My computer altec speakers have a hum to them
  • 20 Answers
Most likely from ware, those speakers have a tendency to ware out easily, you might need new ones, but you can try adjusting the EQ on your ipod (under settings).
Posted on May 18, 2011
How can I splice Altec Lansing amplified speaker system 221 to ac power supply cord instead of the computer cord
Not a good idea. The receptacle that the computer cord plugs into has EMI filters in it. Bypassing it would cause an AC hum that you'd never be able to get rid of.
Sep 16, 2016 | Altec Lansing Audio Players & Recorders
Altec Lansing GT5051, I'm hearing a humming noise from the speakers as soon as I turn them on. The humming noise is heard even if speakers are not connected to source.If I try and play music with...
Sounds like a problem in the speakers' internal power supply, maybe a faulty capacitor. Speakers need to be looked at by a technician, or replaced with a new set.
Jun 05, 2011 | Altec Lansing GT5051 Computer Speakers
My computer altec spekers have a hum to them
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
May 17, 2011 | Altec Lansing Speakers: FX6021 Inconcert...
I have a 2.1 altec lansing speaker system i got 3 years ago. a couple of moths ago they started humming. the humming is now so loud i have to turn the power off when i go to sleep (i can even hear the hum...
If there is a router or you leave your phone near the speakers that is what is most likely causing the problem. Check to see if anything that gives off a wireless signal (eg. microwaves, cell phones, cordless phones) are nearby, and try to see if moving one of those things fixes your problem.
Feb 28, 2011 | Altec Lansing VS2421 2.1 Speakers
Humming, how to access cct board
Try unpluging the Altec power supply turn it around and plug it ack in. It may be out of pphase with one of your other power syples.
Jan 12, 2011 | Altec Lansing AVS 500 Computer Speakers
The humming sound from the speakers. how do u get rid of it?
i have the same probles woth my atp3 , connected to an airport express , and even to teh laptop itself. seems like it comes from static electricity around or within the speakers. try to change the location but i doubt if it will help alot.
if its the same sound i`m hearing then its really quite hum that is practicly unheardable while you play music , and if it bothers you while the speakers are not in use , just turn them off.
hope this helps
Oct 18, 2009 | Altec Lansing ATP 3W Computer Speakers
My speaker altec lansing vs4121 is just humming
Check the audio amplifiers Ic´s maybe are burned
Aug 10, 2009 | Altec Lansing VS4121 Speaker
NO Sound from NEW speaker unit?
Yes the green wire that goes from the speaker should be plugged into the green jack on the PC. An easy test to see if its the computer or the speakers is to have the speakers on and volume up a little and tap the tip of the green plug with your fingers while out of the computer. If it makes a humming or any noise at all while tapping, the speakers are working if not lets check voltage at the power plug or if the unit has any lights on. Gook luck!
Mar 25, 2009 | Altec Lansing Multimedia Computer Speakers
Humming noise but no sound
It not a short but it is 60Hz hum coming from the a loose connection to ground (not properly grounded) check your power strip for proper ground, 60HZ hum is the culpurit here.
Sep 21, 2007 | Altec Lansing AVS 500 Computer Speakers
41 people viewed this question
 Grubhead
Grubhead
