Question about Acer Computers & Internet
What is the best cpu to put in the acer travelmate 2312lm laptop
    Scholar:
  • 142 Answers
With most laptops you cannot replace the CPU because it is soldered onto the motherboard. This is the case with this laptop.
Posted on May 17, 2011
How can i install my windows 7 64 bit version on my acer travelmate 2480?
No if you have a 32 bit processor, you use 32 bit OS's. Your locked in buy your hardware.
Apr 29, 2013 | Acer TravelMate 2480 PC Notebook
I have acer travelmate 800 series,the notebook stopped working so i bought a new motherboard and power switch still the laptop will not start. it is getting power but wont start, i have tried taking out...
Have you tried powering it up without any periferals?? take out the RAM, HDD, WIFI, CD, etc... I've seen a BAD wireless network card preventing the system to power up... if it seams to power up than put back stuff in one by one starting with the RAM to see what periferal is causing the problem... If not than it could be the CPU...
Good Luck!
Mar 25, 2011 | Acer for Acer TravelMate 800 Series...
Can you do a cpu upgrade on Acer Travelmate 2480-2968? If so what type of intel CPU will work on this machine?
The following CPUs are supported by the Acer TravelMate 2480:
Intel Celeron M processor 410/420/430/440/450 (1 MB L2 cache, 1.46/1.60/1.73/1.86/2 GHz, 533 MHz FSB) or higher.
So, based upon the speed of the CPU you currently have, you can decide whether you need a CPU upgrade or not.
Nov 04, 2009 | Acer TravelMate 2480-2968 Notebook
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
Upgrading laptops
Best upgradeable laptop right now are the high end Dell XPS model line. Hope this helps.
Dec 24, 2008 | EliteGroup K7S5A Pro Motherboard
Cpu f6 screws
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
20
Aug 28, 2008 | Acer TravelMate 290 Notebook
User manual
Here is the user manual: http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/3760015b151b4a57482570000012d348/$FILE/TM2310-ENG-OLM%5B1%5D.pdf
Acer's server is a bit on the slow side so be patient.
For security reasons password solving can't be done, you will need to "Recover" the hardrive by re-installing the OS through the recovery partition if you have one or by using the recovery cd's.
Cheers
Jun 11, 2008 | Acer TravelMate 2300 Notebook
Acer laptop dead
try to take it to anyone who knows electronics to check the motherboad for you, its not a big problem had it been its Malawi I would have done for you.
epamost@yahoo.com
Mr CPU.........
Apr 07, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
