My 36' Philips Magnavox Smart Plus Series television always shows up so dim whenever I change it to the "AUX" ch when playing PS3. It will be normal for a second on that ch, but I notice it will get dim after a few seconds. I've tried messing with the brightness and all that stuff, nothing seemed to work. It's driving me crazy because whenever I watch a DVD it just shows up way too dark and dull. I got the TV as a hand me down from a friend of mine, and he's had it for awhile. When watching digital cable everything is fine, it's just when switching to that "AUX" or as I call it the "PS3 Ch" it stay normal for a second then just gets dim and annoying. :/ I can still play with no problem but it's just knowing that it could be a bit brighter would help. :( Is there anything I'm missing with this TV? I don't own the original remote either but I've tried changing it from the "Sports" "Movies" "Weak Signal" "Video games" and still it's not working :( I don't know what else to do!
SOURCE: help for a friend; ln-s4095d, hdmi and blu-ray.. no picture
email141.
I had the exactr same problem with P#3 and the same model of TV, I turned of the 24 hz setting as you suggested and it si workign great! The only thing I am wondering is what ewxactly the 24 Hz setting is. The actual title is "BD 108P 24 HZ output. I didn't turn off 1080P did I? Don't think so as picture looks great. Even though I didn't ask the original question I REALLY appreciate the answer!
Posted on Dec 31, 2008
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
romsky79
  • 822 Answers
SOURCE: Sanyo Flat screen
try to check the settings of your tv if all ok. if ok its a problem in your TV circuit board try to resolder maybe some sections is cold solder. if not its a service mode. trust me!
Posted on May 20, 2009
dsacco86
  • 1077 Answers
SOURCE: ch setup on a vizio tv.
( FOR VIZIO TV MODEL VO47L )
Press menu on the remote,
then go to the icon that says TV,
then press down on the remote to change,
"Tuner Mode" for Cable or Antenna.
"Auto Search" for auto search channels
"Skip Channels" for removing the unwanted channels.
If you need a copy of your manual, go here:
http://www.vizio.com/downloads.aspx
Posted on May 24, 2009
  • 380 Answers
SOURCE: channel 4 is ch 8 and ch8 is ch 4
Did your cable company change the order to your channels? This is a rare problem.
Posted on Dec 05, 2009
I have just been given a hand me down Philips Magnavox Smart Plus Series TV, but it is giving me a code, ,and I do not have a remote control, how do I get to channel 3
You may have to purchase a programmable remote control as a replacement and use its code search feature to find a code that will control your Magnavox TV.
Feb 05, 2015 | Philips Televison & Video
Can't find install code for philips magnavox smart series plus
Universal remote codes for Philips Magnavox TV are: 0062 0204 0207 0183 0226 0288
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand
Sep 27, 2012 | Philips Smart Plus TP3285C 32" TV
Dvdplayer shows its playing but not on tv does tv need to be programed
guest,
how is your hook up? is the dvd plugged into aux in or video in ...okay is the tv on ch 3? use remote press CH down to see if you have video/aux ch...3..2..1..video.....(if you are plug into video/aux) if you have a vcr do not disconnect...we do not wish mess anything up...
May 12, 2010 | GE 27GT271 TV
Philips magnavox smart series pr1920c601 turning off itself!
well let me ask ya something so it is coming back by its self then going back out may be solder connection okay call tv shop good luck shad
May 03, 2009 | Zenith B27A11Z 27" TV
HOW TO REMOVE CLOSE CAPTION FROM SMART SERIES TV
on your remote go to cc push that until it sayes closed caption off not positive but pretty sure
Jan 11, 2009 | Philips Magnavox 20MS233S 20" TV
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
Where should i connect power cord in philips magnavox smart series tv
Don't understand the question, but the power cord sure goes in to a regular AC outlet.
Nov 15, 2008 | Philips Magnavox TS3260C 32" TV
NO SOUND/CLEAR PICTURE
Please do not do all caps. It makes it harder for us to understand your problem.
Check the speaker settings in the menu and in the case, BUT NOT UNTIL IT IS UNPLUGGED FOR ABOUT 10 MINUTES! TVs have caps that hold up to 30,000 volts and take a while to discharge.
Oct 05, 2008 | Philips Magnavox Learning Universal Remote
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
TV seems to be "stuck" in VCR mode after power surge
your tv is playing dvd means your video &sound section is ok. as it is not playing cable means that there a problem in tuner section only. if cable connection &its socket is ok.
Sep 25, 2007 | Philips TS2768C 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
