Question about Pentax Cameras
How to unlock card on pentax optio z10 - Pentax Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Pentax Master
  • 102,366 Answers
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Posted on May 18, 2011
2 Suggested Answers
lock123
  • 6831 Answers
SOURCE: How to unlock card in pentax optio Says Card
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 22, 2010
The sd card in my optio z10 says it's locked. How do I unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 07, 2010 | Pentax Optio Z10 Digital Camera
Memory card says locked, how do i unlock it?
There's a small switch on the card slide it and you are done.
Feb 21, 2010 | Pentax Optio Z10 Digital Camera
What is pentax optio z10 reset button
The reset is on the settings menu, it does not have a reset button.
To get to the settings menu press the menu button then press the right button on the controller to get to the setting menu.
When you are on the setting menu you need to go down using the down arrow on the controller to the 3rd page were the reset option is.
Press right to access the reset options then select Reset then ok.
Jan 29, 2010 | Pentax Optio Z10 Digital Camera
Optio Z10 is stuck on green mode, how do i fix it?
Go into the menu and find "reset"...follow the on-screen instructions.
Dec 10, 2009 | Pentax Optio Z10 Digital Camera
How to format memory card pentax optimo z10
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
In 'My Computer', right-click on the drive and choose 'Format'.
5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Oct 30, 2009 | Pentax Optio Z10 Digital Camera
Pentax Z10 won't turn on.
Press and hold the playback button for 2 seconds. The camera should turn on and be in playback mode. Switch to Camera Mode by opening the from slider cover. Hope that fixes it. See Pentax Z10 Manual Page 34.
http://www.pentaximaging.com/files/manual/OptioZ10.pdf
Cheers Jon. Sydney Australia.
Jun 10, 2009 | Pentax Optio Z10 Digital Camera
Can't install software for Pentax OptioZ10
If software is a problem why not just buy a USB to SD card adapter, and plug your SD card directly into macbook - about $10
Mar 08, 2009 | Pentax Optio Z10 Digital Camera
I have a pentax optio z10. when i turn it on (slide the front open) it says "green mode" then proceeds to turn blank..
i got the same problem. try holding the play button and turning on. it wont help fully, but i was able to look at my already takin pics
Jan 13, 2009 | Pentax Optio Z10 Digital Camera
Cameras Logo
29 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
