Question about Dometic Rooftop RV Air Conditioner
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
  • Dometic Master
  • 6,674 Answers
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
Posted on May 21, 2011
I have problems with my heat in my pop up camper on the roof runs but won"t heat up what would be wrong with it and can I fix it
Posted on Oct 29, 2012
Coleman Mach 48000 series roof top A/C in my camper & recently it's been dripping heavily inside the camper. We looked at the top & inside for a clogged line & can't find anything, suggestions?
I had the same problem but it wasn't a clogged drain line, it was the gasket between the roof of the camper and the AC unit. The gasket had shrunk and pulled apart allowing rain water in. To make sure you don't have a clogged drain line when using the AC do you notice water dripping off the camper anywhere besides inside? You should have some drips somewhere on the outside.
Jul 18, 2017 | RVs
I have a duo therm model 57915 522c1 air unit on my camper. Turned it on and was working fine. Then it shut down. Doing nothing now. Any ideas?
water draining from condensate hole ??? if not its shut off on high water level (you don't want water dripping into your nice camper right ?)
bees are my nemesis on these they love to build mud nests in the drain holes and stop em up !!
Aug 25, 2016 | Heating & Cooling
Why is my roof rv a/c leaking condensate water inside Pop Up
if everything has been cleaned properly, is trailer level. good luck!
Nov 04, 2015 | Heating & Cooling
RV AC is working fine, but the water is leaking from the ceiling Where is the drain tube on the unit, The AC unit is a roof type, Duo Therm serial # 43404934, Part # 3105459
Normally, the condensate will drain out of the unit onto the roof and off the edge to the ground. Remove your cover inside (probably 2 screws) and tighten the 4 bolts you will find inside. If they are tight, go to your RV supply place and get new roof gasket. Remove the AC and insert the new gasket and resecure the AC to your roof.
Thanks for your question @ FixYa.com
Jul 26, 2011 | Dometic Rooftop RV Air Conditioner
R we still talking about the duo therm briskair roof &celing conditioner with no place to put the freeon mamawwyatt122142@aol.com
There are usaully no places to refill Rv Ac units. You have to have very particular parts to fill most units..Tell me your exact Issue..
Aug 05, 2010 | Dometic Rooftop RV Air Conditioner
Duo-therm brisk air AC unit leaks water into my RV when it rains
take the cover off and make sure the drain line is clear on top off RV.
Nov 15, 2009 | Ovens
Duo therm briskair conditioner
check your power supply, 5 minutes is about the time it takes to blow a breaker
Aug 11, 2009 | Heating & Cooling
I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Roof leak 1999 jayco eagle mod 8333-8715
It is best to get self tapping screws and relocate them. The water leak has destroyed the wood where the factory screws were and a bigger screw will not work. Just move them over a few inches. If the leak was bad enough all of the wood will be routed and should be replaced. Is this on the top seam where the rubber meets the aluminum or is it on the side of the camper near the top?
Mar 24, 2009 | Sport & Outdoor - Others
Dometic Rooftop RV Air Conditioner Logo
605 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
