Question about Kitchen Ranges
Does this model have a sabbath mode - Kitchen Ranges
  • 8,197 Answers
MAy I get the make and model # to see if it does have a sabbath mode
Posted on May 18, 2011
My Frigidaire refrigerator is showing the code 5c 5b on the front panel. What do this mean
Hi Juanita,
I'm not sure what the 5c code is however the 5b code means "Sabbath Mode" (Sabbath Mode is a feature that disables portions of the fridge and its controls in accordance with observance of the Sabbath and religious holidays within the Orthodox Jewish community)
You need to press and hold the arrows ("?" on freezer temp and "?" on refrigerator temp) to remove it, if the arrows are not lit up, press them anyway to try and get the fridge out of Sabbath mode.
Hold down both arrows for ten seconds to get out of Sabbath mode.
If that does not work, unplug the fridge for 10 minutes, plug back in, and try once again.
Edit: On newer models the press points are different: Sabbath mode is turned ON and OFF by pressing and
holding "Control Lock and Power on/off buttons" for five seconds...
Hope this helps.
Oct 11, 2017 | The Computers & Internet
My stove went to "sab" mode after power outage. Technician came over and review manual and couldn't fix it!
You need to refer to the manual of the model that has Sabbath mode and apply that to yours even though it doesn't have it. you are setting the controller not the wires that make Sabbath mode operate.
Apr 01, 2016 | Kitchen Ranges
What does SABB mean on ge french door refrigerator
Sabbath mode someone pushed some buttons and caused this or touch panel shorting. Need to read owners manual to clear
Jun 20, 2015 | GE Refrigerators
My frigidaire gallery refrigerator model number DGUS2645LF3 is showing an error code "5b" and nothing inside works.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are in the Sabbath Mode.
The Sabbath Mode is a feature that disables portions of the refrigerator and its controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community.
Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds. The display shows "Sb" while in Sabbath mode.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, for example due to a door left ajar, the alarm will sound intermittently for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
If this does not solve the problem you have a bad control board.
Sep 02, 2014 | Frigidaire Refrigerators
STUCK in Sabbath mode.
What is the complete model number of the unit?
Dec 10, 2012 | Jenn-Air Kitchen Ranges
My maytag gemini oven has been stuck in sabbath mode for months and holding the clock button does not help. It does this everytime we lose power and it stays off for months and will turn on when ever it...
This is from the Maytag website it explains how to cancel the sabbath mode;
To cancel the Sabbath Mode:
Press the Clock pad for three seconds.
Or
After 72 hours, the Sabbath Mode will end.
  • "SAb" will flash for five seconds.
  • The time of day will return to the display.
NOTES:
  • Sabbath Mode can be turned on at any time with or without the oven on.
  • Sabbath Mode cannot be turned on if the keypads are locked out or when the door is locked.
  • Most prompts and messages and all beeps are deactivated when Sabbath Mode is active.
  • If the oven is baking when Sabbath Mode is set, the Bake icon will go out at the end of the baking cycle. There will be no audible beeps.
  • If the oven light is desired while in Sabbath Mode, it must be turned on before the Sabbath Mode is started.
  • When the Sabbath Mode is started, the temperature display will immediately show the set temperature, rather than the actual oven cavity temperature. No preheat beep will sound.
  • The self-clean cycle and automatic door lock do not operate during the Sabbath Mode.
  • Pressing the Cancel pad will cancel a Bake cycle, however the control will stay in the Sabbath Mode.
  • If power fails, the oven will power up in Sabbath Mode with 72 hours remaining and no cycle active.
I hope this helps to return it to normal mode,
GENE
Oct 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
What does 5ab mean on the oven?
Some ranges with a lot of features have a Sabbath mode, hence the letters Sab in the display although it looks like 5ab. Check your owners manual and it should tell you how to turn off the Sabbath mode. If you don't have a manual Google your model number and Sabbath mode.
Aug 28, 2011 | Ovens
HOW DO YOU GET THE STOVE OFF SABBATH
Sabbath Mode is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. Usually this disables the oven, but allows the consumer to still use the surface burners. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
Somewhere in the owner/operator's manual is a section that refers to "Sabbath Mode". Since all ranges differ in features, you need to refer to the operation section of your owner's manual to find out how to shut the feature off.
If the model number you listed this question under is correct the instructions for Sabbath mode are listed on page 13 of your owner's manual. To cancel Sabbath Mode you press and hold the CLOCK button for 5 seconds.
If you can't find this information, or no longer have an owner's manual, you can download or print a copy for FREE at managemylife.com. Just enter your model number under the "Manuals" link and you will find it listed in .pdf (Adobe) format. If you have questions, please post back with your MODEL NUMBER (if different from the one you have listed) and let me know. I hope this helps you.
Apr 14, 2010 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
