Question about Scosche Industries Scosche Vw01b Wiring Harness for 1986&Up Select Volkswagen
What are the pink wires on a VW01B wiring harness for a 2000 vw passat?
How many fuse box has the 2002 vw passat 1.8 t
Arturo, Passat fuse/relay locations and alarm schematic. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Volkswagen Passat B5 FL 2000 2005 fuse box diagram Auto Genius
VW Passat B5 Guides
http://forums.vwvortex.com/showthread.php?3751731-Fuse-box-in-engine-compartment
Best images of 2003 VW Passat Relay Diagram
2002 passat alarm wiring schematic Google Search
Aug 21, 2016 | Cars & Trucks
Wire replacement instructions for headlight on 2003 passat
go to a wreckers that handles VW and get the complete headlight harness and replace the existing harness
Jan 30, 2016 | 2003 Volkswagen Passat
Wiring harness
Not easily and without modification.
Nov 07, 2013 | 1999 Volkswagen Passat
Wring harness
The Answer to this question is HARD... There are Wiring Harnesses on 1990 Trucke that are not the same for the Same Year and Model.. Engine Codes, Options, Ect play a very important role, as much as the Year Does..
I put a 2002 Audi A4 Engine into a 1998 VW Passat and it was an Identical Wiring Harness... I know that does not help you all the way but there is more to it than just a year.... The Audi A4 and Passat Engines had Identical Engine Codes...
Apr 08, 2013 | Chevrolet Chevy Cars & Trucks
I'm looking for a factory wiring diagram for my 1999 vw passat.
Hi Chad,
If you cut the car's radio connectors off the wiring harness, you'll void the warranty of the car (or worse). Trying to splice or "tap" the wires will get confusing even if you don't connect the blue wire with the white stripe to the white wire with the blue stripe.
Do yourself a huge favor and purchase a wiring harness adapter for your 199 Passat instead. Crutchfield sells one for your car for $10. Likewise, most electronics stores that deal witrh mobile installs have them too - check out Best Buy, Circuit City, Fry's and even your local independent radio shops.
You wire the new radio's harness to the harness adapter for the car in the comfort of your home (the light is better and you don't have to contort yourself to do the work). When complete, bring it out to the car and plug one end into the car, and the other into the radio. Insert the antenna plug and you're done wiring!
If you want a wiring diagram, those usually aren't available online for free. You need to spend a few dollars for a Chilton's Auto Repair Manual or similar at an autoparts store. You may find registering at a site for Passat Enthusiasts will be beneficial.. all the folks there have Passats and discuss everything from tire sizes and rims to transmission rebuilding. One such site is the "Forum" section of Passat World.
I hope this helps & good luck!
Dec 27, 2012 | Cars & Trucks
I have a 2000 VW Passat GLS that I'm trying to install a Dual stereo system into but I can't figure out what the wire colors on the car are for each thing (power, ground, etc.). I've looked online through...
First of all I would highly reccommend you use a wiring harness such as the Metra 70-1784 or the Scosche VW01B for two reasons; 1) it will make things 10 times easier for you and 2) it will keep all your factory wiring intact.
If you want to tackle this without using a wire harness do not just go and cut off your factory plugs, leave them on in case you ever need to change out the radio to a different model/brand of if you ever decide to sell the car or trade it in you can put your factory radio back in and keep your nice new radio for the new car. Just tap into the wires behind the plugs and make sure to insulate your connections really well so you don't pop fuses or worse.
Here's the wire colors and what they do:
12 volt constant wire - Red/blue
Ground wire - Brown
Radio ignition wire - Red (thicker red wire)
Radio illumination wire - Gray/blue
Front left speaker - Red/green (+) and Brown/green (-)
Front right speaker - Red (+) and Brown/red (-)
Rear left speaker - Blue/white (+) and Brown/white (-)
Rear right speaker - Blue (+) and Brown/blue (-)
If you're using a amplified antenna adapter that has a blue wire attached to it, connect that blue wire to the thicker red radio ignition wire.
Hope that helps.
Apr 02, 2011 | Car Audio & Video
How do I disconnect the wires on the fuel pump for 2002 VW passat wagon?
there should be a wire harness right on top of your tank not easy to get to
Jan 16, 2010 | 1999 Volkswagen Passat
I have a 2000 VW Passat. Recently, my cruise control has been acting up. It will engage but shut off every time I turn on my left turn signal or my brights. However, three days ago, it stopped working...
Check the wiring harness, especially the one that goes underneath the dashboard and steering column. There may be bad wires or loose connections that may have caused your cruise control to act up when turning on the signals or the brights. If that checks out Ok, inspect the speed sensor near the transmission. It may have gone bad.
Oct 27, 2009 | 2000 Volkswagen Passat 4Motion
VW Passat 1.6l 2000 (UK) Sudden failure of
check under seat, there are 3 sets of wires, they could be coroded, these wires run all the windows door, any thing that is for useing the power, i know just had it fixed 245, 00 later,,
Sep 09, 2009 | 1999 Volkswagen Passat
Scosche Industries Scosche Vw01b Wiring Harness for 1986&Up Select Volkswagen Logo
130 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Jose Velazquez
Jose Velazquez
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
