Question about Toro Lawn Mower With Toro Power Tools
Toro recycler model number SR-21 S lawn mower wont start changed plug, filter, new gas. Mower ran for two lawn cuttings but seemed to overheat and choke out frequintly in high grass now it wont start at all.
  • Roy Cagle
    Roy Cagle May 17, 2011
    Maybe all the high grass isn't being eliminated by the blade and the deck and you are getting some clogging underneath. That could explain the overheating, but the starting issue will require some diagnostics to get at the root of the problem.
  • 577 Answers
Check your oil is it up to full, then I would check to see if you have compresson, pull your plug and roll over and feel with finger ,but don't touch spark plug wire or you will light up! next I would check for spark, then for fuel, make sure the carb is getting fuel,,,check your hoses and fuel cap and clean your carb and needle/seat and make sure gas will run through the fuel line. Also you could have sheared a flywheel key
the choke out you are talking about could of been a lean condition and smoked the eng rings
Good Luck compresson test should tell all 2StrokeJim
Posted on May 18, 2011
My toro super recycler bogs down while mowing. I have fresh gas, just changed the oil and filter. Any suggestions?
check and be sure the blades are sharp. if the blade gets a rounded edge it wont cut properly and will bog down trying to cut.
Aug 15, 2016 | Toro Power Lawn Mower
Why my toro recycler 22in personal pace lawn mower wont start ?
I recommend that you call the store and get service under the warrenty.
Aug 06, 2014 | Toro Garden
I have a toro recycler 6.0 push mower and I can't seem to get it started changed the plug but still won't start
get the old gas out of tank and carb....put new gas in...wait 2-5 min....spray starter fluid into carb --one decent squirt....it'll crank....
Jun 09, 2014 | Toro Power Lawn Mower
Mower wont start changed plug still wont start checked gas line seemed okay but what is that plastic piece in the line never seen one before
Getting a mower out of its winter slumber takes some time. Start with fresh gas, new oil, and air filter. Sometimes carbs get gummed up(varnisized gas). Donyboy73 on youtube shows how to remove Briggs n Stratton in tank carb systems and clean the parts and passages.
Apr 27, 2013 | Toro Power Lawn Mower
Toro Recycler engine doesn't rev up when control arm is engaged
check the throttle spring in the front of the engine.It is hooked to a loop and when going near a bush it will push in and slow the rpms down.If you locate it pull it out and the RPM"s should increase.
Jul 25, 2012 | Toro Power Lawn Mower
Will not start toro model143.026706
if it stopped running after hitting something with the blade check the key on the flywheel where it meets the crank
Jun 04, 2012 | Toro Power Lawn Mower
I have to prime the toro mower every time I empty the bag to get it to start?
  1. what is the model, manufacturer and year of mower?
  2. has any maintenance been performed on this mower?
  3. if no, try replacing the spark plug and air filter (it's possible the spark plug could be fouled and/or the air filter is clogged) be sure to follow the manufacturers recommendations for oil, gas, filters and plugs.
routine maintenance involves:
  1. sharpen/replace blade
  2. oil change
  3. replace air filter
  4. replace spark plug
  5. new gas
Aug 31, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
429 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
