I have an AO Smith Century E Plus 3 hp 3 phase 208/230/460V belt driven motor. The wiring diagram on the motor is very vague. There's nine wires coming out of this motor, AO Smith p/n 7-850111-01-0J. I'm just a little confused on how to wire it in. Very expensive motor and hard to get, I just don't want to blow it.
  • 11,800 Answers
This is a tri-phased motor in which the coils are joined in a stellar configuration: one end of the coils is joined together internally while the other 3 ends are set externally as the power connectors.
Because this motor is a special one, capable of functioning on different voltages the coils were designed with intermediary outputs so basically you have 3 sets of the 3 phased outputs, corresponding to the 3 available voltages.
You must identify the wires for each pair. You will do that by measuring the resistance of the coils between 2 of the wires. You will need a very sensible ohmmeter for that. Once you have determined the 3 pairs just connect the appropriate pair to your tri-phazed mains source.
Posted on May 21, 2011
  • Azrael SRL May 21, 2011
    But i must warn you, if you don't identify the wires correctly the engine will be instantly fried. If you aren't absolutely sure you can do the job correctly then call someone who can.
  • 43,501 Answers
Here is the connection diagram...
Low voltage would be if you are using 208/240v and use the high voltage if you are using 460v
3 phase motor connection
heatman101
Posted on May 18, 2011
    Genius:
  • 1,400 Answers
Hello
This is probably being done in pairs. Say wires 1 and 2 3 and 4 5and 6 would make up your 3 hot wires. Then 789 would be tied together.
This is an example only! I dont know what the diagram shows on the motor.Each combination would depend on the voltage you have available.208 230 460 also the amps.
460 volts would draw the least amount of amps.
  • mpcheesman1
    mpcheesman1 May 18, 2011
    Thanks for the 2 thumbs up.
  • 12,061 Answers
Http://www.bestbuypoolsupply.com/media/motormanual.pdf
Hi all the info you need is in this manual at the above link.
Posted on May 17, 2011
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
Wiring diagram for century pool pump motor model b977
check on side of motor should show low and high voltage wiring if not email AO smith
Apr 13, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
Replaced an old Magnetek century two speed with a AO smith century two speed. Hooked the wires up the same but unable to get the motor to operate in the high speed mode, suggestions!
Each motor will have wiring diagram on label.
Compare diagram on old motor with new motor.
WIRE COLORS VARY
Which 2-speed timer do you have on the circuit?
Wire lead from NO terminal connects to High speed.
Wire lead from NC terminal connects to Low speed
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#2-speed
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Oct 23, 2012 | Pool & Spa
Im replacing a 2 speed Hayward motor with a AO smith 1 speed motor. I need to no how to wire the 1 speed
to wire a single speed motor you use only the black, white and green wire. there is usually a wiring diagram on the side of the motor to show how this is done.
no wiring diagram then put the black wire on the L1 or H1 post and the white wire to the common and of course the green to ground
Aug 21, 2011 | AO Smith A O Smith Motors Century 1hp 115v...
1/3 Hp 115 volt 24 year old motor 40 amps. single Phase. is this for 110 volt Plug in to wall.It also 3 wires , Orange,Red, White, were do i hook these up to on a 110 Plug. Can you Please help.
You looked at nameplate on motor to get the rating information?
Rating plate may also have small wiring diagram.
I was looking at AO Smith single-phase 2-speed pool pump motors yesterday.
The rating plates show wiring.
Open following link:
http://waterheatertimer.org/images/AO-smith-rating-label-500.jpg
Notice the image shows the words: Brown White Line Line.
Brown and white are wire colors. Line means 'power' from breaker box.
240V will have two Line wires, L1 and L2. 115Volt will have Line or L1 and N or Neutral.
Look at your rating plate and then add a comment with clear description of what appears on rating plate, or include in-focus photo. Put your camera in macro to take close-ups.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Your wall outlet has 2 plug-in slots. One is wider that the other.
'Line' will refer to Hot wire from breaker which corresponds to smaller slot on outlet.
'N' or 'Neutral' is neutral wire from breaker box which corresponds to wider slot on outlet.
Apr 30, 2011 | Electrical Supplies
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
Just replaced a rheem oem 1/6 hp motor 3 wires with a 1/3 hp 5 wire. Need help with wiring diagram. A.O. Smith 1/3 hp to capacitor
green wire cut off if motor is held on with metal bracket.white/yellow to contactor,black to other side contactor. brown/wht to fan on capacitor,brown to common on contactor NOT HERM.
Jul 07, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
Wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Jun 17, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
Heating & Cooling Logo
306 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
