Question about Microwave Ovens
I have a whirlpool accubake oven model #WGE34300 Ser. #1MH3558149 which does not have an owners manual. The digital display has the letters PF before the time but i'm not sure what this stands for. The stove came with the house but does not have a manual to explain the digital displays.
MicrowaveSvc
  • 9098 Answers
SOURCE: Whirlpool Microwave Model MH3184XP will not power up after power failure
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again. Let us know if the hard reset doesn't fix it.
If not, then you may have a problem is on the control panel, which we repair nationwide for $39.95 postpaid.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 13, 2008
bestdarngood
  • 3037 Answers
SOURCE: whirlpool microwave oven model gh5184xpq
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Please let me know if you need any more help or have further questions about anything that I have posted. I would be glad to help
thanks
Posted on Apr 27, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: sharp microwave oven R874M. DIGITAL
It's generally just a few screws. To order in the UK, see here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
SOURCE: Bosch HES435U - Stove Keypad is Locked
Locking or Unlocking the oven control panel
1. Access Select Function Menu
2. Turn knob clockwise until Lock Keys is flashing
3.Touch Start. Key Pad locked is displayed.
4. To unlock keypads, touch cooking mode and hold for 5 seconds. Display will read unlocking key pad
5. When unlocked the clock will again appear in the display.
Posted on Jul 18, 2009
SOURCE: J have mirowave oven Whirlpool AVM 918.
i have the same microwave oven,
when the display say CAL, you have to calibrate first,
how to do this is: push on the left (cancel) button and hold it till it starts
Posted on Jul 27, 2009
Replacing underneath lights
If the owner's manual does not address it, then some disassembly may be required.
You didn't mention your model number or even your brand, but since you posted it under Whirlpool, maybe it's a Whirlpool.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Always be sure to unplug the oven or turn off its breaker before removing or installing the bulbs.
Failure to do so may result in damage that could require circuit board repair.
Oct 27, 2013 | Whirlpool GH8155XJ Microwave Oven
Tip
Or the microwave could be in "Demo Mode" - Check your owners manual. In...
If the microwave operates normally, but does not heath at all, then it can be the high voltage capacitor, the rectifier diode.or the magnetron.
The diode and capacitors can br tested. The capacitor must be allowed discharge before testing, or you risk to get electrocuted, even if power is off. Capacitors can get discharged by shorting their two contacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, your model number did not return any result, contact the seller here to purchase parts. (here in UK).
on Jun 16, 2009 | General Electric Microwave Oven
Change light bulb microwave
If your owner's manual doesn't cover it, then you will have to do some disassembly, and may have to remove the oven from the wall, depending on the model number, which you did not mention.
But since you posted this is the Whirlpool microwave section, I'll assume that's it.
Oct 17, 2013 | Whirlpool GH5176XPT microwave Oven
User Manual Whirlpool Magicook 22G
Nov 28, 2012 | Whirlpool GH7155XHS Microwave Oven
How to remove the controls panel cover. Our 12 yr old microwave suddenly stopped. No power to display or oven. I have been told that there is a fuze behind the display that is replaceable. Trying to get...
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's an Amana, WHirlpool, Kitchenaid, etc., and you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If you need to remove the oven from the wall, the the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool here.
You can download GE owner's manuals and installation instructions here.
Apr 15, 2010 | GE JE1390 Microwave Oven
I have lost my user manual model is Whirlpool Microwave - 22C (Magi Cook MT 22C) from where i can get it
Go into comet or curries and ask for whirlpools telephone number ad ring them up they should be able to send you a new manual there might be a small postage charge or you could write em a letter
Nov 27, 2009 | Whirlpool GH7155XHS Microwave Oven
I have a Whirlpool gold accubake microwave / oven combo model number GMC305PDS07. The microwave will not turn on and will display "DOOR". I think it is thinking that the door is open?. Please help.
Press and hold the DELAY START TIME button for +5 secs and a chime will sound. The option to toggle between SND HI and SND LO will come up, pressing Delay Start Time will change it between these options.
Jul 18, 2009 | Whirlpool RMC275PD Microwave Oven
Whirlpool Accubake Microwave Oven 2001 vintage.
Hello jparks739,
Please find a link to an exploded view of you micro as well as details on how it goes together. Note the two screws ( item 31) that hold the cover and lens over the bulb in this document.
Hope this helps you..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 03, 2008 | Whirlpool GH5176XPT microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
