Why is air conditioner a split unit leaking on the inside???
  • 59 Answers
You may want to check the evaporator drain line for a blockage. You should see this line off the front of your furnace on the top.
Posted on May 17, 2011
Why does my split ac unit leak inside the house?
This happens when the drain pipe is too high, or kinked. The pipe must be lower then the drain pan in order for the water to drain. This is a common problem.
Jul 27, 2014 | Sanyo Heating & Cooling
Leaking water from the inside unit
When the air gets cooled it also gets dehumidified, on the inside unit there should be a condensate drain. Check the drain to see if its clogged, also check to see there is a drain, I have seen units installed by "pros" who have forgot to intall it
Apr 14, 2014 | Ramsond 12,500 BTU 1 Ton Ductless Mini...
Outside unit freezing
Hi there well it sounds like you got a R22 gas leak thats all
Dec 09, 2013 | Soleus Mini Split Air Conditioner
I have a sanyo split system and one of the inside units creates ice around the coils. the filters are clean and there's nothing blocking the air around it. What can it be?
There are reasons for.
1. Dusty indoor coil and blower wheel - Clean it.
2. Less speed of blower motor- Replace capacitor/motor
3. Short of gas- Find leak and rectify.
Thanks.
Jun 29, 2011 | Sanyo Split System Air Conditioner
My Panasonic split system inverter is leaking water from the inside unit
condensate drain is stopped up and if older than 6 yrs, need to remove the unit and clean coil and pan with high pressure water
Mar 24, 2011 | Panasonic CW-1006FU Air Conditioner
The inside unit is leaking water
Water leaking in split unit common, due to air filter & evaporator coil dust blocked- Clean it.
Drain pan and drain hose dust blocked-clean it. And also due to less rpm of indoor motor, there will be forming ice over the coil result to water leaking while defrosting.Replace motor capacitor.
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
Leaks water inside
Water leak is the common problem in split air conditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4. Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replace motor capacitor.
Dec 18, 2010 | Sanyo Split System Air Conditioner
Leaking water from bottom of inside unit while it is running
It's common problem due to non maintenance. Service your unit frequently, at least once in 4 months.Clean drain pan too.
Dec 06, 2010 | LG LA141CE Split System Air Conditioner
Samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Feb 06, 2010 | LG LSC121PMA Split System Air Conditioner
Split HVAC does not achieve requested temperature
If is heating on outside temp must bee max 5 degree
Celsius.If leak inside unit then check drain hose.
Feb 15, 2009 | Mitsubishi MS-A09WA Split System Air...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
