Question about Asko W6441 Front Load Washer
Door latch on inner door of Asko W6461 quattro 1600 rpm will not click in to close door just stays open, therefore washer won't start...
  • 1294 Answers
SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Posted on Jun 11, 2007
  • 351 Answers
SOURCE: Asko W6021 Front Loader Washer Problem
the carbon brushs in the motor need replacing,on the w6021 the fault you get is a clicking sound when you press the start button.
Posted on Mar 02, 2008
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
SOURCE: Need new stabilizer clip/bolts for ASKO washer model W6461
Don't need those bolts except for shipping the washer. They were supposed to have been removed a long time ago.
Posted on Sep 18, 2009
  • 901 Answers
SOURCE: Asko washer w6021 doesn't work. I've checked
See whether water is flowing into the wash machine. Then the door close switch.
Posted on Mar 29, 2010
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
My malber wd2000 door won't open
Malbers use a thermal (heat acting) latch to hold the door closed, so it stays latched for about 2 mins after being turned off. This is to give you time to think before you open the door and possibly spill water all over your feet. When the little bi-metallic piece cools off, it bends to one side (inside the latch assy) releasing the catch, and the door can be opened. Sometimes, the bi-metallic part bends OK, but the latch catches and won\'t release. It just needs a little vibration to free it up. A smack to the latch area (on door or face of Washer) will free the latch.
I tell my customers: Don\'t pull too hard on the white door handle. If you can\'t open it with your little finger (seriously) it\'s not ready to open!
Nov 14, 2013 | Malber WD2000 Front Load Washer / Dryer
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
Rear passenger door won't stay closed
Door latch on door itself is in closed position if it will not close at all. In this case, open door and pull outside handle hard to pop open door latch. If you have door opening at random, door latch needs replacing or door catch on body is loose.
Jul 29, 2012 | 2003 Chevrolet TrailBlazer
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
The door on my machine won't shut?
Hello
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
GMC Envoy 2004 XUV tailgate won't latch closed. Pressure switch makes latch click but when I go to close it, it does not latch.
Two things happen. One the latch is already latched and therefore it's closed before the gate shut, When you try to close it you might notice that the door don't close all the way. This doe'snt have to be thwe case. the other thing that happens if the lock mechanism is working, You here it click? The latch is stuck as the opener is stuck. You might get lucky and spray the latch with Blaster or other rust buster type penatrant. Theres angles though the opening of the latch . Spray on several angles and repleatly close the door trying to vibrate the Penatrant into the stuck area. Looking at the latch use a screw driver to move the latch and see if you can cycle it though it's positions to see if you can latch and unlatch it with the tool and reopen by pullung the handle ( you may need to try ther inside handle too and even the remote openner if you have one. Ussaaaly you need to push the button twice to open the rear hatch so it may take a few trys and spraying to get it to come loose.. Some vehicals stay closed a long time and stuck is the way to think.. But if the door is used often the linkage inside the door mayh have come off the the latch is closed and the linkage doesn't open the laTCH AND THE THING MANAGED TO GET CLOSED WITHT THE DOOR OPEN.
May 09, 2011 | 2004 GMC Envoy
I have an asko 10505 washer. how do you open the door?
here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
Mar 28, 2011 | Asko W6021 Front Load Washer
Asko W6441 Front Load Washer Logo
111 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
