Question about Frigidaire FMV156DC Microwave Oven
Our frigidaire microwave stop heating up the food?
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 .,/;'
Posted on Aug 13, 2011
  • 3 Answers
SOURCE: Microwave not heating food
check the protector connected at the capacitor and at the magnetron coil windings, check using an ohm meter.,meter should read to zero
Posted on Dec 21, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: MICROWAVE OVEN DOES NOT HEAT ALL OTHER FUNCTIONS WORK
Since the light comes on and the turntable rotates, I would suspect a bad magnetron, a loose connection at the magnetron, a failed high voltage transformer, or shorted high voltage rectifier diode.
If it's less than one year old, it should be fully covered under warranty.I'd suggest contacting the manufacturer to get it fixed free.
Ifit's within the magnetron portion of the warranty (usually 5-9 years)but out of the original full warranty (usually 1 year), then yourmanufacturer will cover the part cost, but not the cost to visit you orthe labor charge to do the work.
If you or a friend want to work on it, please see these links first:http://www.microwavedisplay.com/safety.txt& http://www.microwavedisplay.com/disassembly.txt
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
For Frigidaire models, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Or you can find your nearest Frigidaire/Maytag-authorized servicer here.
You can visit Daewoo onlineor call them at 1-800-323-9668 or 1-800-553-4355 to find parts or findyour nearest authorized service center to have them do the work.
Posted on Oct 07, 2008
  • 38 Answers
SOURCE: My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
Posted on Mar 20, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: Frigidaire Microwave OTR FMV145KS2 not heating
Chances are it's a defective high voltage rectifier diode or magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/cap_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You can download Frigidaire owner's manuals and installation instructions can be downloaded through the links here. where you can also locate a nearby authorized servicer if you choose.
The magnetron has a 10-year part warranty, but you would have to pay labor.
If nothing else, you can save about $75 by taking it to the shop yourself.
Good luck.
Posted on Jun 17, 2009
SOURCE: My Frigidaire microwave stopped working while cooking food.
All lights are operational. Model number is FMV156DBC.
Posted on Aug 31, 2009
Microwave won't heat
you have a power diode defective, high capacitor or Magnetron, test it for open with DVOM OR VOM , or better consult the qualified tech, Because this involve high voltage.
God bless you
Jul 10, 2012 | Frigidaire GLMV168K Microwave Oven
Frigidaire PLMV168K2 micro wave stopped heating food. Still has turntable and light functions. Seems to have more of a power load after initial start. The buzz is more intense than normal.
A loud buzz is a symptom of a shorted magnetron or high voltage diode. Would recommend that you take it to a qualified repair facility if you want it repaired, but if the magnetron has failed, the part costs can equal that of a new oven.
Dec 06, 2010 | Frigidaire PLMV168 Microwave Oven
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
Microwave stopped heating up the food. Everything works except for the heating mechanism.
Check the door safety interlock switches. Remove the cover to find these small micro switches on the side away from the hinges.
Need more help ... post a comment here
thanks for using FixYa.com
Nov 02, 2009 | Frigidaire PLMV169DC Microwave Oven
Mar 20, 2009 | Frigidaire FMT148GP Microwave Oven
Food not heating in microwave
Magnetron tube probably failed. Depends on how old the microwave is. If its still under warranty, call Frigidaire. If not, take it to a repair shop, get an estimate, and compare it to a new one. It'll probably be cheaper to buy a newer one that will have more power, but check anyway.
Dec 18, 2008 | Frigidaire FMV145K Microwave Oven
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
126 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
