Question about Panasonic Cameras
MiniDV camcorder ; does not show on TV to playback hookup by COax cable to input ports. GS12 20x
I DID NOT find a solution; but I did find that you charge entirely too much for a
service that may or may not help me. I have tried online tech support before and I
got lost in the shuffle because people want to talk to me as if I am computer savy.
Posted on Aug 15, 2008
I'm using a coax cable from symphonic vr-701 to tv and trying to record. it acts like it is recording but just shows snowy image on playback
Coax from wall to coax in on VCR and Vcr Coax out to in on set.
Whatever channel vcr is on this way it will record and pass to set.
Check first you have playback from VCR to TV alone, could have dirty or blocked video heads which in record will just record no watchable picture. Hookup or blocked video heads are most likely.
Dec 13, 2012 | Symphonic Televison & Video
Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
  • Tune the CABLE BOX to the channel you want to record.
  • Tune the TV to the VIDEO INPUT you have the VCR connected to.
  • Select either VCR or DVR on the VCR.
  • Select recording mode.
  • Press the INPUT SELECT button.
  • Select IN 1.
  • Press RECORD.
Hope this has been helpful....
Good Luck....
Jan 19, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Canon Elura 65 Camcorder USB input?
I tried to look over the camera for 20 minues and could not find any slot to put the USB cable in. I looked over the camera just one last time before giving up and and i found a little pull tab on the front of the camera. I pulled the tab and it opened showing a circular insert (for hookup to a TV) and a USB slot!
Sep 07, 2009 | Canon Elura 65 Mini DV Digital Camcorder
My 42 inch sylvania plasma tv does not have a coax connection, so how do i hook up my cable to the audio/video connection? i know there is an rf converter to transfer audio/video to coax but i really...
Since your TV only has audio and video input jacks, you can connect those to audio and video output jacks on the VCR. Now connect the coax cable to the RF/ant input on the VCR and you'll have to change channels by using the VCR channel selector.
Let me know if you require further assistance.
Aug 08, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
HDTV Converter hookup with sat. and antenna
Hi there Phil...... this switch from analog to digital has lots of folks scratching their heads. Fortunately I have some great news for you. The signal coming from the Dish network does not need a converter as it is already digital.
May 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
New TV hookup
You should have no problem with this. I have provided a picture of your model below for clarification. One end of the coax will attach to the 3-4 OUT on the back of the receiver and the other end will go to the NEW tv's coax input. If your set has two coax inputs you may have to select the port that you connect to in the menu portion of the tv. If the new tv does not have a coax input you can use RCA jacks which are red/white and yellow and connect those to the TV 1 output on the back of the receiver and the other end to one of the inputs on the back of the tv- this will require you to select the input source you connect to again e.g AUDIO 1, AUDIO2 etc. If you have a VCR run the coax from the 3-4 on the back of the receiver to the antenna inon the back of the VCR -usually the top port, then run another coax from the output- bottom port to the coax input on your tv. I hope I have been of some assistance to you and Thanks for using Fix Ya. If I can assist you further please let me know.
Apr 06, 2008 | DISH Network DVR-625 DTV Receiver /...
Magnavox MWR10D6 can't record from camcorder wrong channel
OK...try this...plug your RCA cables from your camcorder into the RCA input jacks on the back of the recorder. If you have a VCR, it can be plugged into the coax input on the back of the recorder. Use the coax output and plug it into a RF modulator (about $20 at Wal Mart). Plug the RCA output cables from the recorder into the RF modulator as well (Don't ask me why, but it seems to work on mine). Connect a coax cable from the RF modulator to the TV. Make sure the TV and Recorder are both on the right channel. The RF modulator will have a channel switch to use channel 3 or 4 on the TV. Make sure the recorder is set to E1 (Rear). You can check this with the channel +/- buttons on the bottom right of the remote. Good luck.
Jan 06, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Cameras Logo
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
