How to set up brother mfc-465cn to computer,and telephone line
I only have one phone line . i need phone line for phone ,computer and printer.everytime i take out the phone line connection from computer tower i'm having problems getting on line,also i won't get dial tone from phone.i get dial tone only when i have phone line and the computer line in printer. 'i'm very confused. please help candy
SOURCE:
Mix-it-up
  • 832 Answers
SOURCE: Brother mfc-5840cn
press menu then start mono then 4 times arrow-up (Tel index). machine will be in maintenance mode. press 8 then 0 (zero) then press the start mono button until display shows error A1: xy. Press the right arrow (Speaker +) button. What error codes do you see? (Machine saves the last ten errors). plz post here again.
To leave the maintenance mode press 9 then 9.
Posted on Nov 02, 2007
  • 306 Answers
SOURCE: setting up my mfc-440cn brother
Im guessing the "Brother" is a printer....the Printer should connect using a usb port, Unless its an ethernet port for the printer then you will need a router to connect both printer and computer. Are you using a High Speed connection or a dial up connection?
Posted on Nov 17, 2007
  • 84 Answers
SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Posted on Feb 13, 2008
  • 268 Answers
SOURCE: wireless connection to xbox
I understand this can be a little confusing , especially if you have not done it before!! I can explain to you the steps , but it is a little tricky and I don''t want to completely confuse you!
With that being said , take a look at the article I posted below. It is directly from Microsoft and is a step by step guide for this , including pictures to make it easier. When you open that link scroll about half-way down to the section that says :
"How to connect an Xbox 360 to your wireless network"
There you will see all the info you need , along with the pictures I mentioned to make it easier for you!
I hope this helps , and if you need further help feel free to leave a comment with the issue and we can clear it up...
Posted on Oct 01, 2008
SOURCE: Connecting my Brother MFC 440cn printer to the internet
It turns out my dad had the usb cable plugged into the ethernet port instead of the usb port. It works fine now.
Thanks for the response.
Posted on Dec 02, 2008
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
How to install brother printer mfc-465cn
Here is a link to Brother to download the software / drivers for the MFC-465cn. You will need to select which Operating System that your computer is running in Step 1:Select OS....
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc465cn_all
Mar 24, 2010 | Brother MFC-465CN InkJet Printer
I have a brother mfc 6800 and do I need a telephone line on it?
You will need a phone line connected to the MFC 6800. If you have a separate line for your fax number, make sure you connect this line to your MFC 6800. If you have a different ring, but on the same line as your phone number, you'll need to set up your MFC to utilize the distinctive ring (see the manual for setting this up).
Jan 26, 2010 | Computers & Internet
Brother mfc-465cn opening raster file failed
Try downoading the drivers from the apple web site. You would need the brother 1.1 drivers download.
Remove printer then added it again
Jan 02, 2010 | Brother MFC-465CN InkJet Printer
I have a brother MFC 465CN printer. Is it
It is compatible according to the Win7 compatibility Center. If you have any problems, check your cables or network settings.
( http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Hardware&p=Brother%20MFC-465CN%20All-In-One%20Printer&v=Brother&uid=MFC465CN&pf=0&pi=0&s=465CN&os=32-bit ; the 64 bit OS will also work fine)
Dec 09, 2009 | Brother MFC 420CN All-In-One InkJet...
Mfc 465cn has black line
Open the document feeder and clean the scanner glass.
Feb 12, 2009 | Brother MFC-465CN InkJet Printer
Fax
go to brother.com and you can down load the manual
Sep 20, 2008 | Brother MFC-465CN InkJet Printer
Receive a fax on a line sharing a answering machine
I need to know how to connect the fax to the telephone unit that has an answering machine.
Aug 29, 2008 | Brother MFC-465CN InkJet Printer
Open Questions:
Computers & Internet Logo
706 people viewed this question
Ekse
Alun Cox
