Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sleep/timer is stuck on & TV will not turn on
  • Sony Master
  • 12,061 Answers
Hi, well this is NOT a sleep/Timer problem No, from experience in my shop this will indeed be the problem below.
This is a classic switchmode power supply, has sensed a severe potential problem, and is shutting down to avoid a fire, explosion, or both. This set had developed a problem, that is so severe that the set must be shut down, This set should be removed from the Power, and in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center, this point is very important for a good result, Always contact, their local, "Head Office" Now, when you get the information you want, then you can decide as to repair of replacement. The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done
Posted on May 17, 2011
TURNS OFF AFTER 12 MINS. SLEEP IS SET AT OFF
In addition to a Sleep Timer, many TVs have an Off Timer, too. Check for other automatic settings and timer settings. If you use the TV as a monitor for a computer, the sleep setting on the computer might affect the operation of the TV.
Apr 28, 2015 | Televison & Video
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
Hi my rca truflat 20 inch tv stays on for about 30 mins then displays an analog clock and turns off
Your sleep timer is on. Hit menu, and poke through that and find the sleep timer settings. Sleep timer is something that turns the TV off after an amount of time that your do not interact with it.
Sep 17, 2010 | RCA Televison & Video
My tv is stuck in a closed caption screen
CLOSED CAPTION SELECTION SLEEP 10 To cancel the sleep timer: Press the SLEEP button repeated-ly until "SLEEP 0" is displayed. You may view specially labeled (cc) TV pro-grams, movies, news, prerecorded tapes, etc.with either a dialogue caption or text displayadded to the program.1) Press the MENU button so that the menudisplay appears on the TV screen.2) Press the CH(annel) ▲ or ▼ button to pointto "CAPTION".3) Press the VOL(ume) ▲ or ▼ button to selectthe mode you wish.4) When done, press the MENU button to exit the menu
Then turn OFF.
I also include your user manual below. It's easier to read in there.
www.symphonic.us/pdf/om/ST413C.pdf
Aug 21, 2010 | Symphonic ST413C 13" TV
How to turn on the sleep timer with a comcast
press tv,press setup until 2 blinks,enter 994,press setup briefly,enter049,press the button you want to put the sleep timer on or off
Jul 10, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
TV will not come on with remote or power button
The following instructions are for the Emerson EWC1303/1903 tv/vcr. That's the closest match I could find to the Spongebob Squarepants 13' TV
If it's actually in Sleep mode, do the following:
TO CANCEL THE SLEEP TIMER
Press the WAKE UP/SLEEP button on the remote
control until “SLEEP TIMER” appears.
To view the time left for sleep timer press the WAKE
UP/SLEEP button twice, then press the MENU button
on the remote control to exit the sleep timer setting
If unsuccessful, try unplugging the TV for 1/2 hour, then plug it in and try turning it back on either manually or with the remote. Either of these should solve your problem. Best of luck to you!
May 08, 2009 | Emerson SpongeBob SquarePants TV
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
14 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
