The sleep/timer is stuck om & the TV will not turn back on. We have a Sony TV
  • 19,396 Answers
Hi.
The TV is in protect mode. This is a special diagnostic mode that turns on when an internal fault such as an incorrect voltage or a short is detected by the TV main circuit board. In protect mode the TV is forced to stand-by, and voltages from CPU are kept off, apart from the low +5V DC that is used to keep the TV in standby.
General troubleshooting consists in disconnecting power cord. If that does not do the job, the TV must be tested and repaired.
Power reset will not help in case there is effectively an internal fault, but can reset the fault mode if the error was prompted because of a temporary problem
(e.g caused by power surge).
If that does not work, contact the manufacturer at the number listed on the owners manual to get the TV repaired by a licensed technician.
Note if the TV is blinking a number of times, then there is an error code. In that case tell me the number of blinks and the TV model number.
If it blinks all the time, then there is no code. Try power reset. If that does not work you need a technician.
Regards.
Ginko.
Posted on May 18, 2011
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
SONY HDTV-LCD MODEL - KDF-42WE655 turns itself off. Lamp light indicator flashes red. Should I attempt to reset ? It is approx. 4 years old
I'd wager that somewhere in the menu settings, there is a "Sleep Timer". Check the menu for the sleep timer, which turns off the TV after a set length of time. Also, check your remote, there might be a "Sleep" button that would do the same thing, press it multiple times until it reads "Sleep: Off" or something similar.
Dec 19, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My tv is stuck in a closed caption screen
CLOSED CAPTION SELECTION SLEEP 10 To cancel the sleep timer: Press the SLEEP button repeated-ly until "SLEEP 0" is displayed. You may view specially labeled (cc) TV pro-grams, movies, news, prerecorded tapes, etc.with either a dialogue caption or text displayadded to the program.1) Press the MENU button so that the menudisplay appears on the TV screen.2) Press the CH(annel) ▲ or ▼ button to pointto "CAPTION".3) Press the VOL(ume) ▲ or ▼ button to selectthe mode you wish.4) When done, press the MENU button to exit the menu
Then turn OFF.
I also include your user manual below. It's easier to read in there.
www.symphonic.us/pdf/om/ST413C.pdf
Aug 21, 2010 | Symphonic ST413C 13" TV
We got a free Sony TV from a neighbor moving out of state. No owners manual or remote, but its worked fine until today. This morning the 'sleep' and 'timer' lights are both blinking, alternately at one...
Unplug tv from wall socket for minute to get its timer function reset, then replug back in and turn it On.
If problem still not solve, let me know.
Thanks.
May 16, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Turns on and off
If your TV turns off by itself, first check whether or not it has a built-in sleep timer by consulting the instruction manual of the TV in the Manuals/Specs/Warranty section of the Sony® eSupport Web site. If the TV does not have a sleep timer, or the timer is not set to turn the TV off, service may be required to resolve the issue.
Aug 13, 2009 | Sony Televison & Video
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Sleep timer not a fix
This Tv is a piece of junk I have 2 of them and I had to replace the first one with this same problem. The second one just broke is stuck in dvd mode. Company is out of buissness
Dec 06, 2007 | Sony KDE-50XS955 50 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
