Question about Trinity Keyless Biometric Fingerprint Door Lock Adel 788
I have the Trinity 788, when I put my finger on it, it beeps and makes the sound of unlocking, but handle just turns without turning lock mechanism. What have I done wrong
    New Friend:
    Problem Solver:
  • 5 Answers
Most likely, the center shaft between the 2 lock parts are not aligned properly.Uninstall the lock, check the center shaft cradle on the enrollment side of the lock to be sure the top and bottom points are properly aligned.They should point at each other.
Reinstall the lock and test.
Adel Biometric Keyless Fingerprint Door Lock Trinity 788
Posted on Apr 25, 2015
  • 963 Answers
Trinity Keyless Biometric lock:
I can't answer your question directly, but I can steer you to their website, which includes a support phone number that you can call, as well as links to Customer support and Frequently Asked Questions:
http://www.axxisbiometrics.com/products/locks/latch-style/trinity788/
I'm sure they can answer your questions. Good luck!
Posted on May 18, 2011
The red padlock icon that usually unlocks with the 5 second touch of a finger won't unlock the cooktop.
Have you tried disconnecting the whole cooktop from the main supply for about 5 minutes? Sometimes when reconnected the fault goes away.
Nov 28, 2015 | Cooktops
Key loose / does not stick in ignition slot
Diagnosis: Basically, the ignition slot thinks the key is in so the lock mechanism is in place, which prevents the key fob from going in all the way.
Solution: Insert your finger all the way into the slot. Curl your finger slightly so that the tip touches the bottom. Pull your finger out slowly and your finger will "unlock" the mechanism. You will hear a click sound and also feel it being unlocked. Try inserting your key fob into the slot.
May 26, 2013 | 2009 Audi A4
Put joystick into lock mode
press and hold on button til beep then push and hold joystick til beep then pull and hold joystick til beep turn off then on should be unlocked now
Oct 04, 2012 | Invacare Supply Group Invacare Pronto M91...
I have a Adel Trinity 788 biometric fingerprint handle that I need to install. I lost the screws and I am trying to find the 3 long bolts that connect the 2 halves together. Does anyone know where to...
Apr 10, 2011 | Trinity Keyless Biometric Fingerprint Door...
What if the power is shut down?it is still work?
Feb 21, 2011 | Trinity Keyless Biometric Fingerprint Door...
I have a Trinity Keyless Biometric Ringerprint Door Lock Adel 788. The scanner reads my fingerprint but the internal lock/unlock won't operate. I already tried resetting the lock to factory out of the...
This is the website for Axxis Biometrics, the manufacturer:
There is a phone number and email address which you can use to contact them for technical support.
Feb 14, 2011 | Trinity Keyless Biometric Fingerprint Door...
Red ligth is on all the time and not sound or open the door?
Jan 17, 2011 | Trinity Keyless Biometric Fingerprint Door...
The lock only has two redlined but beeps when put in batteries
Try putting the batteries in backwards for a second, then reinstall the correct way..good luck
Sep 20, 2010 | Trinity Keyless Biometric Fingerprint Door...
How to replace a door handle on a 2006 hyundai sonata, i either broke the handle and need to replace it or I am trying to figure out how to fix the drivers side handle
Step1: First, unscrew the 7 screws holding on the door panel
Step2: Next you carefully pry off the tweeter cover that is where the mirror is.Lift the panel up and off of the door . Undo all of the wiring connections except for the window controller.
Step3: Open the 2 black rubber view ports (Circled in Yellow) and roll the window up or down until you see the 10mm bolts that hold the window in place.
Step4: Loosen, but don’t remove these bolts. Slide the window up, and tape it up, or remove the window and set aside. Next, unplug the door lock plug and move the door panel out of the way.Unscrew the gold 10mm bolts that hold on the metal inner door panel . Also remove the Phillips screw that holds the inner door handle on
Step5: Unscrew the small bolt that holds on the lock cylinder that is behind the quarter-sized black cap on the side of the door. Be careful with that little bolt or it will fall into never land .Pull the lock cylinder out and set aside.
Step6: Now grasp the door handle, and with your free hand smack your hand holding the handle towards the back of the car. This will release the door handle.Under the door handle is a Phillips screw. Loosen this screw a few turns but don’t remove.
Step7: Now undo the 3 black star shaped screws on the door lock.You can now wiggle the inside of the door handle until it comes free. See the tabs that hold it onto the door . When you go to put it back on be sure the tabs get back in the right place.Pull the whole inner door panel and lock mechanism free by wiggling it out of where it sits.
Step8: Now you can undo the 3 cables; 1 from the outer door handle yellow mechanism, 1 from the inner door handle mechanism, and 1 from the inner door lock lever.Put on the new lock and put it all back together. Be sure to test it as you go. I had to turn the lock cable to the inner door lock lever 180 degrees because it was not unlocking properly when I put it back together the first time.
A couple of other notes, there are 2 pieces of plastic that are for the robots to use when putting the door together for the first time. one is a 3 pronged white plastic thing riveted to the inside of the metal door panel. The other is a white plastic thing covering the lock mechanism. You can cut off the fingers and throw the plastic cover away they are both useless and in the way.When you put it all back together, just go in the opposite order of disassembly. It is a little tricky to get the yellow plastic outer door handle holder into place. Be sure that the little tabs grab the metal of the door or things will not fit together properly.Be sure to test the power window after you put the window back in place. Do not overtighten the bolts on the window, it is glass…..
Apr 08, 2010 | 2006 Hyundai Sonata
My Adel Trinity 788 fails when read my (master) fingerprint (red light - two beeps). I already tryed to reset to factory defalts, pushing the 2 buttons (holding), removing a battery, then put the battery...
according to what he says:
if your lock does not recognize its master finger ud.hizo an attempt to reset and apparently not properly reset as initially ud. must press the two buttons at once not stop pushing, in followed remove a stack, reinstall again the battery immediately is oira one beep should expect from five to seven seconds is oira a different sound until that moment is reset your veneer and is at that very moment that are left of pressing the buttons.
then begins the process of adding tracks
http://www.segurilex.com
Feb 22, 2010 | Trinity Keyless Biometric Fingerprint Door...
Trinity Keyless Biometric Fingerprint Door Lock Adel 788 Logo
368 people viewed this question
Top Trinity Locks & Locksmithing Experts
ray gallant
Are you a Trinity Lock and Locksmithing Expert? Answer questions, earn points and help others
