Question about Dryers
Hi, I am thinking of buying a samsung dryer, dv665j, apartment size, what are some of the things I should watch out for, right now I have a Miele, 15 years old, which quit on me this week, seems like the start button which had been sticking for a long time now, the cost of fixing and ordering a new part is a few hundred dollars, so we saw this samsung, what are the consumer right ups for this one? thanks.
jsrock516
  • 5911 Answers
SOURCE: not drying
If the dryer turns on, drum spins, but you have no heat, any of the following components could be bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
Now, if your dryer keeps failing, it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation was. If you can't remember, or if it has never been done, this could be the cause of your dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little prevent maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. You have to remove the entire front panel on some models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two RED leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set.
I hope this information is helpful to you. Post back with comments if you have any further questions.
PS This is not to assume you are abusing your appliance or are acting irresponsible. I just wanted to give you some useful tips, because some people just don't know.
Posted on Feb 14, 2008
dididsaythat
  • 291 Answers
SOURCE: Miele T220 drum doesn't turn
sounds like belt may be slipping .. check idler pully for tightest against belt .. belt may be streached and need replacing
Posted on Oct 14, 2007
centralhigh
  • 260 Answers
SOURCE: Whirlpool Dryer Model # LE7680XSW1
David,
You have a pretty old dryer. Replacement is recommended because new dryers use less electricity and more than make up for the price with the savings on your electric bill.
However, if you still want to use this dryer, you will need to replace some internal switches. In order to guide you through that I recommend you use our premium service.
If you need to find a local repair service, please type your zip code into our repair service search engin located on our site.
Good luck,
CH
Posted on Jul 30, 2008
SOURCE: Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Posted on Feb 04, 2009
mcgyver468
  • 710 Answers
SOURCE: My dryer won't start, but I think the cycle button won't engage.
THERE IS A SWITCH THAT IS LOCATED ON THE OPPOSITE SIDE OF THE DOOR. SOME OF THESE SWITCHES ARE OF THE PLUNGER TYPE. TRY PUSHING THE PLUNGER IN WHILE STARTING THE DRYER, MAKING SURE THAT NOTHING IS IN THE PATH OF THE ROTATING DRUM. IF THE DRYER STARTS, THEN EITHER ADJUST OR REPLACE THE PLUNGER SWITCH. THANKS FOR USING FIX-YA. PLEASE KEEP ME POSTED. GOOD LUCK
Posted on Sep 22, 2009
Where is the thermal fuse located on a dv665j dryer
Usually a small unit near the heating element. You may have to remove the top lid if possible to view it. If there's no heat then its the element has failed. Get an appliance electrician or similar to check the element because the thermal fuse normally self resets when it cools.
Nov 15, 2014 | Samsung Dryers
Change element in a samung dv665j
Usually, one takes the rear cover off revealing the element area. I doubt if the heating element is burned out. Typically the small thermostat or thermal fuse link blows before the heating element goes. You would have to see the diagram of your model online. Most sites have the exploded parts view of that section online. If you don't have a meter tester you may have to replace all 3. Some models have them all tied into 1 board. This site has video troubleshooting. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-160-1067262-/Samsung-Dryer-doesn-t-heat-DV665J Samsung Dryer Doesn Heat
Sep 13, 2014 | Samsung Dryers
Samsung dv210 will not turn
Belt come off/damaged? Same thing happened to us and the clicking noise was our shredded belt flapping around hitting the drum. see : We fixed our dryer!! so happy!! First We ordered the dryer belt with part # Samsung Dryer Belt 66002-001655. I got it off Amazon at a good price $11-13 at http://www.amazon.com/gp/product/B001KGX...THANK GOD we ordered it just in case because it turned out the belt had NOT slipped off but was SHREDDED apart. The BEST ADVICE to this particular model Samsung VRT steam dryer DV419AEW came from a commenter to another thread . Follow this thread if you have Samsung VRT steam dryer with model # DV419AEW= this threadhttp://www.fixya.com/support/t1210394-sa... The comment at the BOTTOM of the reply made by "dumb-stump". He describes how you take apart this particlar model. I also watched the youtube video on belt placement http://www.youtube.com/watch?v=obaoSDbzY... This shows how to place on pulleys etc once you get belt around the drum.
Jan 20, 2013 | Samsung 7.3 Cu. Ft. Electric Dryer
A loud clunking noise - the vent/filter check light came on plastic broken parts which looks like a fan or something.
Hi
Yes, your right, it is the blower fan for the dryer, something may have gotten down the filter element housing and broke it, or just from heat and time.
Yes, you can fix it if your somewhat mechanically inclined.
It is not a hard job, but must be done correctly.
I will send you a webpage with some parts choices.
I do not know where you location is so I cannot send you to the direct webpage.
Please rate me
Bud
parts webpage: http://www.ask.com/web?q=Miele+T9800++parts&qsrc=6&o=11145&l=dir
Youtube video on Miele dryer repair, not your model but will probably dissassemble the same way.
http://www.youtube.com/watch?v=Kl7jTH2d58A
Oct 26, 2012 | Miele T9800 Electric Dryer
Need diagram of belt installation for dryer DV218AEW
Hi mcpitts...
Click on the link to find your model number link http://www.repairclinic.com/Appliance-Parts
Here is the process for taking your dryer apart mentioned above.
You will need to decide which video fits your machine appearance.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
Please take time to rate me
Aug 10, 2011 | Samsung DV218AEW Electric Dryer
Miele T9800 dryer starts then stops and goes dead. Vent is clean.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 19, 2010 | Miele T9800 Electric Dryer
Samsung apartment size dryer-there is heat but drum does not turn
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 26, 2010 | Samsung DV306LEW Electric Dryer
Miele Dishwasher - Not cleaning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
xxz
Apr 26, 2010 | Miele 24 in. G892SCU Plus Built-in...
Is it 120 02 240
There should be a label that tells you that. Most home dryers are 120
Mar 05, 2010 | Samsung DV328AE Electric Dryer
Holes in clothes
I'd bet the holes are the same size as the holes in the dryer tumbler. the only thing I can think of is that your dryer isn't tumbling and the heat that is pushed through the holes is burning your clothes.
Apr 18, 2009 | Miele Novotronic Premier 500 Front Load...
Dryers Logo
76 people viewed this question
Top Dryers Experts
