Question about RCA H125 MP3 Player
RCA 125A - purchased Nov 2008 (or 2007), used a few times, then stored properly, then when I tried to used it a few months ago, received 'file system corrupt'... when I hook it up to my computer, receive error message that unit/device is unrecognizable... same message from 'My Computer' & 'Device Manager'. Info from web posted by people with both this and 115, say that I need to reformat it, but I can't get to that point
  • 5 Answers
SOURCE: File Sytem Corrupted!
The dreaded "File System Corrupted" error is one that comes time and time again. Did you drop the player or hit it by accident? If so, then the pin connecting the battery to the micro hard drive has probably been disconnected. You can removed the back of the player with a screwdriver, but you risk tearing off the S/N sticker. If you decided to do it anyway, remove the back of the player and then simply fit the multi-pin connector back into the hard drive. Replace the back and screw it in, and then turn it on to see if it works. I did this with my old RD2762A, and it worked like a charm. Hope this helps!
Posted on Aug 30, 2007
  • 5 Answers
SOURCE: screen says "file system corrupted!"
okay to fix this problem you need to do this steps..
1.) Try to press and hold the PLAY button while connecting it to your computer.
(This will allow the device to connect to the computer in safemode.)
2.) Once connecting to the computer is successful, download the upgrade firmware to the device, and follow the upgrade steps.
Upgrade firmware can be found at the link provided below:
if you have any more questions feel free to email me @
Posted on Nov 20, 2008
  • 8596 Answers
SOURCE: Tried to download RCA EasyRip installer, says file is corrupted.
You can find the software at
Posted on Dec 28, 2008
I found Billy K. Dec.8 2007? the best advice...My opal is a m4002. I think Windows XP - Media 10 stop seeing my device and kept seeing it as MTP device... and the opal needed new firmware becuase of it.
Even though I was using Yahoo Jukebox for loading my opal.... it was my computer that no longer recognized the Mp3 player. I tried to go back to a earlier version of Media Player - that didn't work... and caused other errors.... did a system restore and tried again.
SEE Below for how I got it to recognize and hopes this helps others... all together took me 2 days to get this issue fixed.... whew.
--- Billy's advice worked but had to finagle it a bit - below I edited what he had to what I did......
  • I downloaded onto a PC the firmware update for the M4002.... sorry don't have the link handy but you can find easily enough - found 2 versions out there version is the most current. (The RCA video site would not work as it tried to re-route me to and there was nothing there to help me regarding the opal!!) - version 1.8 is a earlier one.
  • Anyway with that downloaded - I attached the the Opal to computer. My computer started trying to see the device but it had errors... It was kinda like hipcupping.... I ended up going into the View system info - clinking on Hardware - device manager - portable device (which had the error message on it) highlighted MTP - right clicked and then "disabled it" The computer then settled down and I think it changed from MTP to Opal.
  • Then I went to the firmware update which After installing the firmware package in the PC, you get an install screen for the new firmware with a format option for the OPAL. I selected that option, but the "start" button was greyed out as the PC still didn't see the OPAL. I pressed the reset (toothpick in the back of the OPAL) for about 15 seconds, than held down the Opals "Menu" button and waited (Keep holding that menu button until you get the firmware/format screen to allow you to click on the Start Format button..... Eventually the software recognized the OPAL, and started to format it. (again get ready and have your mouse over that start button as I had to do this a couple of times before I could momentarly have a chance to hit the format start button. If I wasn't fast enough to click it - it would grey out again... so kept resetting opal then holding down that menu button until the "start format" was avaible to select....
    If you get a dialogue to restart the PC, press NO! You have to read the instructions that come with the install. Eventually I reformatted the drive, and installed new firmware. (I did not get a restart PC - but left Billy's advice in case others do.
  • ANYWAY - it works Great now..... Sorry this seems lengthy - it was relitivly easy after I figured out or just kept trying to do the reset on the opal and hold the menu button until the firmware allowed me to hit start.... Good Luck. Also - not sure but I think going into the hardware device manager was also a key for me..
Posted on Jan 28, 2009
my rca jet s2001a whem im trying to on my device it displays flash error and to format with sigmatel formatter, i cant find such formatter pls help me out my email id is
Posted on Oct 18, 2009
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Aug 21, 2017 | Health & Beauty
I have a Dell Latitude D600 that worked perfectly fine, until around a few months ago. It starts up normally and takes me to a DELL startup and then takes me to a black screen that says this: Windows...
Have you tried starting windows using the safe mode, and if it does start up in the safe mode, did you try to restore your system to a previous date that it was working properly. Sometimes when you have your kind of problem, even though several months have past, the calender for restore is lock too at the time your system went down. this gives you the opportunity to restore to a date close to when your system failed.
Before you try restore, make sure you do not have a virus that has corrupted you system, run a virus scan first. If you haven't done so I suggest downloading Malwarebytes anti-malware that is free online, it works very well, and Microsoft uses it for there systems.
I hope this is helpful, good luck, I hope you don't have to purchase the setup CD.
Jul 13, 2011 | Dell Latitude D600 Notebook
Received for Christmas 2010. Worked great! Few nights ago, made something to eat, and it shut off. Light, clock, everything. After a few minutes, it came back on. Used it last night, same thing. But this...
The joys of purchasing items with a bought out warranty. Check the plug and contacts on the fuse.
You could either call a microwave repairer and pay for callout and repair or purchase a new one.
May 30, 2017 | Oster OGG61403 Microwave Oven
I need my unlock code for lg u990 imei 358203- 01-2052260
Try to get free LG KU990 Viewty unlock code from promo event at third party sites. Here you can try on this store, a few months ago they have free unlock code event, but you must follow their instruction. If you so urgent looking lg unlock code, you can try buy from online store according to your models and network card. It will not takes so much time.
May 02, 2011 | LG KU990 Viewty
RCA LCD 42Lfhd37 Unusable signal
have you tried calling to the store you purchased it from and seeing if they will print you a new receipt. alot of stores will do this for you. also some times the store will cover the tv under manufacturers warranty and will send someone out to your house.
hope this help
please feel free to ask if you have any other questions.
Apr 06, 2009 | RCA L42FHD37 42 in. LCD HDTV
RCA DVR-40 Directv receiver will not make a call to Directv
i believe you have to slow the modem speed down. contact directv 800-531-5000 on instructions how to slow the modem speed. tell them you are getting "service not answering" hope this helps!
Mar 22, 2009 | RCA DVR-40 DirecTV DTV Receiver / 35-Hours...
The Rear Wipers on my 2001 1500 Chevy Suburban Stopped working
Unplug the connector at the rear wiper motor, turn the switch on and probe the wires with a test lamp, if you have power back there you more than likely have a bad motor. If there is no power start checking fuses they are all labeled easily on the back side of the fuseblock covers both on the dash and underhood. Good Luck!!!
Mar 15, 2009 | 2001 Chevrolet Suburban
Retrieving files from external HD
take it to one of your friend computer & try it out, if it works you know the drive is ok and the problem is in the pc
good luck
Mar 29, 2008 | Computers & Internet
The files are corrupt
Was the player disconnected before disabling it correctly? In the bottom right in the system tray the usb icon with a green arrow is able to be right clicked and select "Safely Remove Hardware" to safely remove most players. I personally got frustrated, forgot to do this and removed my Pearl hastily. After that it has yet to function properly. The system is corrupted and no files register even though there are still 967 mb worth of music on the player.
So this is not a solution but rather a probable cause to the problem. I have yet to find a fix for this except to dispose of the player responsibly and purchase a new one.
Feb 29, 2008 | RCA TH1101 MP3 Player
RCA H125 MP3 Player Logo
55 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
