Question about Xitel INport Deluxe for PC
The program has worked very well for some time. Ive moved > from a windows xp computer up to a windows 7 pc. Until > recently ive had few problems trimming the track of entire > selection recording that I have made from my radio/lp/etc.., > into individual tracks/songs. Now It will only let me trim > the first half of a 3 hour 20 minute chunk of recording. > Usually almost half exactly. When i trim the recording into > individual songs, I begin by putting the end marker (red) at > the far end right side and work my way back moving the green > starter marker ever backward to pick and choose wanted > tracks to single out to keep. The recording will not play > (the cursor does not even move)until I get to the middle of > the recording itself. eventually I am only able to get half > the tracks trimmed and cant even hear the last half. Are the > settings wrong? does it have something to do with changing > from an xp to a windows 7 computer? any help is appreciated. > I cant seem to find any thing online that could explain this > or in the manual. When i moved into the new computer (xp to windows 7) i needed to get a new encoder it was "fastencc" it is now called "lame". I dont know if this is a software problem or a hardware problem. The people /makers of the product seem to be baffled at this as well. One other irritating problem that i have had is the reception from tiime to time drops in and out leaving gaps of a few seconds throughout the recording often leaving it worthless.
0x0000008E (0xC0000005,0x805D946E,0xF78032FC,0x00000000)
Remove all USB attached devices like drives. You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode. To eliminate possible bad RAM. Unplug PC, open case, and remove all RAM. Test one DIMM at time, one slot at a time. Re-install Windows. Clean install works best, but all data will be lost. Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Dec 11, 2012 | Microsoft Windows XP Home Edition English...
Have 2 pc's , need to tranfer old to new (files)
Only suggestion I have is back-up all important files and then reload to new computer.
Oct 28, 2012 | Dell Dimension 1100 PC Desktop
I just recently bought a sylvania netbook that runs windows ce.I really dont know much else about it.Ive tried downloading some games and it says that its not a windows ce file or something.Ive also...
You can run software that says it is designed for WindowsCE. This is not the same as full Windows (xp, vista, 7) so normal windows programs will not work.
Apr 26, 2011 | Computers & Internet
Purchased my Seagate June 6, 2008 and have used it just a few times with my Win XP. I recently bought a new PC with Win 7 onboard (naturally). Now I want to transfer (copy) my music and photo files from...
Certainly, any files that you write using Windows XP will be able to be read with Windows 7.
I'm not familiar with the CEEDO program -- did the author update it for Windows 7 ?
Dec 26, 2010 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
I need to uninstall Micosoft Intrnet Explorer so that I can reinstall IE7. I keep getting s message that a more recent one is on my computer but I cannot find it to ubinstall it.
Click "Start" then "Control Panel" --> "Add/Remove Programs" --> "Add/Remove Windows Components" --> click the "Internet Explorer" and uncheck it, click "Next" wait for few seconds until the uninstallation is finished and click "finish" when done. Close the windows and now open, "My Computer" -- > "C:" drive --> then "Program Files" and locate "Internet Explorer" and delete the folder. Now restart your computer and repeat the same procedure from "Start" then "Control Panel" --> "Add/Remove Programs" --> "Add/Remove Windows Components" --> click the "Internet Explorer" and uncheck it, click "Next" wait for few seconds until the uninstallation is finished and click "finish" when done. That should work. Even if you don't repeat the steps, by default, windows Xp has the Internet Explorer 7 with it.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 19, 2010 | Microsoft Windows XP Professional
Theme Failing to work.
Go to Restore..
Menu details:
start==>all programs=>accassores=>system tools=> system restore...
give ur installation date...thanks.........
Mar 25, 2009 | Computers & Internet
Dell Desktop, wont power up..monitor goes blank
Remove the cable. Keep pressing F8 while you power on the system and choose safe mode, press enter. Screen will roll up a few pages and stops for a while. wait a few minutes. windows will start in safe mode Scan for viruses. Restart. It is a virus problem
Dec 16, 2008 | Dell Dimension 4600 PC Desktop
Vertex programming problems via USB
This probably doesn't help, but sometimes a much slower (older) computer will work where a faster (newer) will not. The Motorola's are notorious for this. Others, too. USB is USB, a standard--so that's not your issue.
Apr 13, 2008 | Radio Communications
Xitel INport Deluxe  for PC Logo
54 people viewed this question
Top Xitel Computers & Internet Experts
KG John Justin
KG John Justin
 Grubhead
Grubhead
Are you a Xitel Computer and Internet Expert? Answer questions, earn points and help others
