Question about Nintendo Wii Console
I am having difficulty accessing the wii Internet after typing in the encryption code to my families wireless router. How can I access the internet? The error code that popped up after typing in the code to the WEP box was 51030. I do not know what this can be used for, bit I hope it can be used to help solve the problem.
    Novelist:
  • 82 Answers
You probably have to cycle your network. The 51030 error code means you have a problem with your system's SSID. SSID stands for service set identifier, which is basically a network name. It's how your private wireless network knows that a device is allowed to be on it, essentially. To fix this problem:
1) Unplug both your modem and your wireless router.
2) Leave them sit, powered off, for a few minutes.
3) Plug the modem back in, allowing it to fully boot for a few minutes.
4) Plug the route back in after the modem has had a chance to boot.
5) It may not be necessary, but at this point I would advise rechecking or resetting the wireless connection settings on your Wii. This is really a precautionary step, but will definitely increase your odds of success. Try connecting again.
6) If these steps don't work, completely erase your connection settings and create them again from scratch, making sure to double check that all the settings you are entering are EXACTLY the same as they appear on your router.
Posted on May 18, 2011
Error code 51332 unable to connet to internet
Error Code: 51332 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Jul 01, 2010 | Nintendo Wii Console
Internet connection
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Apr 25, 2010 | Nintendo Wii Console
When I try to connect to the internet this comes
That means it's not connecting to the wireless router. You need to go on a PC connect to the router. It is usually 192.168.1.1 or 192.168.0.1. Once you login (default username and pass varies by router but "admin" and "admin" is my first guess). Go into the wireless settings and make sure that:
1. It is being "broadcasted" and not "hidden"
2. You are using the right encryption method your router is at (WEP, WPA, etc)
3. Make sure you have the correct WEP code
Hope this helps,
BReady
Mar 27, 2010 | Nintendo Wii Console
Error code 51330 on the wii.it will not except my
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
Need further troubleshooting? Go straight to Nintendo's website at:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Nov 19, 2009 | Nintendo Wii Console
Can not connect to the internet error code 51330 WII I have wireless connection in my home
I don't personally know how to solve this, but you could try some of the suggestions here.
Sep 09, 2009 | Nintendo Wii Console
Need encryption code...
here is a trouble shoot guide for your problem. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Mar 03, 2009 | Dell TrueMobile 2300 Router (000001)
Access to password
yas thats encryprion key it is set for your internet security.
http://192.168.1.1
or http://192.168.0.1
try both this link it is default ip for access router.
but if this ip not works then u must have to reset your router with reset switch it in back side of your router.
thewn u can access router with this link.
then it propmts for user name and password.
then user anme: "admin"
paasword :"admin"
or
reamin pasword blank.
then u got some menu.
go to advanced security then u se encryption code.it is which u prompt when u connect your wi fi internet. ceck those pasword and type wehn u coonect yourinternet .
thats it.
Dec 29, 2008 | NetGear DG834G Router
Cant conect to internet
  • Wii Error Code 51300 - 51399
  • This error is caused by the Wii being unable to connect to the access point.
    To solve this error :
    Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds.
    If your router is using WEP encryption
  • Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
  • 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
  • 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
    If your router is using WPA encryption, the Wii is compatible with :
    WPA - PSK(TKIP)
    WPA - PSK(AES)
    WPA2 - PSK(AES)
    If your router is using MAC filtering, ensure the Wii MAC address has been added to the list of approved MAC address on your wireless router settings
Dec 27, 2008 | Computers & Internet
Error Code 51331
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
Sep 10, 2008 | Nintendo Wii Console
Wii wireless connection
On your computer Open an Internet explorer and type the router IP address which would be either http://192.168.0.1 or http://192.168.1.1
Look for the SSID and write it down.
Also write down the type of encryption you are using. WAP, WEP, or none.
Also write down the security Passphrase.
Also you will need the IP address, in Windows click on Start, Run and enter 'cmd" in the run box.
At the command line type "ipconfig" and record the IP address
On the wii, You should be able to have the wii look for a Wireless Access Point. If that does not work try the Manual Setup in the Internet Connections menu.
Enter SSID
Enter Type of Encryption.
Enter Security Passphrase
Enter IP address
MTU value is not required. Nintendo recommends 1500 if you are having issues.
http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=wRouter
Mar 10, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
152 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
