Question about Toshiba Computers & Internet
Errors in the hard drive.how to fix it or remove?
  • 621 Answers
If a hard drive is showing errors which are normally bad sectors they cant really physically be fixed the computer just tries to ignore using those sectors of the drive. Hard drives are so cheap now days i would recommend backing up anything important and replacing it as it will get worse. Cheers from Scott and please vote
Posted on May 17, 2011
Toshiba satellite l750-16l "a disk read error occurred"will a new hard drive fix
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Nov 06, 2012 | Toshiba Computers & Internet
System has hard drive errors and a write fault error then logs off
You can re-locate the main cable to your hard-drive just by removing it and replacing it, this often fixes read write errors. Carry out this procedure at both ends (Hard-drive end and motherboard end. Just check that the connector is clean and dry (clean with an eraser if dirty).If this does not fix the problem it looks like your hard-drive may be on its way out, and should be replaced.
Oct 11, 2012 | HP Pavilion TX2000Z 12.1" TOUCH-SCREEN...
E 68 error code.
The e68 error on your Xbox 360 is caused by a hard drive/HDD problem, much like all of the problems in the "e6x" family of error codes on the Xbox 360 platform. It can be caused by an internal connection error with the hard drive, a general failure of the hard drive, or overheating of the hard drive. Basically, there is quite a large range of things that can cause the Xbox 360 e68 problem, which can make troubleshooting the issue slightly difficult.
Step one to fix the e68 code on your Xbox 360 is to remove the internal hard drive and try playing your console without it. If it then works, then you can be sure that you can permanently fix the problem. If not, then you will have more serious issues on your console that will need to be checked over by Microsoft
if it is the hdd there are guides on the net on how to fix it
Aug 23, 2010 | Microsoft Xbox 360 Console
E68 error code
try removing the hard drive and see if the xbox plays without it.
error 68 could be internal fault or external but is a harddrive fault.
if it plays without the hard drive, you need a new hard drive.
if it still does not work with the hard drive removed, you may have an overheating problem.
this could be fixed by you by following many of the online guides or if you have a warranty maybe microsoft will fix it? the 3 red light fix will fix most red light errors. i would suggest upgrading the fans too if you plan on fixing it yourself.
May 27, 2010 | Microsoft Xbox 360 Console
E 68 error....will transfer cable help fix it?
The E68 is a weird error. Its normally from a hard drive failure. The underground xbox 360 scene says
THe E68 is a Hard Drive Error. The Hard drive is not properly configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
If the xbox can play without the hard drive then this error can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices.
If its the hard drive or your console causing the problems contact Microsoft they will probably fix your hard drive and maybe recover your game saves. On the newest games that info is stored on xbox live.
http://support.xbox.com/support/en/us/nxe/contactus.aspx
May 08, 2010 | Microsoft Xbox 360 Hard Drive (20GB)
E68 Error Please Help
Turn off system, take hard drive off, put hard drive back on, turn system back on.
Dec 18, 2009 | Microsoft Xbox 360 Console
E 73
moz-screenshot-3.pngmoz-screenshot-4.pngmoz-screenshot-5.pngmoz-screenshot-6.pngmoz-screenshot-7.pngThis problem is fixable, I had similiar problem with my clients XBOX360 console ( I run an electronic repair shop) and get customers frequently with this Error. I was able to fix couple of consoles with the help from this XBOX360 Repair Guide
You can download the repair guide and fix most common problems with your XBOX console. There are also other errors which are covered in the guide, so you can fix them as well!
Oct 05, 2009 | Microsoft Xbox 360 Console
Xbox is showing one red light in the lower right hand spot. How do I fix this
The Specific Type of hardware failure can be determined by the error code displayed on the screen.
If the screen is blank or you would like additional information follow the instructions for determining the secondary error code in the section below
E64: (not yet known)
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E67: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
E69: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
E71: (not yet known)
E73: (not yet known)
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. (could also be a problem with the encoder chip)
E76: (not yet known)
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it
Sep 24, 2009 | Microsoft Xbox 360 Console
One red light - Error: E 68 - Problem code 0110
We offer a repair service.
FixMyConsole
Jun 03, 2009 | Microsoft Xbox 360 Console
It has the bottom left ring
Hello my name is Tim Ehrhart and I hope this helps The Specific Type of hardware failure can be determined by the error code displayed on the screen.
E45: Unknown (possibly dashboard update related)
E64: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc.
E65: DVD Drive Error.... DVD Timeout, Wrong firmware, dvd is without f/w chip, etc. This can also be caused by the tray not being fully closed on boot.
E66: DVD Drive Error: DVD model, or version does not match that of the version expected by the dashboard. OR the firmware version on the drive is older then the firmware version expected by the dashboard. Make sure the DVD drive is of the same version originally included with the console and that it is using either the original firmware included with the console or newer.
E68: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error. Some also believe this might be caused by a problem with the fans.
E71: possibly a dashboard update error, Check below in the "Console Reset Codes" for instructions. If that does not work there is no other solution and the console must be sent back to MS for repair.
E72: (not yet known)
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port.
E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
Please leave feedback as I am new and wanne gain a good rep. Thnk You
Mar 12, 2009 | Microsoft Xbox 360 Console
Computers & Internet Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
