My toshiba satellite l35 wont turn on,,,the light blinks then shuts off ,,,thats all it does
  • 4,338 Answers
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Posted on May 17, 2011
Clear cmos toshiba laptop satellite L35-S2174
Remove coin battery for 2 minutes, Computer will default to original new computer status. Make sure the 2032 coin battery is good.
Dec 26, 2012 | Toshiba Satellite L35-S2174...
My toshiba L35-S2161 the monitor only displays lines in colors, what to do to fix it
Since you diagnosed by using an external VGA monitor, you now know the fault lies in either the Video Cable, or the Display Assembly.
Your graphics chipset is good.
(Also known as GPU. Graphics Processing Unit )
A) Video Cable:
(Toshiba = LCD FL Cable )
See if the connections are good. Check the motherboard side connection of the Video Cable, AND the LCD screen side connection.
A loose connection can do this.
1) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/taking-apart-laptop-1.htm
2) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/remove-notebook-screen.htm
(On both links above you can click on the photos to enlarge )
Observe the sheath of the Video Cable for obvious signs of damage.
If the cable looks pinched, stretched, or torn, the tiny wires inside the cable may be damaged also.
Best method is to remove the Video Cable, and perform a continuity test of the wires inside the cable, with a multimeter.
(An economical unit can be purchased for around $8 to $12.
Analog or digital is fine )
B) Display Assembly:
Video Cable checks out OK;
1) Check the connections to the screen Inverter board.
Make sure they are tight. Make sure the Inverter board does not appear to be damaged.
2) Screen Inverter board:
Primer;
An LCD screen does not produce light. It needs an additional light source.
http://en.wikipedia.org/wiki/LCD_screen
A Backlight is the additional light source.
A Backlight is usually a CCFL, or a series of LED lights.
The Toshiba Satellite L35-S2161 Notebook PC, uses a CCFL for a Backlight. (Uses 1 CCFL)
CCFL stands for Cold Cathode Fluorescent Lamp
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm Thick, and is close to the width of the LCD screen in question, Long )
A screen Inverter converts the power (Electricity) from the laptop, for the Backlight and LCD screen.
It is located behind the Display Mask, (Display Bezel), and mounted towards the bottom of the LCD screen.
http://www.zkarlo.com/selected-zkarlo-part/inverter-board-p2215.php
A bad screen Inverter usually causes a garbled display, or doesn't light the Backlight up.
To test a screen Inverter you need a sensitive multimeter, or use a spare Backlight bulb that is known to be good.
Bulb lights up the Inverter is good, the Backlight in the LCD screen assembly, is bad.
[ The LCD screen is composed of layers. These layers are held in place by a metal Screen Frame. {Resembles a picture frame }
The Screen Frame comes apart.
Screws are removed, and the Screen Frame comes apart in four pieces, (Four sides), or the Screen Frame comes apart in two pieces as an Upper half, and Lower half.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/big/satellite-L35-screen-08.jpg
The Backlight bulb is taped to one side of the LCD screen layers, and is under that side of the Screen Frame.
The LCD screen layers MUST be kept aligned, as they were from the factory. For this reason alone, it is tedious for an experienced technician, and is usually not done at the consumer, or DIY level.
http://www.zkarlo.com/selected-zkarlo-part/lcd-cable-p2216.php
More in a Comment.
Regards,
joecoolvette
Feb 05, 2012 | Computers & Internet
I replaced my screen on a toshiba L35 laptop and turned it on screen is black now comp is running . help please?
try first your laptop without using your laptop screen. remove laptop screen and testing display output from your CRT or LCD monitor. if display comes out, try to check your inverter.
Feb 04, 2011 | Toshiba Satellite L35-S2366 Notebook
Fixing DC Jack for Toshiba Satellite L35 cost how
I believe the L35 uses what is considered a satellite power jack which means the actual jack is not soldered to the motherboard but uses a cable and plug, therefore is the easiest of the power jack repairs. The cable can be found on ebay for around 30 bucks or less. I usually charge 50 bucks for the labor plus the part, the laptop has to be disassembled to complete the repair. Below is a link for disassembly if you want to use it as a reference and perfrom the work yourself.....
Jan 04, 2010 | Toshiba Satellite L35-S2366 Notebook
I have the toshiba satellite L35, when i turn it on the red toshiba logo shows up but then after that it goes to a black screen that says a disc read error occurred
you may have lost your hard drive. always best to back up your files and os on an external drive. if you have a recovery disc try to boot it
Dec 16, 2009 | Toshiba Satellite L35-S2366 Notebook
My wife has a toshiba satellite L35-S2151 laptop. When she went to turn it on, the orange battery light flashes 8 times and nothing else happens. Any clue as to what is going on?
Try turning on the device with the power connected if it turns on, keep the power plugged in for the entire day. See if you will have the same problem without the power supply. If it still occurs without the power supply, you may have a bad battery, you can verify if you can get swap battery from a similar laptop.
Oct 01, 2009 | Toshiba Satellite L35-S2366 Notebook
Toshiba Satellite L35 screen color turned to pink.
If you have a LCD-screen, not an old-style CRT-screen, it is the data-cable, and its connections, that are not transmitting one of the 3 "primary" colours, e.g., mix red & blue & green to get white,
but mix only two of those colours, and you could get pink,
because the mixing is an "additive" process.
If you mix NONE of the 3 primary colours, you should get BLACK.
If you see GREEN, you're seeing ONE of the primary colours.
Sep 19, 2009 | Toshiba Satellite L35-S2366 Notebook
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
