Question about FrontRange Solutions Goldmine 6.5 for PC
I have GM6.5 and I am having problems with the incoming mail information in terms of not been able to see the information, when I searh the mails they are not there and When trying to pack the files with the DB utilities I've got an error message of disk full (which is false as I have 20 free gb space. I have done it several times and I got rid from the error, but still incoming mails seem to dissapear or not been on it's place. Any hint or idea? I do not have the master pwd and I enter as normal user
What is incoming mail server
Welcome to FixYa.
"Incoming Mail Server" is a computer in a network that provides "post office" facilities. It stores incoming mail for distribution to users (message store) and forwards outgoing mail through the appropriate channel (message transfer agent). The term may refer to just the software that performs this service, which can reside on a computer with other applications or to a stand-alone computer dedicated only to the mail function.
When setting up your phone to receive emails from your GMAIL via a specific email client (software) installed in your phone, the incoming mail server should be pop.gmail.com
Thank you for using FixYa. Have a great day.
Jas247
Jun 15, 2011 | Nokia N81
Tip
How to setup your email into your iPhone
First, you need to know your IMAP incoming and outgoing mail servers. These servers can be provided by your email service provider. Once you have these info, you may follow the steps below:
1.Go to 'Settings' on the main menu on your iPhone.
2. Click on Mail, Contacts, Calendar...
3. Select Add Account and tap 'Other'
4. Add mail account and then fill out the lines with your name, e-mail address and password then tap 'Save'.
5. Select IMAP and then use the information below:
* Incoming Mail Server *
- Host Name: type the IMAP incoming server
- User Name: type your complete email address
- Password: your e-mail password
* Outgoing Mail Server *
- Host Name: type the IMAP outgoing server
6. Tap Save button.
Thank you!
on May 03, 2010 | Cell Phones
Tip
Tip for emails from MS
Information that you must obtain from your ISP before you configure Outlook Express 6.0 loadTOCNode(2, 'summary');
  • E-mail address. An example of an e-mail address is "someone@example.com."
  • Username. For example, if your e-mail address is someone@example.com, your username is "someone."
  • Password.
  • Incoming mail server name. An example of an incoming mail server is "pop.microsoft.com."
  • Incoming mail server type. Is the incoming mail server type a POP3 server?
  • Outgoing mail server name. An example of an outgoing mail server is "smtp.microsoft.com."
  • Does your account require that you use secure password authentication?
  • Does the ISP use any non-standard e-mail ports?
from MS site
on Dec 01, 2009 | Computers & Internet
I cant get my bellsouth.net incoming mail or outgoing. had to set up my computer ater losing everything what do i put for my incoming mail server(pop, imap, http incoming mail pop, imap or...
Im assuming you are using outlook express, if not, I apologize, but steps should be similar for other types of software:
  1. On the Tools menu, click E-mail Accounts.
  2. Click Add a new e-mail account, and then click Next.
  3. Click POP3, and then click Next.
  4. Under User Information, do the following:
    1. In the Your Name box, type your full name the way that you want it to appear to other people.
    2. In the E-mail Address box, type your e-mail user name, followed by @bellsouth.net.
  5. Under Server Information, do the following:
    1. In the Incoming mail server (POP3) box, type mail.bellsouth.net.
    2. In the Outgoing mail server (SMTP) box, type mail.bellsouth.net.
  6. Under Logon Information, do the following:
    1. In the User Name box, type your full e-mail address, including the @bellsouth.net domain.
    2. In the Password box, type your password.
    3. Select the Remember password check box.
Note You have the option to have Outlook remember your password by typing it in the Password box and selecting the Remember password check box. Having Outlook remember your password means that you won't have to type your password each time you access the account; however, it also means that the account is vulnerable to anyone who has access to your computer.
  1. To verify that your account is working, click Test Account Settings. If there is missing or incorrect information, such as your password, you are prompted to supply or correct it. Make sure your computer is connected to the Internet.
  2. Click More Settings.
  3. On the General tab, under Mail Account, type BellSouth.net.
  4. Click the Outgoing Server tab, and then select the My outgoing server (SMTP) requires authentication check box.
  5. Select Use same settings as my incoming mail server, and then click OK.
  6. Click Next, and then click Finish.
Notes
  • Do not select the Log on using Secure Password Authentication (SPA) check box.
  • Unless specified by BellSouth.net, all server and address entries are typed in lowercase letters.
Good Luck!
Aug 10, 2010 | Computers & Internet
Tip
How to set up the e-mail client - T-Mobile Shadow?
To set up an e-mail account on the device, follow these steps:
  1. From the Home screen, scroll down to Message Center.
  2. Scroll to the right and select Set Up E-mail.
    • NOTE: For additional information on setting up e-mail, select FAQ's or About.
  3. Select one of the following options:
    • AOL | AIM Mail: set up your device to receive e-mail from an AOL® or AIM® account.
      1. Read the terms of use, then select Accept.
      2. Type your Screen name and the at symbol (@), then select either aol.com or aim.com
      3. Type your Password.
      4. Select Next.
        • NOTE: Ensure the Save Password check box is selected.
      5. Select Finish or Done.
    • Gmail: set up your device to receive e-mail from a Gmail account. Before using this service, verify that POP e-mail access is enabled in your Gmail account.
      1. Type your e-mail account name.
      2. Type your password.
      3. Select Next.
      4. Select Finish or Done.
    • Windows Live Hotmail: set up your device to receive e-mail from a Windows Live™, Hotmail®, and MSN® e-mail accounts.
      1. Select Sign in to Windows Live.
      2. Read the terms of use and select Accept.
      3. Type your E-mail address and Password.
      4. Select Next.
      5. Select the desired options for display on your Home screen.
      6. Select Next.
        • NOTE: These options cannot be selected with the T-Mobile Default Home screen.
      1. Select the data options to sync on the device.
      2. Select Next.
      3. Once the device connects and downloads e-mail, select Done.
    • Yahoo! Mail: set up your device to receive e-mail from your Yahoo!® Mail account.
      1. Read the terms of use and select I Agree.
      2. Type your Yahoo! ID, Password, and Display name.
      3. Select Next.
      4. Select Finish.
        • The new Yahoo! e-mail account displays.
    • Outlook E-mail: set up your device to receive e-mail from your Outlook® account.
    • Other E-mail: set up your device to receive e-mail from other POP3 and IMAP4 e-mail accounts.
      1. Type your E-mail address and Password.
      2. Select Next.
      3. If necessary, type the Incoming and Outgoing server addresses.
      4. Select the Server Type.
      5. Scroll to Account Name Displayed and type the desired account name.
      6. Select Menu, Done.
        • The message Set up Process is complete displays on your screen
on Dec 08, 2008 | HTC Shadow Smartphone
On incoming Yahoo mail...how can I print full email message
Just click and open the mail.... then click on Print button located on top of your mail page, one preview page will open with your full mail.....as well as the printer list...select your printer, through that you want to print....and click Print...Thats all....enjoy staying with Fixya....Good Luck
Nov 13, 2009 | Yahoo Mail
I need to find out the names of my incoming e-mail and out going
The incoming mail server (pop3) is mail.yahoo.com
The outgoing mail server (smtp) you should get it from your internet provider.
Jan 22, 2009 | Yahoo Mail
Emails
The default name server due to interaction with the router?s NAT firewall feature cannot resolve simple names such as ?mail?. There is a workaround for this: First, verify that the mail client is set up with simple server names. To view the server names entered into Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". If these are simple names like "Mail" and not something like "pop.myisp.mail.com" then use this work around. Second, make sure that the TCP/IP settings are configured to obtain an IP address automatically. In Windows 2000 also make sure that the TCP/IP settings are also configured for Obtain DNS server address automatically. Replace the mail server names with the mail server IP addresses. There are a couple ways this information can be obtained. Contacting the ISP and asking is one possible way. The other way is to reconnect the original computer to the modem. Make sure the computer is restarted or that the IP configuration is released and renewed and that the computer has obtained an IP address from the ISP. Open a "COMMAND" window by typing "CMD" in the run dialog box located in the "Start" menu. At the command prompt, type "PING MAIL" where "mail" is the simple name of the incoming mail server. The ISP server will return an IP address for the mail server. Record this address. Do the same for the outgoing mail server (if different): type "PING MAIL" where "mail" is the simple name of the outgoing mail server. Open the mail client (Outlook Express, etc.). For Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". Enter the incoming and outgoing mail server IP addresses into these fields. Click "Apply". Close the window and test the mail by sending an e-mail to the mailbox. (Send an E-mail to yourself. This will test the incoming and outgoing mail all at once)
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Cant get my emails?!!!
The default name server due to interaction with the NAT firewall feature of the router cannot resolve simple names such as ?mail?. There is a workaround for this: First, verify that the mail client is set up with simple server names. To view the server names entered into Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". If these are simple names like "Mail" and not something like "pop.myisp.mail.com" then use this work around. Second, make sure that the TCP/IP settings are configured to obtain an IP address automatically. In Windows 2000 also make sure that the TCP/IP settings are also configured for Obtain DNS server address automatically. Replace the mail server names with the mail server IP addresses. There are a couple ways this information can be obtained. Contacting the ISP and asking is one possible way. The other way is to reconnect the original computer to the modem. Make sure the computer is restarted or that the IP configuration is released and renewed and that the computer has obtained an IP address from the ISP. Open a "COMMAND" window by typing "CMD" in the run dialog box located in the "Start" menu. At the command prompt, type "PING MAIL" where "mail" is the simple name of the incoming mail server. The ISP server will return an IP address for the mail server. Record this address. Do the same for the outgoing mail server (if different): type "PING MAIL" where "mail" is the simple name of the outgoing mail server. Open the mail client (Outlook Express, etc.). For Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". Enter the incoming and outgoing mail server IP addresses into these fields. Click "Apply". Close the window and test the mail by sending an e-mail to the mailbox. (Send an E-mail to yourself. This will test the incoming and outgoing mail all at once)
Feb 16, 2006 | Belkin (F5D5230-4) Router
FrontRange Solutions Goldmine 6.5 for PC Logo
21 people viewed this question
Top FrontRange Solutions Computers & Internet Experts
David Payne
David Payne
Are you a FrontRange Solutions Computer and Internet Expert? Answer questions, earn points and help others
