Question about ASUS P4GE-MX Motherboard
My asus p4ge-mx-uaykz motherboard has two slots for installing ram right now i am using 256mb can i upgrade it to 2gb?
    Novelist:
  • 100 Answers
Hi yes u can upgrade to 2 GB memory because Ur mother board supports it up to maximum of two GB and make sure u ask Ur dealer to select the correct DDR that is rated as PC2700,PC2100,PC1600 because selecting incorrect DDR may burn Ur motherboard with warm regards-bonefirediv.
Posted on May 17, 2011
    Scholar:
  • 142 Answers
Yes you can upgrade to any DDR that is rated at PC2700/PC2100/PC1600 and non ECC. Up to 2 gigabytes.
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
I upgraded my RAM memory adding an additional 1gb to another slot and earlier i was using 256mb.when i started to boot, my system just restarted after the windows loading process and this happened all the...
1) Check your BIOS to see if there is an AUTO spd setting. (usually you have to push either F2 or Delete key when you see the first black screen with white words)
2) Make sure that the speed ratings of the memory chips are compatible. If the new one isn't backward-compatible in speed, it might be too fast to be supported by an older motherboard.
Jul 29, 2011 | ASUS P4GE-MX Motherboard
Mi PC tiene: placa base ASUS P4GE-MX-procesador X86 family 15 mod.4 stepping 1- un HD de 80GB y memoria RAM DDR 256MB. Quiero ampliar mi memoria a 1 X 2 de 560MB (1GB) y instalar HD de 120GB. Es posible
S?, usted puede actualizar su equipo. La placa base es compatible con la memoria DDR1 tipo PC1600/2100/2700 2GB max. Es necesario IDE tipo HD. Buena suerte.
Mar 22, 2011 | ASUS P4GE-MX Motherboard
I have this ASUS P4GE-MX Motherboard. I want to upgrade my ram from DDR 256 MB TO DDR 1 GB. For temporary purpose, I tried another 256 DDR ram with 400 MHZ, but I had some problem with booting my system....
Hello, The Motherboard's specifications mention that it uses DDR Ram, while the FSB runs at 400MHz. That means that any kind of DDR memory will work up to the maximum of 2 GB (it has 2 slots, so it's up to the max of 2x1GB DDR sticks).
There's no issue with the speed, actually the faster you can get the better results you will have. Try looking for 1GB DDR 400MHz (preferably two of them, if you want to max out the capacity and since it's kind of cheap to do so).
The one you tried and didn't work, might be due to a faulty RAM module.
Mar 13, 2011 | ASUS P4GE-MX Motherboard
My Mother Board is ASUS P4GE-MX. How much GB does the RAM spport.
ASUS P4GE-MX Motherboard has two RAM slots Supporting DDR-I, 1GB each. Hence, it supports 2GB RAM Max
Click here for more details (if required)
Dont forget to rate the solution if I could have been of any help!
CreativeTECH
Dec 03, 2010 | ASUS P4GE-MX Motherboard
Excuseme,I don't speak english, but I need the audio driver for motherboard ASUS P4GE-MX for windows 7 32bit. You can answer me in this address e-mail: jose_a85@hotmail.com thanks
Have you checked with ASUS TechSupport? That is a very old System Board and most likley does not support Windows 7 and Asus most likley has no plans to release any. I recommend buying a newer model of system board, which will require newer CPU, RAM and video card to successfully implement Windows 7 and find drivers more easily.
Check this Asus forum post with similar question:
http://vip.asus.com/forum/view.aspx?id=20081208025209781&board_id=1&model=P4GE-MX&page=1&SLanguage=en-us
Also not sure if you tried running the Windows 7 Upgrade Advisor before you upgraded.
http://www.microsoft.com/Windows/windows-7/get/upgrade-advisor.aspx
it most likely would have advised against installing Windows 7 on the current system and recommended what you would need to upgrade first.
Good Luck!
Feb 17, 2010 | ASUS P4GE-MX Motherboard
P4GE-MX system having 256MB RAM-Hanging regularly
Get it checked from an expert. It may be due to overheating, or some other hardware problem. U can take a chance by reinstalling your operating system.
Aug 22, 2009 | GE Asus P4GE-MX...
IS ddr2 ram works on ASUS P4GE-MX? or only DDr 1 is supported by this motherboard???
Number of PIN DDR2 more much than DDR1. If you install on DDR2 Slot DDR1, can not be installed correctly, because the location of the key slot DDR1 and DDR2 is different.
Look the picture, and look the different
I look for your maindboard, it's only supported DDR1.
Mar 21, 2009 | GE Asus P4GE-MX...
Pc upgrade
Hi ****, you can increase you system speed slightly (Depending on the total memory speed of the card), by adding an AGP 4x video card & setting your bios to boot to AGP. See page 2-16 in your manual. Change, Init Display First to [AGP]. Doing this will disable the onboard - integrated video card. (Doing this will also free your system memory which is used to run the onboard graphics card). Increasing your system memory to its max of 2GB will help as well. Here is Crucial's memory link for your board. http://www.crucial.com/store/listparts.aspx?model=P4GE-MX You should increase the CPU if at all possible to its max speed in-order to see an over-all increase of system performance. (This is not what you asked for, so I'll only include Asus link for supported CPU's, for the P4GE-MX motherboard). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P4GE-MX Don't expect lighting speed but you will notice game playing speed much better. Programs should load much faster, ECT. Upgrading the AGP must comply with 4x/8x (+1.5volt only). Please see page 1-12 in your manual. Looking for XFX video card is best because it carries a lifetime warranty. Try this link: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150210 You can continue to search for an XFX Geforce cards. (Best on the market for their lifetime warranty). Good luck ****! Though the AGP slot is faster than a PCI slot, you may find an XFX PCI card with more video memory on it. Some even run DDR3 & DDR3 memory. Mike
Sep 14, 2008 | ASUS P4GE-MX Motherboard
Hello My ASUS K8V-MX Motherboard has only two memory slot
Look into you're manual, go to pages 1-11 & 1-12.
The memory listed here has been tested by Asus to work correctly in the K8V-MX motherboard. In order for you to reach 2GB memory you will need DS memory. Double sided. This means there is 512MG on each side of a single DIMM, hence 2x1x 512MB DIMM equals 1GB. So you will need 4x 512MB to raxhl a total memory of 2GB. Please stay within the recommended memory listed on the Qualified Vendor List (QVL).
Simptronics memory it not on the QVL list. From time to time some memory not one the list may still function. This is not one of those times.
Mike
May 19, 2008 | ASUS K8V-MX Motherboard
ASUS P4GE-MX Motherboard Logo
116 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
