I have a Mitsubishi WS-65511 with error code 22. I have been to http://www.tvrepairworld.com/mitsubishi_repair_kits and to TVrepaitkits.com and have no clue which kit I need, please let me know which one is the kit I need. Thank you!
  • 3,459 Answers
You need a convergence repair kit - blink code 22 is almost always a convergenc issue. Sometimes it will look 3D and sometimes it will not show any video and have a 22 error code. TV Repair Kits has what you need.
Posted on May 18, 2011
  • potv9662 May 18, 2011
    Will this fix the TV from turning immediately off after just turning on the set. That is why I was confused.
  • SD Tech
    SD Tech May 19, 2011
    CONTRARY to what someone told you--if it is 2,2 error code, one or both of the 5 amp pico fuses for the convergence circuit are bad---with 2,2 the set will not power up---it detects no voltage for convergence and does not allow set to come on.
    This means whatever the set uses for convergence IC's they are bad--they get the fuse--some models use STK392-570 (2) OR STK392-040 (2) OR even a single STK393-110 chip.
    SD TECH
Ws-65909 power light goes out after 3 seconds no sound or picture
Thats the code which normally indicates a convergence failure you can get the WS55909 - WS65909 Convergence repair kit which also has instructions from www.tvrepairworld.com its listed under the Mitsubishi repair kits catagory.
Oct 26, 2012 | Mitsubishi WS-65909 65" Rear Projection...
Tip
Mitsubishi WS-65511 Manual Download
Download Mitsubishi WS-65511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-65511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Reset Mitsubishi WS-65511 VChip Password
Bypass Mitsubishi WS-65511 Front Lock
on May 03, 2010 | Mitsubishi WS-65511 65" Rear Projection...
I have a mitsubishi ms-65511 and we had a poweroutage for several hours today and now the tv won't turn on and I am getting a continuous green light of death ... HELP
Thats caused by weak capacitors on the DM board which cannot recharge after the power has been restored. Very inexpensive repair . The WS48511 - WS55511 DM repair kit from www.tvrepairworld.com has the capacitors and the CD with repair instructions which should solve the issue of the steady blinking green light.
Oct 11, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Power comes on and the back off.... Code is two flashes then paus then two flashes.... Where do I check to find fuses to the convergence?
This is a short protect error code. The affected parts is not only the pico fuses but also the convergence IC(STK393-110) that is mounted on the large aluminum heat sink. I have a link where you can buy the repair kit that includes steps-by-steps instructions that will guide you in the whole process of repair. Click the link below.
Mitsubishi V21 chassis(WS-65511) convergence repair kit ($42).
Scroll down to V21 chassis convergence repair kit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Sep 13, 2011 | Mitsubishi WS-65511 65" Rear Projection...
How do I fix the 2,2 error on the ws-55819?
install the convergence repair kit for your model. The 22 error is almost always caused by shorted Convergence ICs and blown picos. You can get the convergence repair kit for your model at www.tvrepairworld.com
Aug 05, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ms-65511 green light continuos blinking....
Thats a very common problem caused by failed capacitors on the DNM power board. Repalcing them should solve the issue. You can get the DM repair kit for your model at www.tvrepairworld.com which contains the upgraded caps and the CD with repair instructions
Apr 27, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Ws-65511 error code 22 sd tech
error code 22 is an indication of a short in a low voltage power supplies
Oct 13, 2010 | Mitsubishi WS-65511 65" Rear Projection...
I have a Mitsubishi Ws-65511 65" and the green light on front panel blinks continuesly and the tv will not turn on with the power button or the reset button on the front panel. If we unplug the power cord...
The Bulb in the unit needs to be replaced. To confirm, look in the manual for the set and it will explain the flashing lights by the numer and duration of flashes. Hope this helps.
Jun 07, 2009 | Mitsubishi WS-65511 65" Rear Projection...
How many times does it blink? Or is it a continuos blinking that doesnt stop? Let me know and I will be able to help you with it.
Apr 30, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
