Question about GE Profile 25.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black
GE TFX24e side by side and a small pool of water runs out from under the freezer side on to the floor we sop it up with a sponge. I noticed the drain hole, water will not go through, it builds ice in the area - posted in Refrigerators
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 17, 2011
GE SIDE BY SIDE FRIDGE HAS WATER LEAKING ON FLOOR FROM FREEZER SIDE
There is hole behind the freezer panel that the water should drain thru . Use a small hose in the hole and blow thru to cleam drain .
Aug 14, 2012 | GE Refrigerators
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
Our GE side by side model GSS25SGRE is leaking water toward the front of the unit. We have pulled it out to see if it was condensation and that is not the problem. At times there is a lot of water that...
okay, my name is marclavoris, what happens is your refrigerator goes into defrost, the heaters comes on and melts the freon off the coils, the water goes down in the drain, which you will see on the freezer side at the very bottom of freezer, you may need to take off inside back panel to access the hole. it is clogged up with alot of debri, so when it is backed up, it overflows under your bottom tray, it then goes into defrost again and it pushes water on your floor. To solve problem, clear the drain in the freezer
Sep 12, 2009 | Refrigerators
How do you unclog the condensation drain on a GE gss25wgma model refrigerator? have water pooling and freezing on the freezer floor, spilling out onto the floor within days after removing it. Thanks!
usually the drain hole underneath the evaporator in the freezer section can restrict with anything from ice to bugs. take a wire hanger and try to run it all the way down into the drain pan. if you have ice then try to poor cool water over it to defrost ice. then use hanger
Jun 22, 2009 | GE GSS25JFM Side by Side Refrigerator
Water pools on floor
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
May 24, 2009 | GE Refrigerators
Zanussi fridge /freezer
the drain located under the evap. maybe stopped up pour some boiling hot water into it and see if it drains underneath into the drain pan
May 06, 2009 | Zanussi ZEBF250W Bottom Freezer...
Water leaking - GE Profile Refrigerator, Model: TPX21PRX
Check to see if the drain at the bottom of your freezer is plugged. When the refrigerator goes on defrost, the water has to go somewhere. Look below the coils in the freezer section and see if there is ice in the drain.
Jul 15, 2008 | GE Profile 20.7 cu. ft. CustomStyle...
Kenmore 5842 side by side crapped out - approx. 9 years old - garage fridge
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Mar 12, 2008 | Kenmore 58422 / 58429
Water under side by side hotpoint
You can deal with it once for all by pouring warm water into the drain pipe to clear any blocks and sopping it off with a sponge..
Oct 29, 2007 | Hotpoint HSS25GFP Side by Side...
GE Profile 25.5 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black Logo
259 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
