Question about Dryers
Amana Dryer won't start
I've got an old Amana dryer (17-18 years old) that had been working just fine until a couple days ago.
When I push in the timer knob to start, it makes a buzzing sound and won't start. Sometimes I can repeat that and it will buzz and then "catch" and start working. Other times it will just stop buzzing and nothing happens other than the clicking of the timer.
Don't know the model number but it is old. The timer knob is on the left instead of the right like you normally see with Amana's today and the right side has button to select permanent press etc.
I'm guessing its either a thermostat / temperature fuse issue or a timer issue. Is there any easy way to figure out which?
  • markferg Aug 14, 2008
    The buzz is identical to the buzz indicating that the drying cycle is over and it is time to take out the clothes, though not quite as loud.
  • 706 Answers
Depending on your interpretation of the 'buzzing' sound compared to mine, I'd say it may be a relay chattering or the motor trying to start up but the windings are beginning to fail. You may want to clean the motor housing from dust etc and make sure that you do that with the power disconnected. Also: with no clothes in teh dryer..try rotating it around and feel for any spots in that rotation that may be binding.. if the drum has excessive restriction while rotating.. the motor may not have enough torque to overcome that and just buzz,,, Hope that helps...
Posted on Aug 14, 2008
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
Dryer won't turn over/start. When push start switch makes noise but won't turn. If hold door closed switch and turn manually while pushing start button it would work for awhile, but that has...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 05, 2011 | Amana Dryers
Fisher Paykel Dryer Model DE08-US1. Dryer won't start. When pushing the start button, there is a "humm" from the electric motor - like it's trying to start. Very sudden problem. ...
heatman101
Jul 18, 2011 | Fisher and Paykel DEGX1 Electric Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
Kenmore 90 series dryer. Was working fine three days ago, now it won't start when you set the timer and push the button to start. Is ther a reset button or something? Checked breaker at electric panel...
heatman101
Jun 30, 2011 | Kenmore Dryers
Hello, My dryer was working fine a few days ago and just yesterday it stopped working. I pressed the stop button and there was no power. the Filter connecting the dryer to the wall is not blocked with...
heatman101
Jun 14, 2011 | Amana NED5100TQ Dryer
I have a GE front loading dryer model # DBVH512EF0WW. It's about 1 1/2 to 2 years old. It has worked perfectly up until this point. When we push the start button, it just beeps twice, but does not...
heatman101
Jun 13, 2011 | GE DCVH515GF Gas Dryer
I have an similar problem with my Amana Dryer LEA30AW.
First Clean out your filter, Assuming the element is okay and cut-out are fine it should run okay, you could also try running it on low heat will take a bit longer but hey if it works great..Good luck
Oct 01, 2009 | Dryers
I have an old whirlpoos elec. dryer whilch worked
it could be a broken drum drive belt, or a bad motor or motor start capacitor
Sep 18, 2009 | Whirlpool GEW9250P Electric Dryer
Dryers Logo
343 people viewed this question
Top Dryers Experts
