We bought a second hand lavamat 1020 . It seems that the pump does not pump the water out. Therefore the spinning cycle does not occur at all either and when you open the machine all the water comes pouring out.
Hi, just solved the same problem with our aeg lavamat w 1020. Try checking the filter tray (or port) at the bottom left-hand corner of your machine. This was our problem and as soon as the blockage was removed the machine could be pumped out. It appears to be running OK now.
Was this helpful?
Yes
No
Popular Solutions for AEG Lavamat W1050 Front Load
The mechine doesn't drain the water and the end mode is blinking when i trun it on. when i...
(More)
The mechine doesn't drain the water and the end mode is blinking when i trun it on. when i disconnect the power terminals from the pump the end mode stop blinking and the mechine starts,drum spin etc.. i put a new pump but still the same problem , i checked to see that the controller give 220V to the pump power terminals and it does. it semms that whenever i put some load on the pump power terminals the mechine goes into end mode .
Hello, Our AEG Lavamat W1050 had a broken handle, I have bought a new one, but am unsure how the...
(More)
Hello, Our AEG Lavamat W1050 had a broken handle, I have bought a new one, but am unsure how the springs sit. Please can you send me a picture, or advise. Thank you
My machine did not tumble any more and the repair man replaced the brushes. It worked for 2 loads,...
(More)
My machine did not tumble any more and the repair man replaced the brushes. It worked for 2 loads, and now again, it does not engage. water fills up, however not turning , tumbling, spinning... where do I get a new cicuit board,, or a repair manual - not a user manual?
Hi, my Lawamat W1050 does not rinse or spin when I put the knob on the Cottons Linen ? I have...
(More)
Hi, my Lawamat W1050 does not rinse or spin when I put the knob on the Cottons Linen ? I have checked on other programs and it works just fine. The red END indicatior light flashes constantly when the program is finish... any ideas ?
