Question about Onkyo TX-8410 Receiver
Onkyo TX-8410, speaker selector B not operating. When I have the speaker selector on A&B or just B, the B speakers do not operate. If I switch the wires from the same speakers to the A channel, the speakers work fine. Is there a fuse that would have burned out?
    Brigadier General:
  • 8,546 Answers
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-8410-Receivers-manual/id/365ci162/t/2/
Individual speaker leads are not fused. It's possible the switch is defective. Does it light the speaker B indicator? If not, I'd suspect the switch.
If it DOES light the Speaker B indicator maybe there's an open circuit going to the Speaker B terminals. Or its common ground for that speaker pair alone is open.
Posted on May 17, 2011
My onkyo tx-sr605 7.1 a/v tuner will not switch from game/tv to cable/sat or any other mode. I can't even get into the setup moder It won't power on even if I press the power button manually.
You have this all backwards. So essentially it won't power on. THAT must happen before setup or anything else.
http://www.retrevo.com/support/Onkyo-TX-SR605-Receivers-manual/id/2526bh742/t/2/
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 21, 2011 | Onkyo TX-SR605 Receiver
How do I connect my onkyo tx-sr705 to a pyle pro speaker selector? I am "not" using the onkyo for a surround sound, only for music with 3 pairs of speakers in different rooms. (CD, Sirrus...
Hi Mdensonjr, I see that this was posted in 2011 but well the speaker selector would be connected to the Front speaker terminals, Thanks, JT
May 29, 2011 | Onkyo TX-SR705 Receiver
My onkyo tx-8222 suddenly stopped amplifying on both speakers and headphones. I can hear music faintly with the volume at max (just the pre-amp?). Time for a new amp?
Never use maximum volume for troubleshooting. The errant switch or control that you eventually find and flip will suddenly release the amp's full power and you'll destroy your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Look for a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Feb 21, 2011 | Onkyo TX-8222 Receiver
Rear Speakers no Sound.
The rear speakers will only work when the Dolby signal processor or one of the 4 sound fields has been selected. In other words, the rear speakers won't "work" when listening in just Stereo, and this can happen if the "By-Pass" button on the front of the receiver has been engaged.
May 15, 2010 | Onkyo TX-SV535 Receiver
Connect an amp to a Onkyo tx-904
tou may want to hook this to speaker select switch
Aug 28, 2009 | Onkyo TX-SR705 Receiver
No sound coming out of speakers something is wrong with the receiver
check if it goes to protection mode on power on. see to it that speaker selector switch is set.
Is your speakers connected properly?
Is your music source ok?
Do you hear a click after you switch on the power? the click indicates that the time-on delay transfers the amps output to the speakers which prevents thumps going out to the speakers.
Once it goes to protection mode you need to have it serviced. This is due to a fault in one of the amps and that it protect the speakers from further damage.
Aug 17, 2009 | Onkyo TX-SR502 Receiver
MY REMOTE IS NOT WORKING FOR MY ONKYO TX-SV525,
Hello, I am sorry for your issue. Please go to replacementremotes.com and search txsv525. They do sell a replacement. If you email me at askonkyo@us.onkyo.com and I will send you a copy of the manual. Thank you. Onkyo USA
Mar 14, 2017 | Onkyo TX-SV545 Receiver
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
TX 8410 Onkyo no sound
Well, I'm sure you've either fixed the issue or gotten rid of the unit by now, but anyway... perhaps the speaker selection was accidentally switched (A or B), or my personal favorite: "Tape 2 Monitor" was turned on. Even if you select something else, you'll still see "Tape 2 Monitor" displayed on the LED display. Hit the button again and it will go away and your sound should return.
Jun 05, 2008 | Onkyo TX-8410 Receiver
294 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
