Question about Sony Playstation 3 (PS3) Console
Since getting TW Masters my bluetooth wireless mic is not working and when i try to register it..it just keeps scanning?
  • glennandme2 May 19, 2011
    It is playstation brand and the model is i am not sure on the bottom it says sn 930075278 - is that what you need?
    It is made by Sony i let me know is there is somewhere else I can check. There are no other numbers on the base that I can see or in the infromation sheet
  • 794 Answers
Hi glennandme2,
May I have the model and brand of your Bluetooth device?
Thank you for using FixYa.
Posted on May 18, 2011
  • Jemalyn Labaguis May 19, 2011
    Thank you for the information. If your Bluetooth device is just being scanned and can't be registered try this: press the scan button and also turn on the Bluetooth headset on at the same time.You have to continue to hold the power button on the Bluetooth headset and the scan button in about a minute or two it should detect it and will ask for a pass code which is "0000" and press Enter then it should work.
    Hope it helps.
I try to connect my Bluetooth PS3 Headset and the error code 80010009 keeps showing up and won't let connect and talk online.
Just a question do you have it paired with a cell phone as well? If you do when you turn it on it may be pairing with the phone first and not with the playstation this happened to me and I could not figure it out for 5 minutes.
Ok,Delete the mic from your console and then connect the mic to your console using the charging cable. Open up the door on the top of the mic. It will register everything automatically.
Also you can delete the Bluetooth device what is on your list then turn off your ps3 turn it back on and then register your device again...
Hope it helped..
Aug 09, 2011 | Video Game Consoles & Games
Cant pair ps3 wireless headset
sometimes it is easier just to watch a video!
Here ya go. please remember to leave me a positive rating and a testimonial really helps!!
thank you!
1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions (1.0, 1.1, 1.2). 2009 may see version 2.1 Bluetooth headsets hit the market, so you will have to try it for yourself on PS3.
  • All brands of Bluetooth headset should work with the PS3.
USB:
USB (wired) Headsets can also be used with the PS3.
  • Any of the PS2 compatible USB headsets should work with PS3 games.
  • USB headsets are required for PS2 software used on the PS3.
Not Compatible with Bluetooth Stereo Headphones:
  • The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
  • If you want to listen to the gameplay with headphones then they will have to be compatible with your TV or stereo receiver.
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 3. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
  • Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
  • Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works.
3. Troubleshooting
General:
If you are having trouble with a headset after it is paired with the PS3, there are a few things to check first:
  • Make sure your headset battery is charged and working. Be aware that some brands/models will need to be paired again after each recharge. It's not a problem, it's just the way those models work.
  • Make sure your controller is charged. Lots of strange things happen when the controllers don't have enough power, like dropouts and headset interference.
  • The headset should be set as the input/output device from the XMB.
  • For Bluetooth users, make sure there are no other Bluetooth devices in use near your PS3. Also try to eliminate any other radio frequency interference if possible.
  • For USB users, make sure the connection is secure and there are no wire breaks.
  • Update your console to the current available firmware.
Pairing Problems:
  • If the PS3 cannot locate your headset, make sure that your headset is in pairing mode before you start scanning. The headset instructions will tell you how to set yours to pairing mode.
  • If your headset is missing from the device menu after you re-start your PS3, you will have to pair again. Many headsets will only "remember" one device at a time, so you may have to register again after using your headset with a phone.
  • If your headset appears on the Audio Device menu but is "grayed out" or not selectable, it is not connected. Make sure the headset is charged, and that it is on in standby. I should connect automatically when the Audio Device menu is selected. Tap the call button on the headset if it does not connect, or click on the Connect Bluetooth tab on screen.
  • Make sure no other Bluetooth devices are in use nearby.
Voice Chat Drops:
  • Most in-game voice chat drops are simply network lag. Usually they go away after a short time, so be patient. In extreme cases you may have to leave a game and return to reset the chat function.
  • If you use wireless internet, a low signal strength to your modem/router can make voice chat malfunction. Make sure your wireless signal is as strong as possible to your access point.
  • Sometimes a headset will quit after changing discs to another game. Go to accessories and select your headset again.
4. Playstation 3 Links and Customer Support:
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
How can i attach a bluetooth to ps3 plz help
Hello my friend this should help you out.
please remember to leave a positive rating for me and a testimonial if I helped you out!
Bluetooth:
USB:
2. Setup
and here's a video in case you are a visual learner.
Mar 26, 2010 | Sony Video Game Consoles & Games
Trying to hook my bluetooth headset to my playstation three what do i need to do
Bluetooth Headset Setup
In Game XMB:
All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
For more help you can try these links:
Video Walkthrough (thanks jonny k)- http://www.youtube.com/watch?v=8tSItLGLsX8
Playstation 3 Users Guide- http://manuals.playstation.net/document/en/ps3/current/index.html
Feb 06, 2010 | Samsung WEP460 Bluetooth Headset
How do you turn the bluetooth on on a ps3 cause i cant get my bluetooth headset to pair
Turn on your Playstation 3, and from the main menu go to Settings - Accessory Settings - Register Bluetooth Device
You will be presented with two options:
Register BD Remote Control
Register Headset/Microphone/Headphones
Select Register Headset... and put your Bluetooth headset into pairing mode. On your PS3 select Start Scanning
Select your device and enter your pairing code. In most cases for audio devices the default pairing code is "0000"
Now on your PS3, go to Audio Device Settings and change your "Input Device" and "Output Device" to your Bluetooth headset name. Try speaking and watch your "Mic Level" move!
This might help you as well:)
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=898874
Dec 22, 2009 | Sony PlayStation® 3 (80GB) Console
Ps3 headset wont work
my sony wireless headset wont register please help
Dec 20, 2008 | Mad Catz PS3 Bluetooth® Headset Wireless...
Ps3 bluetooth connection
I think you are mixing up two different technologies. You said you have recently bought a Wireless Router and when you try scanning for Bluetooth devices you can't find it?
First of all, Bluetooth isn't Wi-Fi. You should go to Network Settings under Settings in the XMB and choose for a Wireless Connection and then let it scan.
Be sure you don't have a 40 GB PlayStation 3 since they don't have Wi-Fi.
I hope this helps. Please rate.
Greetings,
DarkNeogen.
Feb 10, 2008 | Sony Playstation 3 (PS3) Console
Using Motorola Blue Tooth with PS3
Yes you can. Just go to accessories or audio device settings. Have your headset on and hit connect bluetooth device. The key it asks for should be 0000. If that doesn't work do a quick search online and you should be able to find one that works.
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Connecting bluetooth headset to ps3
You have to do 2 things in order to use a bluetooth headset on your ps3. First you have to pair it with the ps3. To do this you go to your setting and register the bluetooth device. Make sure your bluetooth device is in pairing mode when you do this. On most headsets you can simply hold down the button until the light comes on a solid color. once it is in pairing mode you will have to scan for new devices. Once this is done you should see the headset on the list. Choose it and enter your pairing code. If you have not set one it will most likely be 0000. Once it is it paired you will have to change your audio output and input. Go to audio device settings and change the input and output device to your headset name. Enjoy!
Sep 25, 2007 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
