Question about Canon PIXMA iP3000 InkJet Photo Printer
Computer cannot detect printer - Canon PIXMA iP3000 InkJet Photo Printer
    Novelist:
  • 100 Answers
Hi make sure that all the connections to ur printer are set right and firmly and make sure to install the CD that came with ur printer and select the correct printer in the printer option menu and try this should definitely work out for u if u don't have the CD,u can manually download it from the internet via the Google search tab and select cached to view any page.was this helpful to u if yes please do rate my solution. with warm regards-bonefirediv.
Posted on May 17, 2011
I want to scan a copy to my computer. the error messae on my printer says no computer found.how do i connnect my printer to my computer
uninstall the printer driver then connect it with computer if computer detect the printer then install it and print the documents.
if computer not detect the printer then connection media like USB cable or wireless connectivity setting
Apr 17, 2015 | HP Photosmart 5510 Wireless e-All-in-One...
I have just bought a new computer with Windows 7 as my o/s. I cannot get it to detect my Pixma MP830 printer.
How can the computer detect the printer if you have not loaded the software. Therefore insert the CD which came with the printer and load the software/driver.
Aug 29, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Printer is not detected by the computer after connecting the printer to the computer.I have installed the printer driver but still there is no respond from either the computer or the copier
Please change the USB cable and plug it to another USB Port on your computer and restart the computer.
Make sure that printer is ON while re-starting computer.
Mar 21, 2010 | Toshiba E-Studio 160 All-In-One Laser...
My olivetti anyway printer worked fine with my laptop,but will not work with my new pc,just reads no device detected
attach printer your new pc. pc on and printer power on. detect your printer than install driver in your new pc through printer driver cd.
if no detect your printer than right click my computer than properties than hardware than device manager than select any and top option scan for hardware changes, detect your printer and install driver.
Mar 02, 2010 | Office Equipment & Supplies
Doesn't recognize the USB cable anymore. I have replacexd it twice and it won't let me install the printer.
There's a big chance here that the problem is not with the USB cable but with the USB port of your computer or with the printer itself, first that you can do here is to try connecting the printer on a different SUB port on your computer and check if it will be detected now by he computer but if still not better if you can try this printer to a different computer and check if it will be detected because if it will be detected on different computer so the problem is with the USB port of your computer.
In a point that the printer will still not be detected by different computer so the problem here is with the printer itself and the printer needs servicing already.
Feb 12, 2010 | Lexmark X5470 All-In-One InkJet Printer
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
Green light is on, but will only print test page. Cables are in place. Printer is about 4-5 yrs old.
you have a usb port computer problem,with computer and printer ON plug theUSB cable into a different usb input on your pc,your computer should detect the new device or printer attached and makes some alert noise if it does not detect the printer then fix your windows operative system
Jul 29, 2009 | HP LaserJet 1300 Printer
Is hooked up to computer but says it not hooked op to computer will no print off computer
this could be a communication problem.
you need to make sure that the cable that you are hooking up is the one that came with the printer,also you may need to plug the cable into a different port and check if the computer detects it.
{take intensive care in case you follow these steps. }
there is an entry for USB printing support
and USB composite device in the device manager under USB devices, if you remove these entries. the computer will start detecting the plug and play device and hence will detect the printer.
Jun 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Epson LX-300+
did you share printer on Main PC ( the PC where are the original drivers )?
Under printer properties, mark "share printer" and apply and ok.
Hope tha helps!
Dec 30, 2008 | Epson LX-300 Matrix Printer
Just got a computer with Vista I downloaded my lexmark X1155 driver. it shows as the default. when I attempt to print it says can not communicate with printer. Checked usb cable and connection. restarted...
As usb is devices is ready detected by vista and its confirm the registry for the device and its not detected while loading driver
suggested to remove the usb cable and remove the previous driver information reinstall the driver without connecting the printer and power on the printer aftre driver is loaded and it will be detected by system
can also check the same procedure with different computer for testing , as the port is working ok at printer end
Jun 09, 2008 | Lexmark Office Equipment & Supplies
Canon PIXMA iP3000 InkJet Photo Printer Logo
old marine
old marine
