Question about Spidem Trevi Digital Plus Coffee Maker
Coffee machine is displaying error message "BREWUNIT BLOCKED". Have tried opening up the machine to clean it out but nothing seems to be opening or closing properly!!
    Scholar:
  • 78 Answers
All fully automatic machines have a motorized system to move the brew group from Home (start) position to the Brew position. Pause in the brew position until coffee is dispensed by the pump action.. Then it returns (reverse move) back to the Home position.
In Brands like Saeco, Gaggia and Spidem it is a 33V DC motor that operates this job. The DC motor is fed directly from the Main power board.
When power to this motor is reduced to half or less the Brew group movement is either slowed or stop completely (no DC current coming to the motor). In both of these cases the error message will be the same "Brew group blocked".
Many technicians diagnose this to a faulty motor. That is not correct. New motor does not restore the function or the error message.
To fix the Brew group blocked error I suggest the following:
1- Remove the Brew drive 33V DC motor. Inspect closely to check for definite smoked and burn marks inside its casing. If one can manage it, to power the motor with DC current & see if it operates.
2- I have rarely seen a motor burn out. It is almost 95% times the power from the Control board is reduced or interrupted. A resistor or Triac or both are bad. These two components are screwed tight at the bottom of the large metal heat sink to dissipate heat as fast as possible. These two components overheat fast and stop functioning. The current id reduced to 11 to 16V or fail totally to power the motor.
If one can get these two components replaced, the power to the motor can be restored.
This electronic repair is not easy or cheap. The old models of Vienna, Trevi and Syncrony Logic have Aluminium boilers. The electronic control board for the old models is not available any longer.
The new models of Vienna, Trevi, or Syncrony Logic have a Tubular heat exchanger & a modified control board. The electronic board for new tubular heat exchanger does not work in older models with Aluminium boiler.
Option one: Find an electronic repair service for the power board.
Option two: Trade this machine in for a new machine .
Posted on Oct 25, 2014
    President:
  • 1,618 Answers
Remove the brew unit and clean the shower screen under the red o-ring, There is also a tube leading from the top of that o-ring to the discharge and is attached with 2 screws, remove screws slowly DO NOT LOOSE THE SPRING AND BALL that is under the fitting, clean out tube and the hole that leads to the screen, that should clear up the problem.
Posted on May 20, 2011
How do I unblock brew unit from Saeco Magic Comfort Plus?
unscrew where is the arrow and take off the brew unit(the block).
Sep 14, 2014 | Saeco Magic Comfort Plus Espresso Machine
Brew unit stuck
Hi molly girl.
You can try to clean your Brewunit. Most of the times when that message appears, it means the brewunit is dirty
You can have more info in the manual if you dont have it:
http://www.miele.co.uk/Resources/OperatingInstructions/CVA%20620.pdf
Jan 11, 2008 | Miele CVA615 Espresso Machine
Blocked Brukit. Had it out a number of times...
Try this remove brewunit and find discharge tube from top shower screen. There will be 2 screws holding tube to brew unit, remove screws slowly and make sure you do not lose ball and spring that is under tube. Clean out that passage way and make sure water flows through, then reassemble and test.
Jul 12, 2011 | Saeco Royal Professional Espresso Machine
Display message - brewunit block - can not undo to start the machine Miele CVA 620 Build-in Automatic coffee machine
YOu must turn the machine off...hold both the small coffee and hot water button...tunr the machine on to light...let go of the buttons..then hold in the large coffee button for a few secinds andletgo ..if that doesn't work hold in the medium coffee button for a few seconds and letgo..that shouldreset the brew unit.
good luck
Jan 13, 2010 | Miele CVA615 Espresso Machine
My brewunit is blocked
Coffee fines and mineral scale build up in the brew unit filters and also in the creme valve. The pressure to pump water through the unit fails and the flowmeter tells the electronics that no water has flowed, it in turn stops all processes and displays "brew unit blocked" message. If you're handy, call Miele tech support. The'll walk you through how to remove the drainage cup screw off the left rear of the brew unit, get the brew unit out and return the gearing to home position. It's a 50/50 chance the gears will return or you will need a service tech to pull your coffee unit out and re-sync the gears to the electronics. That's of course if they didn't break.
This blockage is is prevented only by using the cleaning tablets and descaling tablets. Both need to be used as outlined in the instruction manual.
Oct 02, 2009 | Miele CVA615 Espresso Machine
Gaggia Titanium, "Brewunit Blocked"
Check the shower screen in the unit it is possible that it is blocked with coffee oils.
Aug 03, 2009 | Saeco Incanto Classic Espresso Machine
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hi I have a gaggia titanium coffee machine it has comme up with an error message the the brewunit is blocked i have decalcified machine but no joy can you help
Remove brew unit, If you have the key that came with the machine use it to remove the shower screens and check for blockage.
Mar 29, 2009 | Gaggia Titanium Espresso Machine
Brew unit blocked
You can remove the brew group by following the "how to remove a jammed brew group?" on this page http://cerinicoffee.com/Saeco_technical_documents.asp
For Cleaning Supplies and Saeco Parts visit:
www.cerinicoffee.com
May 30, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
BrewUnit Blocked Error
The brew unit sensor may have become disconnected from the main circuit board. If you are very brave, you can UNPLUG THE UNIT, remove the top panel and check that all the wires running into the circuit board are connected.
Otherwise, the sensor may have failed and this will require service.
Mar 15, 2008 | Miele CVA615 Espresso Machine
Spidem Trevi Digital Plus Coffee Maker Logo
558 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
graybeard32301
ray gallant
nikolay nikolov
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
