Question about Whirlpool Refrigerators
The defrost won't cut in - Whirlpool Refrigerators
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 20, 2011
'99 olsmobile heating and ac
You have a problem most likely with the air temerature control blend door actyautor or the door is jammed or in most cases both. Repair requires the dash to be removed so have it properly diagnosed as the repair is well over $1000.00
May 07, 2013 | Cars & Trucks
During heat cycle the entire heat pump frosts up and won't go into defrost cycle.
some unit you need to jump the defrost tstat also.then it would be the control
Nov 26, 2012 | Refrigerators
2008 impala got in this evening and ac won't turn
Someone will need to check the fuse for the blower, then the blower motor and the resistor.
Aug 09, 2012 | Cars & Trucks
My kenmore side by side icemaker quit working after a power outage. Is there a reset button? The tray has ice but it won't cut or dispense the ice
If you are having a problem with your Kenmore refrigerator's automatic defrost feature, it can lead to issues with the appliance's performance. The Kenmore self-defrost system works similarly to that of other refrigerator brands and it has similar components that can potentially malfunction and cause the entire system to fail. While you can still manually defrost your Kenmore by opening the doors and unplugging the unit for several hours, it is inconvenient and messy to clean up. Your best bet it to find the issue and repair it.
Jul 27, 2012 | Refrigerators
My ac or heat won't work
For the a/c, you may be out of refrigerant, and need it to be refilled.
For the heat part, it is most likely one of the following things: low coolant, thermostat, heater core, or maybe even radiator malfunctioning.
If you need some diagnostic tools to test the A/C, I recommend the actia multi-diag.
Jul 15, 2012 | 2003 Mercury Grand Marquis
My true freezer won't defrost?
Check the defrost timer (in the base, circular knob you can turn till it clicks) If it doesn't heat up rapidly in the evaporator, there is a safety overheat device (thermistor) that may be cutting power to the heater, or there may be a fault with the heater itself. Are you sure the fans are working, and the condenser grill is nice and clean?
May 14, 2012 | True 72 cu. ft. / 2039 liter Commercial...
Help, i turned by Bosch Logixx GSL 14424 GB freezer off to defrost and it now won't turn on...
Turn it round and check the electrics for the compressor are dry. You probably flooded them when defrosting and may have shorted something. If it still won't start with everything dried out, call a fridge technician
May 02, 2012 | Freezers
Kenmore side by side freezer not cold and there is frost on back of freezer wall
you have a defrost problem,it's not going into defrost,bad defrost heater,defrost thermostat,timer or board depending on what model you have.next time send the model number,it should be in the fridge section,on the right hand wall up near the ceiling.first thing if it has a timer advance it into defrost by turning it with a screw driver or if it has a board remove the bottom kickplate and look for the tech sheet,it will tell you how to put it into defrost mode or unplug it..remove all the food and shelves and inside back wall of the freezer,with a hair dryer start melting the ice around the heater if it has a glass heater on the bottom ,if you can't get it into defrost you can unplug it,remove the two screws that hold the heater into place and look at it,if it's all black inside the glass change it out,you can check it with a meter to see if it's good but sometimes it will read good but like i say if it's all black change it out,if you have a calrod just a black rod going around the coil most likely this won't be your problem,it will be the thermostat,next you have to check the thermostat,it's on the top of the coil,if you know how to get it into defrost,first unplug it,then cut or unplug the two wires going to the thermostat,bypass the thermostat by wiring the two wires together,plug it back in,put it into defrost and if the heater comes on then you know the thermostat is bad,it's a good idea to change this while you're in there anyway,also if you look at it and the top looks like it's buldging off then water got inside it and it's bad,if you send the model number it would be easier to help you but you get the idea,you have a bad part in the defrost section,if you have another fridge you could just shut it down and it will melt out on it's own,then you can check the heater with a meter,the only thing is the thermostat has to be cold to read it out with a meter,like i said it's a good idea to change it anyway,you can cut or unplug the wires and bypass it and see if the heater comes on,if it does come on leave it on,it will help you melt out the ice or cut the wires,remove the thermostat and put it in the other freezer so you can check it with a meter but the best way is to just bypass it,put it into defrost and see if the heater comes on,if the thermostat and heater are good then you have a bad board or timer.http://www.youtube.com/watch?v=z-h541_14ZE copy and paste,this is not a side by side but the thermostat is in the same place on the coil,just remember where you remove it from if you change it out,it has to go back on the same spot.if you need more help send the model number and we can go from there.it's a little tricky trying to tell you what to do without knowing if there's a board or a timer in it.hope i didn't confuse you and good luck
Oct 19, 2011 | Refrigerators
Fridge won't cool below 60, freezer won't go above 20
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Aug 08, 2011 | Refrigerators
This morning, my Whirlpool side by side made a kind of fizzling sound for about 10 seconds and then a small stream of smoke came out from the freezer side followed by a larger puff of smoke. The smoke was...
Most likely the water from defrost was sizzling and your defrost heater has burned out. The unit won't defrost and your heater assembly needs to be replaced if that's what happened
Jun 28, 2011 | Refrigerators
Refrigerators Logo
116 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
