Question about Kyocera FS-2000D Laser Printer
I am getting a black stripe down the left hand side of all documents that print - I have a FS-2000D Kyocera Printer & have changed the waste toner box, removed the toner (and cleaned the head) but cant seem to remove it - please help!
    Problem Solver:
  • 11 Answers
The problem is in the fuser roller.
Try to open it and see if there are any damage in the red-orange teflon roller.
The other problem can be in the trasform roller.
It's under the drum. I will write down what can you du, but first open the rear unit at the back and inform me about how it looks like.
Open with pulling gray handle. There is a green square mark in the left. Grab it and pull. Now youz will see two rollers. Please tell me everithing about the upper and the lower roller. Rotate it by the gears (360degrees), and see every side.
Posted on Oct 11, 2011
    New Friend:
  • 12 Answers
Try used Original toners not compatible, or just clean inside of the printer also checked if the film cracked.
Posted on Jun 10, 2013
Kyocera FS-2000D shows call service 7410:0130324
7410 is an error (all numbers following : is the number of pages printed.
- indicating the Drum Unit is not installed properly or you have a defective curcit board. Tyoically it is drum drum is not fully seated.
If you open the door on the left hand side of the printer, where your waste toner container goes and press firmaly on the drum which is loacted behind the waste toner container and close the printer backup. If the drum is properly seated the error should close.
I hope this is helpful,
Shawn
Feb 07, 2011 | Kyocera FS-2000D Laser Printer
Displaying - call service 7410: 0007299 & won't let me do anything
7410 refers to drum not being inserted properly on the left hand side where the waste toner bottle is ull see the drum just above it push it it properly.
Feb 24, 2010 | Kyocera FS-2000D Laser Printer
CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Mar 02, 2009 | Kyocera FS-2000D Laser Printer
Kyocera FS-2000D is printing a grey stripe down the side of page
In this case what i would request u to do is.......
Take out both the catridges from the Printer.........
Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds......
Now remove it and see whether u see any ink on the paper towel..........
U should see some ink on it now place the dry paper towel on the ink catridge in the same way........
Now do the same procedure again..........
Do the same procedure twice on the Black Catridge.................
Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel..........
Know insert both the catridges inside the Printer...........
Good Luck
Feb 16, 2009 | Kyocera FS-2000D Laser Printer
ERROR CODE 7410:0004729
Hi, switch off printer ,just open cover(door) on the left side of the machine and push Drum Unit in machine(to proper seat)
You have to hear "click" sound.Switch on printer.
Regards...
Mar 08, 2008 | Kyocera FS-2000D Laser Printer
Kyocera FS-2000D
Hi, Sound like drum unit is out off position.
Switch off printer.Open left side door, remove waste toner bottle and push drum unit(with grej lever on it) in printer to proper position.If grey lever is not in proper position, drum will be not locked.Place waste toner bottle in position.Switch on printer.
Nov 02, 2007 | Kyocera FS-2000D Laser Printer
Kyocera FS-2000D Laser Printer Logo
517 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
