Question about Jenn-Air 48" Side-By-Side Built-In Refrigerator, JS48F
I have a jennair js48sedbda and the evaporator drain keeps freezing up and freezing up the fan i hope you can help me thank you for your time
  • harryjr34 May 21, 2011
    i am geting the part and going to put it in thank you for your help
  • 794 Answers
Hi harryjr34,
This is a known issue of Jenn Air's 42" and 48" Built in Refrigerators. And your specific model is one these. Defrost water accumulates in the evaporator drain tray and freezes. After a period of time layers of ice may accumulate,allowing defrost water to seep over the edges of the tray and into the freezer section. To correct this, you need to order and replace evaporator drain tray kit with a part # W10199915. All you have to is to follow the instructions supplied in the service kit. You may try to purchase at www.appliancepartspros.com. You can also call them at 1 877 477 7278, 7 am-midnight EST.
Hope it helps.
Thank you for using FixYa.
Posted on May 17, 2011
  • Jemalyn Labaguis May 23, 2011
    You're welcome.
  • brad497
    brad497 Mar 14, 2012
    I replaced the drain kit but now mine won't cool! Any suggestions?
Water leaking from the freezer unit.
The drain hole is probably frozen over. When it goes into defrost mode every 10 hours or so, the evaporator heater removes the ice from the evaporator. There is a drain hole under the evaporator with a hose attached that goes down to a pan by the compressor fan where it is evaporated so as to not leak water on the floor. When it freezes over the drain, the water fills the bottom of the freezer until it comes out the door. A common fix to prevent the drain from freezing over is to take a bare copper 14 or 12 gauge wire and put a couple turns around the evaporator heater and stick the other end into the drain. This heats the wire enough to keep water from freezing b over the drain hole.
Dec 09, 2013 | Jenn-Air JFC2089HE French Door...
Does my fridge have a defrost timer? The first time the fridge quit working we had a repair person come figure out. He found the circulation fan was frozen in the back panel inside the fridge. He turned...
This is a very common problem with Samsung refrigerators especially the type that has two evaporators. The evaporator that is inside the fresh food section and will usally give people the most problems. The drain below the evaporator in the fresh food section will begin to freeze over or become blocked by gunk inside the drain line. When this happens it causes the fresh food section to retain water because with the drain blocked the moisture and defrost condensate water now have nowhere to go. Once that drain is blocked the freezing over of the evaporator will begin to happen more often slowing down defrost which again make problems worse. Clean the drain, make sure the refrigerator is level and confirm the model number of your refrigerator. Your model has no defrost timer and defrost are determined by the motherboard. There is a way to force defrost with your model from the motherboard but until the drain is cleaned out defrost will not help much because the water has no where to go but to freeze over the evaporator and fan area of the fresh food section evaporator. Is your model the?=>RF267AERS I am here if you have questions, Sea Breeze
RF267AERS Parts
Oct 21, 2013 | Samsung RF267AERS French Door Refrigerator
Evaporator freezing up on delfield prep table
unit should have a defrost cycle.If defrost does not engage due to you unplugging it.the fan inside could freeze up.it will continue to freeze until alll ice is removed from fan area.Also check drain.
May 07, 2012 | Delfield 4464N-12 Commercial Refrigerator
The freezer is not as cold as it should be. Is 2 the coldest setting? Shouldn't 4 or 5 freeze ice cream hard? Thank you. Jim
Hi Jim,
I am currently working on that model for a friend, the higher number the colder that compartment will get, it is not advisable to go any higher than 5 or 6, because this will reduce air to the refer section. Is the fan working in the freezer? I have seen problems with this model, and when the drain pan to the evaporator clogs, then the water freezes around the fan motor and stops it from functioning.
Get back to me and I could lead you in the right direction if needed.
Aug 14, 2011 | Jenn-Air JS48SEDBDA Stainless Steel Side...
Hello, I have a Ruud 10 seer unit in the condo i rent...it frequently stops cooling. The fan inside never shuts off, but the unit outside won't come on often enough to cool to the temp on thermostat. When...
It sounds like the air cond is freezing up, and as he melts the ice off he evaporator coil you will have air flow again. When the evaporator, (which is the coil that absorbs the heat from your condo) is frozen over, no air flow can pass through it. The evaporator is located either above the furnace or below the furnace. Therefore, the indoor fan will continue to run, but no cool air will be coming out of the vents. What causes it to freeze up? Usually it is low on refrigerant (some people call it freon). If there is a leak in the system, he may charge it with refrigerant, and then in a few days or weeks later have to thaw it out, and charge it again. If this is the case, you might want to request the leak be located and fixed. Another reason it will freeze up is a dirty filter. Or, if the unit did not have a filter in it for quite some time, the evaporator could possibly be stopped up with dirt resulting in poor air flow all the time and and eventual freeze up of the evaporator. Hope this helps you, stay cool.
Apr 20, 2011 | Ruud Matching Split Air Conditioner
Electrolux frost free fridge freezer
i have the same fridge freezer and the same problem and have no manual can any 1 explain thank you
Mar 31, 2009 | Electrolux Refrigerators
GE Refrigerator forms and Ice dam which stops the evaporator fan from turning.
is it defrosting theres a glass tube which is the defroster bar,there known to have these fail
Jul 07, 2008 | GE GDS20SBS Stainless Steel Bottom Freezer...
Fridge
ok pull the cover off the back wall of the freezer compartment where the evaporator fan is after look under the evaporator should see an aluminum pan with a hole there that's the drain hole for the defrost system if its frozen and that hole is stopped up then every time it defrosts the water will run in the freezer and freeze and also drip into the fridge remove the ice and clear the hole also check the drain tube in the back to make sure its clean
Jan 18, 2008 | Refrigerators
Jenn-Air 48" Side-By-Side Built-In Refrigerator, JS48F Logo
240 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
