Question about Buffalo Technology (HD-PE320U2/WH) 320 GB USB 2.0 Hard Drive
My external hard drive (buffalo HD-PE320U2) is not working. when I plug it on the computer it says "windows does not recognize it" or it has malfunction. what will I do with it?please help I really need the files inside.Thanks
    Sergeant:
  • 281 Answers
First uninstall the software,make sure the external hard drive is not connected to the PC and use your install disk to reinstall the software.You might all so try system restore.Thank you for choosing FixYa.com.
Posted on May 18, 2011
Need to format my portable HD (Buffalo 3.5 500GB Mini-station) before using as External HDD for my TV (LG 42LA6200)?
BUFFALO TOOLS Buffalo Tools is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.
Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Only basic external hard drive functionality is supported with this operating system; some included utilities may not work. The HDD default format is NTFS; to work with Mac, reformat the HDD using Mac Disk Utility.
I would plug it into a windows 7 or Vista and the computer's USB. The computer should recognize it. Click start then computer and find the icon for your drive and right click your Icon. In the drop-down window look for 'format' and that should help you format your drive. is a feature-rich suite of optional software included on many Buffalo Drive-Station and Mini Station storage products. Any or all of the following components of Buffalo Tools may be installed on Windows PCs.Buffalo's Backup Utility is an easy-to-use and fully featured backup software for Windows PCs and can be used to back up one or multiple computers with a single Buffalo external hard drive.ECO Manager is an energy efficiency tool used to conserve energy and reduce battery consumption by regulating the power usage of the hard drive, cutting power to the drive during extended periods of inactivity.RAMDISK is a simple utility that allows you to create a RAM disk on your Windows PC which creates a small, but extremely fast environment to work on files in.SecureLock software for Windows provides complete control of the data encryption on your Buffalo external hard drive, providing password protection and software data encryption.
Oct 21, 2013 | LG 42" 6200 Series LED HDTV - 42LA6200
Driver for HD-PNTU3
This drive showing as not supported for Linux as you mentioned.
Usually this is due to the board inside the enclosure.
You could crack open the case and mount the drive internally which would resolve this issue.
Otherwise you are down to trying to find a driver (not made for this model) that will be recognized by your system.
regards,
Mike
Sep 25, 2012 | Buffalo Technology Buffalo - Hdpnt500u3s -...
My external hard drive (BUFFALO HD-PE320U2) is not working. When I plug it on the computer "safely remove hardware button" display on taskbar but no partition display on My Computer. What will...
For that you need change some registry keys and delete upper and lower filter with below method. First make sure usb cable connected to harddrive is working fine. Try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Sep 07, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
My external hard drive fell down twice on a carpeted floor. Now, I cannot open it with whatever USB cable I use. The computer can recognize the device, but it cannot read the files in it when I access it...
If the drive can be recognized by the cmos there is hope. Remove the drive from the case and plug it in directly to your computer. It should be recognized by the cmos and should be accepted as a secondary drive when your master drive boots up. Then use windows explorer to get into the drive and transfer the files out of it. Remember that if this works for you the issue might just be with the case electronics. If drive is recognized but you cannot see the files, you can get recovery freeware on the web to do the deed.
Sep 09, 2017 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
My buffalo external hard disk can not read since yesterday, I/O device error. previoous was working fine. Do not know why? my Buffalo external hard disk model :HD-PX320U2
it is a PNP (PlugNplay) device. Try using a different cable to connect to your pc. Should the problem remain, hook it up to a different computer and if it doesn't see the drive, it will be an electronic circuit failure inside the box. The data is still on the hhd but you will have to obtain a new circuit to bring the hhd back online for use.
Apr 13, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
Every time I connect my Buffalo Hard disk (HD-PE320U2) and try copying data it shows IO device error. I don't know what to do! help me. Formatting did not help!!!!
That error signals the fact that the motherboard can't communicate properly with the controller of the disk. It's a hardware fault and it's unfixable - this disk is dead, replace it.
Feb 07, 2011 | Buffalo Technology (HD-PE320U2/WH) 320 GB...
Computer not accessing Buffalo HD
my Buffalo external hard disc can be detected by laptop, but my access is denied. When i click on the hard disc icon, it popped out a message box prompting me to reformat my hard disc. Is there any other way to retrieve my files before reformat or
is there any other way to recover my files after reformat?
Is there any other way to troubleshoot my hard disc other than reformatting it?
Please help me, I am desperate to recover all my files because they are too important/precious to lose it.
May 11, 2009 | Buffalo Technology (USA), INC. - 500GB...
Buffalo Technology (HD-PE320U2/WH) 320 GB USB 2.0 Hard Drive Logo
582 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
