Question about Epson R1900 Printer
Changed a cartridge now printer says incompatible cartridge
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 145 Answers
It could be the coagulation of ink in between the cartridgebetter dip it in mild hot water for some times and replace it wiping the water. it would do the trick and solve your problem . it has been practicallytested.
If this solution helpful/useful for you please rate the solution. THANKS FORUSING FIXYA.
Posted on May 18, 2011
"Incompatible Cartridge" error
Try uninstalling printer, reboot computer then reinstall printer drivers. do not accept HP updates as they block non HP consumables. Update manually if needs must.
May 09, 2013 | HP Officejet 6310 All-In-One InkJet...
Printer giving 'incompatible ink cartridge' message
replace your cartridge with a new one or refill others old
check here how you can do it your self
utube.png You-Tube video "sOriLrbuBao" placeholder (do not delete) utube.png
utube.png You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete) utube.png
Apr 16, 2010 | HP Officejet 5610 All-In-One InkJet...
Keeps saying incompatible ink cartridges but hp cartridges have not been changed
remove your cartridge and reinstall again on proper place may be your problem will solved.
Mar 31, 2010 | HP Photosmart C4580 All-in-One InkJet...
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Mar 24, 2010 | Epson Stylus cx7450 All-In-One InkJet...
Message says Wrong Cartridge , Display screen flashes with Wrong Cartridge or Insert Cartridge , but we have changed nothing on the unit at all.
Dec 07, 2009 | Office Equipment & Supplies
Canon MP460- printer head slams end limits and alarms out
This could be indicative of serious ink issue. This could be as a result of a number of scenarios. But firstly, make sure you have replace he right cartridge.
i. Ink has developed incompatibility. Solution is try an older/another cartridge (doesn’t matter if ink is finished). If it stops blinking it confirms that your cartridge has become incompatible. Also if your printer is the type that can work with only one cartridge, remove one after the other to determine which in the set (black or color) has become incompatible. Just replace the incompatible one and start printing again.
ii. The electronic panel on the cartridge that contact with the cartridge carrier inside the printer is dirty and needs cleaning. Solution is try to clean with a piece of folded tissue paper soaked in a bit of methylated spirit. Also clean where the cartridge carrier where it makes contact.
Dec 04, 2009 | Office Equipment & Supplies
Incompatible print cartridge
Take out the print cartridge. Clean the points on the cartridge with cotton swab and try using it again.
Nov 04, 2009 | HP Photosmart C4480 All-In-One InkJet...
Previously working cartridge now incompatible
I have a very similar printer. It is very fussy with cartridges. Take it out and clean it with a Q-tip and rubbing alcohol. Electrical contacts and make sure the ink dabs onto a napkin. Dont buy another HP :(
Oct 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Open Questions:
See all Epson R1900 Printer Questions
Epson R1900 Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
