Question about Dometic RM2652 Refrigerator
How to remove and replace Thermester - Dometic RM2652 Refrigerator
    Genius:
  • 1,156 Answers
If you discover that your refrigerator is not getting cool enough or not cooling down at all, then it is perfectly possible you may need to change your refrigerator thermostat. If you wish to test the thermostat to make sure whether it is working or not, then you should change the refrigerator temperature to something a bit cooler than normal. If the thermostat is working okay then it will take a few hours to maintain a steady temperature. However, if it doesn't then it will need replacing.
Step 1 - Preparation for Replacing Thermostat
The first thing you should do before undertaking this work is to turn off the appliance from the mains. This is something that should be done with all appliances of an electrical nature for safety reasons. If you find that the plug is hidden away behind cupboards or panels then you should turn off all the power to the entire kitchen.
Step 2 - Locate the Thermostat
Next you need to find the thermostat and where it is positioned inside the refrigerator. For the majority of refrigerators where they have a freezer on the top level, the thermostat will be right at the back of the fridge or on the roof of the fridge on underneath the freezer panel. If you have a refrigerator that is next to the freezer then the thermostat should be found in the freezer at the back.
Step 3 - Remove Shelving
Ensure that you take out all frozen food and shelves that are in your way that many prevent you from working on the job with plenty of space to move about in. In order to take out some of the shelves on the inside you may have to make a few screws loose and take out clips holding it in place.
Step 4 - Remove Wires
There will be some wires that are attached to the thermostat and these need to be pulled away gently using the pliers. You should make sure that you are extremely careful doing this as if you pull too hard or grip the wires in the middle then they could break under the pressure.
Step 5 - Take the Broken Thermostat Out
You are now in a position to take the old faulty thermostat out of the refrigerator after taking out the remaining screws and clips. If the thermostat is around an evaporator tube then you should take care then removing as this may cause damage.
Step 6 - Install the New Thermostat
Once you have gone through all the steps, then you should put the new replacement thermostat in to the refrigerator in the same place as the old one. Ensure that you screw it into place and reconnect all the wires. Ensure that when you have done this and put the panel back on to the thermostat that it is secure. Next put back any shelving you took out before replacing the thermostat.
Step 7 - Test the Refrigerator
Finally, turn the power to the refrigerator back on and then wait for the refrigerator to cool down again to a lower temperature. If the new thermostat is working correctly then it will kick in and maintain a steady temperature within your refrigerator.
I hope this will help in solving the problem....
Posted on May 17, 2011
Replacing quarter glass on left side on 2005 pontiac gto
Remove the door opening weather-strip. Refer to Door Opening Weatherstrip Replacement in Doors.
Remove side sill trim plate. Refer to Door Sill Plate Replacement in Interior Trim.
Remove the lower quarter panel trim. Refer to Rear Quarter Trim Panel Replacement in Interior Trim.
Remove the center pillar upper trim panel. Refer to Center Pillar Upper Trim Panel Replacement in Interior Trim.
Remove the quarter upper trim panel. Refer to Rear Quarter Upper Trim Panel Replacement in Interior Trim.
Remove the center pillar outer applique. Refer to Center Pillar Applique Replacement in Exterior Trim.
Remove the roof drip molding. Refer to Body Side Roof Drip Molding Replacement in Exterior Trim.
Important: It is necessary to use new nuts when reinstalling the quarter window.
Remove the nine quarter window nuts (1), securing the quarter window assembly (2) to the body opening.
Caution: When working with any type of glass or sheet metal with exposed or rough edges, wear approved safety glasses and gloves in order to reduce the chance of personal injury.
Important: When removing the quarter window from the body opening make sure that the attaching pins are clear of the outer body.
Remove the quarter window (2) from the body opening.
Remove the rear seat cushion. Refer to Rear Seat Cushion Replacement in Seats.
Remove the rear seat back. Refer to Rear Seat Back Replacement in Seats.
Remove the door sill plate. Refer to Door Sill Plate Replacement .
Remove the 3 quarter trim panel retaining screws (1).
Starting at the lower edge of the trim panel and moving alternately clockwise and counterclockwise, pull outward on the trim panel to disengage the eight rear quarter trim panel attaching clips (2).
Remove the quarter trim panel from the vehicle.
Remove the 4 radio speaker grille speed clips (1), securing the speaker grille.
Remove the speaker grille (2).
Remove the rear quarter trim panel insulator (1), from the back of the quarter trim assembly (2).
Remove 7 rear quarter trim panel armrest retaining clips (1).
Remove 7 rear quarter trim panel armrest retaining nuts (2).
Gently pry the quarter trim panel armrest insert assembly (3), away from the rear quarter trim panel and remove.
You mite look for a video on youtube !
Dec 23, 2016 | Pontiac Cars & Trucks
Tip
95Xi Crosstrainer Crank Arm Cover Replacement
About This Video
Crank Arm Cover Removal and Replacement Video for the 95Xi LifeFitness Crosstrainer
  • This video demonstrates how to remove and replace a Crank Arm Cover on a Life Fitness 95Xi Crosstrainer elliptical
Necessary Tools:
  • Philips Screwdriver
  • 5/32" Allen Wrench
  • 2MM Allen Wrench
  • T25 Driver
  • T50 Driver
  1. Remove the main shrouds as seen in the shroud replacement video
  2. Remove the outer link cover as seen in the outer link cover removal video
  3. Remove the pedal lever assembly (as seen in Sportsmith's Pedal Lever Replacement video) on the side where the crank arm cover replacement is needed
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Replace the parts in reverse order
LifeFitness 95Xi Crank Arm Cover Video Removal and Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
2006 Tahoe. Where is the auxiliary blower motor located?
It is located behind the right rear quarter panel , In the back right of the interior !
Remove the right rear quarter trim panel. Refer to Rear Quarter Trim Panel Replacement - Right Side in Interior Trim.
Removal Procedure
  1. Remove the rear seat. Refer to Rear Number 2 Seat Replacement or Rear Number 2 50-50 Seat Replacement in Seats.
  2. Remove the Third Pillar trim panel. Refer to Third Pillar Trim Replacement .
  3. Remove the garnish molding. Refer to Body Rear Corner Garnish Molding Replacement .
  4. Remove the door sill plate. Refer to Liftgate Door Sill Plate Replacement .
  5. Remove the quarter panel trim screws.
A lot involved in this but not to difficult !
  1. Remove the rear door sill trim plate. Refer to Front Side Door Sill Plate Replacement or to Rear Side Door Sill Plate Replacement .
  2. Remove the lower rear seat belt cover and bolt.
  3. Remove the trim panel from the vehicle.
Remove the sill plate. Firmly pull the sill plate up and out from the retainers.
Remove the sill plate from the vehicle. Start from the front of the door sill. Use a flat-bladed tool in order to pry the door sill plate.
Rear Side Door Sill Trim Plate Replacement
Use a flat-bladed tool in order to pry the door sill plate. Remove the sill plate from the vehicle.
Remove the rear upper garnish molding. Refer to Rear Upper Garnish Molding Replacement .
Pull down on the upper corners of the garnish molding in order to disengage the retaining clips. Pull in order to disengage the remaining retaining clips. Remove the rear corner garnish molding from the vehicle. Inspect the rear corner garnish molding for broken or missing retaining clips. Replace the retaining clips as needed.
Good Luck ! Fun job !!!!!
Jun 07, 2015 | 2006 Chevrolet Tahoe
Where's the fuse for the fan main box shows no fuses for the fan
what do you call main box . most vehicles now have 2 one under dash and one in engine compartment it could be a relay bad or the thermester (sp) that tells it when to run or not
May 14, 2015 | Cars & Trucks
How to install replacement sunroof motor on a 1999 Pontiac grand prix
Important: This sunroof system is timed from the factory in order to allow the actuator to shut off automatically when the sunroof window reaches a certain position. Use extreme care when removing the actuator from the sunroof module. This may cause the timing to be thrown off. This may damage to the sunroof. Anytime the actuator needs to be removed from the module, ensure that the sunroof window is in the fully closed position.
Remove the sunroof window. Refer to Sunroof Glass Panel Replacement .
Slide the sunshade fully rearward. Move the sunroof window to the vent position. Remove the sunroof screws (two on each side). Remove the sunroof window from the module.
Place the sunroof module in the fully closed position. Remove the headliner. Refer to Headlining Trim Panel Replacement in Interior trim.
Tools Required ?€¢
J 38778 Door Trim Pad and Garnish Clip Remover
J 2772-C Headliner Installer
  1. Remove the sunshades. Refer to Sunshade Replacement .
  2. Remove the overhead console, if equipped. Refer to Roof Console Replacement .
  3. Remove the sunshade retainers. Refer to Sunshade Anchor Replacement .
  4. Remove the power sunroof switch, if equipped. Refer to Sunroof Switch Replacement in Roof.
  5. Remove the sunroof trim lace, if equipped. Refer to Sunroof Seal/Molding Replacement in Roof.
  6. Remove the dome light, if equipped.
  7. Remove the coat hooks. Refer to Coat Hook Replacement .
  8. Remove the assist handles. Assist Strap Replacement
  9. Remove the rail lamp. Refer to Roof Side Rail Lamp Replacement in Lighting.
  10. Remove the windshield side garnish molding. Refer to Windshield Pillar Garnish Molding Replacement .
  11. Remove the upper quarter trim panels. Refer to Rear Quarter Upper Trim Panel Replacement .
  12. Remove the center pillar upper trim panel. Refer to Center Pillar Upper Trim Panel Replacement .
  13. Pull down on the door opening weatherstrip seal on both the front and the rear doors.
  14. Remove the 2 rear retainers (2) using J 38778 Door Trim Pad and Garnish Clip Remover. Disconnect the headliner electric harness at the right side of the rear window shelf. Rotate the right front seatback to a horizontal position. Remove the headliner from the vehicle through the right front door.
Disconnect the electrical connector from the actuator.
Important: Before removing the actuator, ensure that the pins J 41718 are tight and holding the cable.
Thread the J 41718 into the front sunroof window screw hole in order to retain the cable adjustment. Remove the sunroof actuator screws. Remove the sunroof actuator from the module. Did you look for a video on youtube ?
Feb 27, 2015 | 1999 Pontiac Grand Prix
What is the code upside down F and a 5 ?
It is a TS error, I thought the same as you that it was aT5...lol...Anyways it is either the Thermester or the controller board. If you can afford it get a tech out there so they can diagnosis the problem ASAP. We didn't and ended up buying a new Thermester and our old one was just fine, it was the controller board that was dead since we put wet cloths on top of the dyer and the water leaked down on the board.....Wont be doin that again... :^)
Aug 01, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
MY KONICA 7115 COPIER HAD DISPLAYED ERROR C05 00 CAN YOU HELP ME
turn off the machine and hold down the STOP botton while turning on the power .hold for 5 seconds .
than should reset the code .if the code pressist that you have a bad thermester in the fusing unit.
good luck
May 01, 2010 | Xerox CopyCentre C118 Copier
Harmonic balancer
what are the steps to removing a harmonic balancers
Oct 18, 2008 | 1997 Chevrolet Corvette
Dometic RM2652 Refrigerator Logo
1,640 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
