Question about Hayward 250kbtu Ng Pool Heater - Inground
H350 FDN heater wont come off of standby mode. No error code. heater is <4 yrs old and recently replaced the keypad and display board and it worked fine for a couple of months.
thepool
  • 78 Answers
SOURCE: the temperature buttons on my hayward 400IDL
You most likely need a new touch pad and they are almost impossible to troubleshoot. If everything else works except "button A" then button A is bad and in this case that means the whole thing is bad. Sorry...
Posted on Apr 23, 2010
SOURCE: "LO" error code on new H400FDN heater
it is low water pressure sensed, unit will not start unless pump is working
Posted on Jun 07, 2009
  • 139 Answers
SOURCE: have pilot light lit but unit willnot come on hayward h350 heater
check millivolt output,if it is in normal range(400-600)check for continuity on pressure switch,flame rollout and high limits.
Posted on Jun 22, 2009
thepool
  • 78 Answers
SOURCE: Pool Heater with communication (CE) Error
Code "CE" stands for communication error and describes a fault between the mother board and the display. I doubt it's the relay causing it though...
StepehnD
  • 78 Answers
SOURCE: I'm receiving an error code CE on my Hayward H
Open up the control panel access door on the front. (the display). Remove the 2 screws at the top and tilt the assembly out. There should be a tab on the bottom that helps keep the assembly stable. Check all the connections on both boards for fit and broken wires. If all is ok, I would shut the supply power off, then back on and see if the data transfer works. If not, bad boards.
Posted on Jul 25, 2010
Testimonial: "Great advice. Working like a charm. No loose wiring. 2 large beetles between the circuit board and the display. Blew them out and it works great."
Hayward heat display is stuck in standby
you need to replace either the display board or the main circ board
Aug 28, 2014 | Hayward H Series Millivolt 250,000 Btu...
Kitchenaid Ykers807ss00 error display f2e0
this is the procedure for this code,
F2
Keypad
E0
E1
STUCK KEY (shorted key)
KEYPAD DISCONNECT or KEYPAD DISCONNECTED
PROCEDURE: Before proceeding, perform steps 1 through 3 above chart to enter the
Diagnostics mode.
A. Unplug range or disconnect power.
B. Check that the keypad is firmly connected.
C. Plug in range or reconnect power.
D. Observe for longer than 1 minute.
E. If error remains then go to step F.
F. Unplug range or disconnect power.
G. Replace keypad.
H. Plug in range or reconnect power.
I. Observe for longer than 1 minute.
J. If error remains then go to step K.
K. Unplug range or disconnect power.
L. Replace display board.
M. Plug in range or reconnect power.
Here is the board to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 10, 2013 | Kitchen Ranges
Hayward H400FD. Can't adjust temperature.
need new display board also check if connected to a system disconnect and try alone
Jan 28, 2012 | Hayward H400FDN Low NOx Natural Gas Pool...
Hayward h series heater was working fine earlier this summer but just recently when we try to turn it on it won't allow us to change the mode from Standby to anything else. The display does not show...
Your unit likely needs the control bezel assembly replaced. It includes the control pad and the circuit board it attaches to. We currenly have one in stock for $229.60 + shipping (and tax if shipped to a Michigan address). If you would like to order it please contoact us thru www.arrowpools.net.
John
Aug 05, 2011 | Hayward H Series Electronic Ignition...
I have a pf error on my hayward 400 fdn 2 yr old heater. also it's wired 240 volt ac
Thank you for posting your question here on Fixya.com.
A 'PF' error code for a Hayward heater is an electrical supply wiring error. This code will display if 120V polarity is reversed, low voltage is detected, or if the ground path is not sufficient. Reset is immediate after error is corrected. If you are feeding it 240 it can mean one of the 120 legs is low or open or the grounding is bad. It could even be an issue with the transformer or the control board but it is far more likely an electrical supply problem. Start with measuring the incoming line voltage with a good meter. You should see 240 line-to-line and 120 line-to-ground on each leg. If the reading is off by 10% or more there is an issue to correct. If not check the ground next.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Mar 24, 2011 | Hayward 400FDP Universal Series Low Nox...
Error message "Number FDN restricted"
I can receive the call from outsider but wont be able to make call to outsider. When I trying to dial out to somebody it says "number FDN restricted" Please help.
Jun 14, 2010 | Samsung SGH-t219 Cellular Phone
How to off the FDN mode of my cellphone
i have a sumsung sgh-s730m and to turn off the fdn i opened the phone to the key pad them hit the little button with the three lines on the actual phone went into settings and turned off the fdn fixed diailing numbers by clicking on managing it and then entered my pin2 number and disabled it hope it helps
May 07, 2010 | Samsung SGH-E251 Mobile Phone - Black
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
Hayward 250kbtu Ng Pool Heater - Inground Logo
117 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
