Question about KitchenAid Refrigerators
Water is collecting at the bottom of the refrigerator,under the food crisper drawer
  • 1 more comment
  • jfm10mann May 18, 2011
    I wonder when you mention defrost if you then mean I should be looking in the freezer (located at top of frig). The one drain line I found in the refrig is located at the top center back area. Please confirm.
    Thank You.
    this sounds like an easy solution but given all the water that has collected at the bottom of the fridge (even if I sponge it up) will I risk having water overflowing unto my hardwood floor?
  • jfm10mann May 19, 2011
    I can not defrost the refrige right now because of all the food I have inside. There is no ice build up on the walls and there is no mold. Would a shorter period work such as 12 hours?
  • KitchenAid Master
  • 19,396 Answers
Hi.
There is a drain hole inside the fridge. The drain hole brings water out toward the evaporator. The drain hole is plugged, probably because of iced water inside the thin drain duct.
Check inside the fridge and locate the drain hole at the back. Usually the hole can be unclogged performing a complete defrost. A faster way is using an hairdryer. In that case the operation needs attention. Hairdryer on cold settings does not defrost in deep inside the hole. On hot you risk to damage the fridge panels. Better removing the food and performing defrost.
If defrost is not enough the drain hole must be unblocked using a thin flexible shaft or a copper wire.
If you have an US or Canada model you can find exploded view using the link below.
Parts sellers.
Posted on May 18, 2011
  • 1 more comment
  • Ginko
    Ginko May 18, 2011
    If water is in the fresh food section forget about the freezer. Check inside the fridge, there is a hole of about a couple of mm. That leads water outside.
    The hole is clogged inside. You need to "defrost" the unit because you need to get rid of the water inside the drain tube.
    All you need to do is removing food and turning fridge off for 24 hours.
  • Ginko
    Ginko May 18, 2011
    Hi.
    If there is no ice formation on the walls of fridge compartment you will not get much extra water. The water in the drain hose is a very small amount, and will drop out at the back of the fridge while you do defrost.
    If the water that you have at the bottom is from condensation, it will be no more than one cup or so. That cup has condensed in hours. When you stop the fridge, the water will stop condensing, ice in the drain will melt allowing few centiliters of ice becoming water and unblocking the drain. If fridge is not moldy or very dirty, there is no need for a flexible shaft to free the drain.
  • Ginko
    Ginko May 19, 2011
    Hi.
    If you want to fix the problem, you need to get rid of the ice or leave with the water problem for few more weeks and program doing a defrost in the longer term.
There is water collecting continuously at the bottom of my fridge under the crispers. Do you know how I can fix?
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Jan 03, 2015 | Refrigerators
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Water collecting in bottom of fridge
Good Afternoon Friend,
I understand that you are receiving water at the bottom of your Frigidaire refrigerator, model# FPUI2188LF. What can cause this is either humidity coming from outside your refrigerator or maybe from the crisper drawers. Make sure your crisper drawers are set for a high humidity. Another thing that can cause moisture build-up at the bottom of your appliance is not covering your foods. Make sure that all foods and drinks are covered to cut down on moisture floating around inside your appliance. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Fpui2188lf 21 Cf Top Mount...
Water in crisper drawer of Whirlpool model number ET18TK
the water in the bottom of the fridge will be from condensate running down the back wall and not collecting in the drain ridge to flow outside to the dish on top of the compressor. It comes from overloading the fridge by opening the door too often and excess food trying to cool down. check and unplug any blockages in the drain and pull any containers away from the back wall as water will flow off the wall onto them and miss the drain all together. The drain ridge will be under 1/2 way down the back
Dec 25, 2013 | Cars & Trucks
Frigidaire Gallery, model GLRT183TDW0 Water is leaking underneath, and water is collecting in the bottom under the crisper drawers
Is there a drain hole under the crsper drawers if so see if it is pluged. And leting water to drain to the drain pan under the frig. I hope this will help. Jim
Oct 27, 2010 | Frigidaire Refrigerators
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Water standing under crisper drawers
small drain hole/tube inside (behind crisper pans) is stopped up. Clean out with flexible wire, etc.
Jun 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator has water under the crisper drawers
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
Jun 19, 2009 | Refrigerators
Water collecting under crisper drawers.
When the refrigerator goes into defrost mode there is a drain tube that allows water melted off the evaporator coil to go into the drain pan that you found empty. That drain tube is clogged.
May 02, 2017 | Whirlpool ET1MHKXM Top Freezer...
Refrigerators Logo
107 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
