphttp://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
Jan 07, 2011 | Toshiba Satellite A305-S6857 Laptop
When I plug in the charger , it charges the battery, but after seconds my laptop restarts or freeze.Battery last 2 hours and seams good.charger gives exactly 19.3 volt DC somehow it looks like the battery...
like the m200 problem maybe the power management system on bios you can try to disable the proseccor the upper procecor on device management . o to save mod open device manager disable the upper proceccor tan restart hope this can help u
Nov 04, 2010 | Toshiba Satellite A305-S6857 Laptop
Toshiba satellite A305-S6857 - how to replace the power inlet (jack) that is broken
Replacing the DC Power Jack on this model of Toshiba Satellite A300 series, is SWEET!
{The Toshiba Satellite A305-S6857 Notebook PC, is part of the Toshiba Satellite A300 series of Notebook PC's}
No de-soldering, or soldering is needed.
The DC Power Jack is a DC Power Jack Harness.
The DC Power Jack is connected to a cable (Wires) that end in a connector, and the connector plugs into the motherboard.
To repair the problem you just replace the power jack harness.
A) Guidance given with instructions, and a pictorial guide, (Click on each photo to enlarge),
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A305/laptop-disassembly-process-1.htm
The above is Page 1.
To go to Page 2, and Page 3 ,click on the white page number at the top, or bottom of the page.
{Page 1::Page2::Page 3::Find another model }
Page 2, Step 17 shows you the DC Power Jack Harness, and where it connects on the motherboard. (Small white rectangular connector)
B) This is a link to a free Service Manual for the Toshiba Satellite A300 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the 11th line. The one that starts with Satellite A10.
Scroll across, and click on > A300
This is a PDF file.
Allow up to 30 seconds after you click on the file name A300, for the first page to come up.
It may also take additional time for the file to fully download.
C) Remove ALL power to the laptop before you begin.
Remove the AC adapter (Charger) and Battery
D) Observe Anti-Static Precautions
It is Advised to buy and wear an ESD wrist strap, and connect the alligator clip to a good ground source.
{For one example I connect the alligator clip to the metal frame of an empty desktop computer case}
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
Using an ESD wrist strap, and connecting to a good ground source, will relieve your body of Static, and help to ensure your laptop is safe from Static shock.
E) Use a multi-compartment container for the various screws you will remove.
Mark each compartment for the area the screw/s come out of.
There may be as many as 60 screws, and 12 different types.
Do NOT mix them up!
If no multi-compartment container is available, you can substitute with a clean egg carton.
Mark each egg holder.
F) Make a record as you disassemble. It's nice to have a record you can go back to in case you are interrupted, and to have a record that YOU understand.
Make notes and drawings, use a camera, or video cam if available.
{Use Good lighting}
From a quick search,
1) http://compare.ebay.com/like/170510661911?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar&rvr_id=184497530091&crlp=1_263602_309572&UA=WXF%3F&GUID=e35d70b712c0a0aa14823c52ff69e46d&itemid=170510661911&ff4=263602_309572
Another one,
2) http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=3231&zenid=90f1860bdc1b624a9122b76394734645
Regards,
joecoolvette
Jul 07, 2010 | Toshiba Satellite A305-S6857 Laptop
FM radio tune with fm antenna on a305-s6857
My laptop is Toshiba M300 and I use FM Tuner Utility under NXP FM Tuner in all programs.
Mar 14, 2009 | Toshiba Satellite Pro M300-S1002V T8300...
maybe you can find the instructions online, or try google it,if not talk to the store or company you bought it from
Aug 17, 2008 | Computers & Internet
Toshiba Satellite A305-S6857 Laptop Logo
179 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
