The stereo had been working great. I had to take it apart an put it away for a few weeks. When I set it up, it would light up but no sound. ( I could see the stereo light come on when I was searching for stations) But no sound(.Connections were all good ) I shut it off for a few hours. got some new speaker wire and tried again. Now it will not light up at all . I plugged a lamp in the built in outlet and it lit up. Is there a fuse. or is it just old and dead ?
    Brigadier General:
  • 8,546 Answers
Hmm, speaker wires make a difference. Follow that clue. Connect one speaker at a time.
Posted on May 18, 2011
2000 camry electrical short?
Michelle, I would recommend taking your vehicle to a local Car Stereo Shop or the dealer. It sounds like your son may have tapped into the incorrect wire in the harness when putting in the new stereo. It sounds like a problem of ignition wire is going to ground. Or the constant power wire is going to ground. Either of these issues would cause this problem.
Mar 01, 2014 | Cars & Trucks
Been away for three weeks...turn my Hisense back on and all I get is blue screen. I can faintly see all program guides in the background but no channels working, no sound. Can anyone advise?
Please put the set on for few hours and I am sure it will work well. It is possible there is a moisture build up , a weak capacitor in the circuit or a dry solder joint. When the chassis warms up it is possible that the fault should clear or else you will need to open and start by checking from the power to the drives.
Dec 21, 2011 | Televison & Video
Accord 2003 radio works sparadically. you a big a crack or pop and the sound goes away. days or weeks later it comes back on. the back light and panel is visible. what is causing the sound to come on and...
Sounds like a defective radio, look on ebay for a replacement. Easier to spend 20 bucks on someone else's cast off than get a new one or have that one fixed. After you have a replacement take it to a car stereo store and pay them a few bucks to put it in for you. If you know what you are doing just takes a few minutes.
Oct 07, 2010 | 2003 Honda Accord
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Hello Replaced stock radio with after market and now the dash, light don't work and tail lights blow the 10 amp fuse can you help
you have a bare wire shorting out,This is a bad condition and needs attention right away.remove the stereo and start over,you will find the bare wire or you wired the stereo to that circuit.
Sep 24, 2009 | 1996 Nissan Sentra
Color spots on panasonic projection screen
The light engine may be dirty with dust, the polarizer filter burned, or the LCD elements burned.
As a last-ditch effort, the light engine can be taken apart and carefully cleaned using compressed air.
Apr 12, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Sound problem with JBL Creature II
I had a problem with the speakers not working properly. The green lights lit, but the amount of sound coming from the speakers compared to that of the sub was much lower.
I decided to take it the speakers apart.
I found that the magnets on the speakers had moved forward slightly in the plastic cage they sat in. I pushed them back as far as they would go, and Hey Presto! working again!
I hope this helps someone!
Feb 23, 2007 | JBL CREATURE II Computer Speakers
24 people viewed this question
 Grubhead
Grubhead
