Question about GE Cameras
Whem I turn on my camera I can nor take a picture because a message appear "white protection" I dont know how to use my camera again
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about SDCards and how to unlock and lock SDCards. If youare getting a memory card locked message then check this out.
How to UnlockSD Card heatman101
Posted on May 17, 2011
Memory card blocked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Memory Sticks have a slide switch on the back, near the contacts. Slide the switch away from the "LOCK" position.
Jul 08, 2012 | Sony Cybershot W330 Digital Camera
Sdcard protect: when I plugg on camera an error message appears on screen " SDcard is protected " I tried to change SDcard and the same message related to sdcard appears . I can not unprotect...
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 25, 2011 | Intova CP8 Digital Camera
Cannot take a picture--message: "your card is
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 02, 2011 | Casio Exilim EX-Z120 Digital Camera
What does "This memory card is write-protected
On the SD card itself is a write protect switch - it's on the side. Check the switch to see if it's in the protect position.
Jan 25, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
As I turn on the camera, a message of "this card
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jan 06, 2011 | Casio EXILIM 8.1-Megapixel Digital Camera...
A "Protected card" message keeps
To format your card is a method of outputting data in a specific format. You can do that from the digital camera, in the menu look out for the Format option and use it, or you can plug it into a computer (through a card reader) and once it shows up in My Computer, right click on the drive letter and select format.
Dec 29, 2010 | Fuji Cameras
I have a "! Protected Card" message on my screen
Look at the memory card again. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 07, 2010 | Fuji FinePix S2000hd Digital Camera
Fujifilem Z20fd I cant turn the card protection off which appears
Is your flash working? Do you have the flash turned on?
Jul 11, 2009 | Fuji Finepix Z20fd Digital Camera
Write Protect error and I think all my pics dissapeared!
If you are using an SD card, it could be possible that the Write Protect tab (the yellow tab on the top right) is in the 'lock' position. Slide it back and try again. If this does not work, make sure you are using the card and not the internal memory to store images.
Feb 05, 2009 | Olympus MJU 400 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Cameras Logo
37 people viewed this question
Top GE Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
